ADI16-16(LPCI)L窄卡PCI总线廉价高精度隔离型模拟量输入接口板
ADI16-4(FIT)GY隔离型高精度模拟量输入模块
ADI16-4(USB)是USB2.0隔离型高精度模拟量输入模块
ADI16-16(LPCI)L窄卡PCI总线廉价高精度隔离型模拟量输入接口板,This product is a PCI bus compatible interface board with high-precision analog input(16-bit, 16 ch), digital input and output channels (4 channels each), and a 32-bit counter(1 channel). Noise characteristics-resistant improve by the bus isolation. Windows Driver Library API-PAC(W32) /Linux driver API-AIO(LNX) is Bundled. It can also collect data easily without a program when the data logger software [C-LOGGER] stored on the attached CD-ROM is used. With plug-ins for the dedicated libraries, the board also supports MATLAB and LabVIEW.
ADI16-4(FIT)GY隔离型高精度模拟量输入模块,This product can change an external analog voltage signal into digitized data. It can connect with the controller unit <CPU-CAXX(FIT)GY, CPU-SBxx(FIT)GY etc.>of F&eIT series, and a system can be built. Moreover, since it has isolated with the digital isolator, CPU which controls an external signal and a module does not have electric influence of external on a host computer as it is.
ADI16-4(USB)是USB2.0隔离型高精度模拟量输入模块,ADI16-4(USB) is compact analog input module which is applied to USB and can be used easily. ADI16-4(USB) converts external analog voltage signals into digital data.
