System
CPU
Freescale MPC8308 PowerPC CPU,400MHz
Memory
DDR2 128M
Flash
8M NorFlash
128M NandFlash
Operating System
Linux 2.6.29.6
LED
NISE-P1016-S
System:Power x1,RUN x1,PWR1 Alarm x1,PWR2 Alarm x1
LAN:Link x6 & Act x6 Indicators
Serial Port:Transfer x16 & receive x16 Indicators
Function LED:2 x4 Indicators
Others
RTC,Buzzer,Watchdog Timer,Reset button,Console Port x1
Serial Communication
Console Port
Console Port DB9 connector x1
RS232 115200Bps N,8,1
Serial Port
16 x RS-232/485 TB Interface connector
Software Mode select
RS-232 Signals£ºTXD,RXD,GND
RS-485 Signals£º485A(Data+),485B(Data-)
Baud:300¡«115200Bps
Protection
Built-in 15KV ESD protection for all signals, 2KV iCoupler digital isolation protection
Network Communication
LAN
NISE-P1016-S
Auto-sensing 10/100/1000Mbps x 2, RJ45
Auto-sensing 10/100Mbps x 4, RJ45
Build-in 2KV iCoupler digital isolation protection
Optional
Digital Input Port
4 x Isolation Input
VL:¨Q80V
VH:>85V
Digital Output Port
4 x Relay Output
VL:¨Q80V
VH:>85V
CAN Port
CAN2.0B(Isolation protection)
Baud:5Kbps¡«1Mbps
IRIG-B Port
RS-485(Isolation protection)
Precision:±1us
Power Requirements
Power Input
Dual Power Input Design
PWR1: 85~265VDC or 100~265VAC
PWR2: 85~265VDC or 100~265VAC
Lost power alarm
Relay empty node(Limited to single power)
Power alarm indicators
Power Consumption
10W@220VAC
Mechanical
Dimensions
483(L)x226.7(W)x44(H)£¨Maximum size£©
Installation
Rack Mount 1U
Environmental
Operating Temperature
-20-60¡æ
Storage Temperature
-30-80¡æ
Regulatory Approvals and Warranty
EMC
GB/T 17626.2-2006 Class 4
GB/T 17626.4-2008 Class 4
GB/T 17626.5-2008 Class 4
GB/T 17626.6-2008 Class 3
Warranty
3 Years
