SN20-KP2̨ÍåÈð¿ÆRIKO½Ó½ü¿ª¹Ø
surface / ™zœy·½Ïò £¬Top surface / ǰ·½
Standard sensing object / ˜ËœÊ™zœyÎ Iron 18 x1 8 x 1mm
Sensing distance / ™z³ö¾àëx£¬ 4 mm
Secure sensing distance / ½¨×h¾àëx£¬ 0 to 3.2 mm
Hysteresis / ßtœþ£¬ ¨Q 10 % of sensing distance
Response time / ·´‘ª•rég£¬ 50 ms Max. 2 ms
Operating voltage / £¬¹¤×÷늉º AC90 ~ 260 V DC10 ~ 30 V
Current consumption / ÏûºÄëŠÁ÷£¬ 2 mA Max.
Load current / Ø“ÝdëŠÁ÷£¬5~100 mA Max. 100 mA
Leakage current / ©ëŠÁ÷£¬ ¨Q 2.0mA no-load
Residual voltage / šˆðN늉º£¬ ¨Q AC 4V
Insulation resistance / ¸ôëx×迹£¬ 20M Ω min. (DC500V)
Voltage withstandability / ½^¾‰Ä͉º£¬ AC1000V 60Hz for 60 Sec.
Operating temperature / ¹¤×÷œØ¶È¹ ‡ú£¬ -20¡æ ~ + 60¡æ
Protection degree / ·ÀË®µÈ¼‰£¬ IP 66
Wiring method / ³ö¾€·½Ê½£¬ Pre-wire
?4.2 x 2M/2-wires M8 pigtailed type /M8£¬ ½Óî^15cm
?4.2 x 2M/3-wires M8 pigtailed type /M8
·½Ðνü½Ó´«¸ÐÆ÷£ºSN04-N/N2/P/P2 SND04-N/N2/P/P2 SN05-N/N2/P/P2 SN10-KP2 SN20-KP2 JN04-N JND02-N RN04-N
Ô²Ðνü½Ó´«¸ÐÆ÷£ºSC0401-N/N2/P/P2 SC0501-N/N2/P/P2 SC0801/02-N/N2/P/P2 SCS0801/02-N/N2/P/P2 SC1202/04-KP2 SC1202/04-A/A2 SCS1202/04-N/N2/P/P2 SCL1202/04-KP2 SCL1202/04-A/A2 SC1805/08-KP2 SC1805/08-A/A2 SCL1805/08-KP2 SCL1805/08-A/A2 SC3010/15-KP2 SC3010/15-A/A2 SCL3010/15-KP2 SCL3010/15-A/A2 SCP3010/15-KP2 SCP3010/15-A/A2 SCL3018-KP2
¾²µçÈÝʽ½ü½Ó¿ª¹Ø£ºKC1810-B3/P3 KC3025-KP2
¹âµç´«¸ÐÆ÷£ºMF-DU30KP2 SU-B3 MF5-KP2 RMF10/20-KP2 RMF-CR2N
RMF-DU10/40N(ËܽºÍ·) MMF-DU10/40N(½ðÊôÍ·) PK3-DU30N RK3-R2N PK3-5N R3JK-DU100KP2 R3JK-R5KP2 R3JK-30KP2
»·Ðιâµç¿ª¹Ø£ºRQ36-KP2
µçÔ´¿ØÖÆÆ÷£ºST-1 ST-T2
¹âÏË·Å´óÆ÷£ºFZ-KP2 VRF-SN
¹âÏ˹ܣºFR-610 FR-610-I FR-610-M FR-610-L FRC-610 FRC-610-S FRC-610-M FRC-610-L FRH-610 FRS-410 FRS-410-S FRS-410-M FRS-410-L FRC-410 FRS-310 FRC-310 FRE-410 FRE-310-M FR-510 FR-620-6F FRX-620-6F FRS-420-S67 FRW-420-S67 FRE-310-S15(0.8) FRB-420 FRZ-420 FRY-620-6F FRX-610-P FRCC-420 FRC4-310-69X FRG-410-L FGR-410 FGR-620 FRC420+FLM04 SFRC-305-21X FRC-210-22X SFRC-505-S17 FRC-620-25 FRC-310-35FA FRC-310-35FZ FRB-320-Q FRZ-320-Q FRD-420-S22Q FRE-310-S5Q(0.8) FRCH-110-S3 FRC4-320Q FRC4-110 FRH-620-6F FT-410 FT-310 FT-20ML FT-320-Q FTY-320-Q SFT1-305-S5Q(0.3) FTC4-110-H10 FT-420 FTX-620-6F FT-420-S67 FTS-310-S15(0.8) FTE-310-S45Q(0.4) FTX-420 FTY-420 FTX-410P FTC9-420 FTC4-310 FGT-420 FTH-420-F1 FGTX-420 µÈµÈ
¾Û½¹¾µ£ºFLM-02 FLSM-02 FLM-03 FLM-03-1 FLM-04 FLM-06µÈ>
