·ÖÌåʽÊý×Ö²âÕñÒǵÄÏêϸ½éÉÜ
·ÖÌåʽÊý×Ö²âÕñÒÇTM63B
TM63B·ÖÌåʽÊý×Ö²âÕñÒÇ£¬¿É²âÁ¿ËÙ¶È£¬¼ÓËÙ¶È£¬Î»ÒÆ£¬¸ßµÍƵÇл»¹¦ÄÜ¡£Ö÷ÒªÓÃÓÚ·¢µç³§¡¢Âí´ï¡¢·¢¶¯»ú¡¢±Ã¡¢µç»úµÈÉ豸ÎÞËð¼ì²âÓÃ;¡£·ÖÌåʽÊý×Ö²âÕñÒdzý±ê׼̽ͷÁí±êÅä´ÅÐÔÎüÅÌ̽ͷ£¬¼«´óµÄ·½±ã¼°ÊÊÓø÷Àà¼ì²â»·¾³µÄ²âÁ¿¡£
ÐͺŹæ¸ñ
TM63B
SPECIFICATIONS
¹¤×÷ζÈ
0¡«40¡æ
Operating temperature range
¹¤×÷ʪ¶È·¶Î§
30¡«90%RH
Operating humidity range
²âÁ¿Îó²î
±5%H±2digits
Measuring accuracy
Õ𶯲ɼ¯
ѹµçÌմɼÓËټƣ¨¼ôÇÐÐÍ£©
Vibration pickup
Piezoelectric ceramic accelerometer(shear-type)
¼ÓËٶȲâÁ¿ ƵÂÊ·¶Î§
10HZ¡«1KHZ(LO) 1KZ¡«15KHZ(HI)
Measurement frequency
0.1¡«199.9m/s
Range of acceleration
ËٶȲâÁ¿ ƵÂÊ·¶Î§
10HZ¡«1KHZ(LO)
0.1¡«199.9mm/s rms
Range of velocity
Î»ÒÆ²âÁ¿ ƵÂÊ·¶Î§
10HZ¡«1KHZ(LO)
0.001¡«1.999mm P-P
Range of displacement
LCDÏÔʾ
3λ°ëÊý×ÖÏÔʾ
LCD dispiay
3.5 digits dispiay
ÏÔʾÊý¾Ý¸üÌæÖÜÆÚ
1S
Single output
Êý¾ÝÊä³ö
ACÊä³öPeak(ÏÔʾȫÁ¿³Ì)£»
¸ºÔØ£º10KΩ»ò¸ß×è¶ú»ú¿ÉÒÔÁ¬½Ó
Static cutput
AC output 2V peak( dispiay full scale) load impedance 10kΩ or more earphones can be connected
×î´óÖµËø¶¨
Max hold function
ζÈת»»
Temperature selection
»·¾³ÏÔʾ
Operation condition display
µçÔ´
9V 6F22µç³Ø
Power supply
9Valkaline battery
