Model Name
R175
R220
R260
R315
R360
R390
R430
R490
Rating Current(A)
175
220
260
315
360
390
430
490
Model Name
H175
H220
H260
H315
H360
H390
H430
Rating Current(A)
175
220
260
315
360
390
430
Input Voltage(V)
380Vac(-15%) to 480Vac(+10%), 3 Phase, 400 ~ 680Vdc
Input Frequency
48 ~ 62 Hz
Output Voltage
0 to input voltage
Output Frequency
0 to 200 Hz
Output Power (KW)
90
110
132
160
185
200
220
Overload
110%, continuous 1 minute
Control System
Sensorless flux Vector, Sine coded PWM
Frequency Resolution
0.1Hz
Frequency Linearity
0.2% of maximum frequency
Communications
Modbus, LonWorks, Metasys via RS-485 (option), BACnet
Braking Mode
Dynamic braking (option), Control stop
Accel & Decel Adjustment
Independent Accel & Decel adjustment with S-curve
Analogue Input/Output
0~5V, 0~10V ; 0~20mA, 4~20mA
Digital Input
5 Digital input with programmable control functionality
Relay Output
2 relays type NO / NC with programmable functionality
Local Control
Comprehensive local control include Start (FWD/REV), Stop, Reset, and Set Speed
Display Screen
16 character*2 line alphanumeric, Backlight and auto contrast.
Run Variables
Output frequency(Hz), Motor Speed(RPM), % Load, Output current(A) , Power(KW), Output Voltage(V), Temperature, I2t used process variable scale
Protection
Current limit, Over voltage, Under voltage, Short circuit, Earth fault, Phase monitoring, Motor electronic thermal overload, Over temperature
Safety Standard
UL508C, AS3100
Enclosure Rating
IP30 & IP54
Operating Temperature
0 ~ 40oC, up to 50oC with derating
Relative Humidity
90% RH, non-condensing
Service Conditions
1000M or less no derating: not subject to direct sunlight or corrosive/explosive
Size for IP30 (H*W*D*)
1225*555*520(mm)
Size for IP54 (H*W*D*)
