System
CPU
Freescale MPC8308 PowerPC CPU,400MHz
Memory
DDR2 128M
Flash
8M Nor Flash
128M Nand Flash
Operating System
Linux 2.6.29.6
LED
System:Power x1,RUN x1,
LAN:10/100/1000M x4(Link x2 Act x2)
Serial:TxD x8,RxD x8
Others
RTC,Buzzer,Watchdog Timer,Reset button,Console Port x1
Serial Communication
Console Port
Console Port RJ45 connector x1
RS232 115200bps N,8,1
Serial Port
8xRS-232/485 TB Interface connector
software-selectable
RS-232 Signals£ºTxD,RxD,GND
RS-485 Signals£º485A(Data+),485B(Data-)
Protection
Built-in 15KV ESD protection for all signals, 2KV iCoupler digital isolation protection
Network Communication
LAN
Auto-sensing 10/100/1000Mbps x 2, RJ45
Build-in 1.5KV magnetic isolation protection
Power Requirements
Power Input
Dual Power Input Design
PWR1:9-48VDC or 9-48VAC
PWR2:9-48VDC or 9-48VAC
Lost power alarm
Relay empty node
Power Consumption
8W@12VDC
Mechanical
Dimensions
200(L)x121.01(W)x54.1(H)
Installation
DIN-Rail Mount
Environmental
Operating Temperature
-20-60¡æ
Storage Temperature
-30-80¡æ
Regulatory Approvals and Warranty
EMC
GB/T 17626.2-2006 Class 4
GB/T 17626.4-2008 Class 4
GB/T 17626.5-2008 Class 4
GB/T 17626.6-2008 Class 3
Warranty
3 Years
