ÈðÊ¿¼ÑÀÖcarlogavazzi¹Ì̬¼ÌµçÆ÷RR2A40D400 Ò»¸öΪ¿ª¹Ø¸÷ÖÖ¸ºÔØ£¬Èç¼ÓÈÈÔª¼þ£¬µç»úºÍ±äѹÆ÷¶øÉè¼ÆµÄ¹Ì̬¼ÌµçÆ÷ϵÁС£´Ë ¼ÌµçÆ÷¿ÉÒÔ¿ª¹Ø¸ß´ï600V ACµÄµçѹ¡£ÄÚÖõıä×èÆ÷¿ÉÈ·±£ÓÃÓÚÖØ¹¤ÒµÓ¦Óó¡ºÏµÄÔÝ̬±£ »¤¡£ÎªÁ˸߿ɿ¿ÐԺ͸ºÔØÑ»·ÈÝÁ¿£¬Èý¸ö°ëµ¼Ì幦Âʵ¥ÔªÖ±½Óº¸ÔÚ´É»ù¸²Í°åÉÏÍâÐͳߴ磺120×45×110MM ÌØÕ÷£ºÄÚÖûº³åÆ÷£¬×Ô´øÉ¢ÈÈÆ¬°ëµ¼Ì忪¹ØÔª¼þ£¬ÊʺÏ45-65HZ£¬¹¤Æµµç·£¬¶î¶¨ ¾øÔµµçѹ´óÓÚµÈÓÚ400VMS ¹ýÁã´¥·¢¶î¶¨¹¤×÷µçÁ÷: 3 x 25, 55 »ò 75 A ¶î¶¨¹¤×÷µçѹ: ¿É´ï 600 VAC ¿ØÖƵçѹ 5 VDC, 4-32 VDC »ò 24-275 VAC ÄÚ²¿¼¯³É»º³åϵͳÄÚÖñä×èÆ÷´ø±¨¾¯Êä³öµÄ¹ýα£»¤ IP 10 ÊÖ±³±£»¤¿ØÖÆÊäÈëºÍ¹ýα¨¾¯×´Ì¬LEDָʾ RR2A40D150 2PH MOTOR REVERSING 400VAC 1.5KW DC IP RR2A40D400 2PH MOTOR REVERSING 400VAC 4.0KW DC IP RR2A40HA150 2 PH MOTOR REVERSING 400VAC 1.5KW HIGH AC IP RR2A40HA400 2 PH MOTOR REVERSING 400VAC 4.0KW HIGH AC IP RR2A40LA150 2 PH MOTOR REVERSING 400VAC 1.5KW LOW AC IP RR2A40LA400 2 PH MOTOR REVERSING 400VAC 4.0KW LOW AC IP RR2A48D220 2PH MOTOR REVERSING 480VAC 2.2KW DC IP RR2A48D550 2PH MOTOR REVERSING 480VAC 5.5KW DC IP RR2A48HA220 2 PH MOTOR REVERSING 400VAC 2.2KW HIGH AC IP RR2A48HA550 2 PH MOTOR REVERSING 400VAC 5.5KW HIGH AC IP RR2A48LA220 2 PH MOTOR REVERSING 400VAC 2.2KW LOW AC IP RR2A48LA550 2 PH MOTOR REVERSING 400VAC 5.5KW LOW AC IP
