Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ADVANTEST/8250A/¹â¹¦ÂʼÆ
²úÆ·Ãû³Æ£º ADVANTEST/8250A/¹â¹¦ÂʼÆ
ÐÍ ºÅ£º 8250A
Features
High resolution 0.001dB, 5 1/2-digit display
GPIB and USB interfaces
Various sensors available by use
1) three-wavelength optical sensor applicable to Blu-ray disk, DVD (650nm) and CD (780nm), most suitable for pick up evaluation (82314B/82324B/82314BW)
Flat wavelength sensitivity characteristic and low dependency on an angle of incidence in the 405/650/780 nm bands
Low reflection; less measurement deviation due to multi reflection between the sensor and the pickup.
2) Blue-violet optical sensor most suitable for Blu-ray disk in the 405nm band (82312B/82322B)
Flat wavelength sensitivity characteristic and low incident-angle-dependency in the 405 nm band
3) High-power optical sensor of up to 200mW (82313B/82323B)
The maximum light-receiving power of 200mW suitable for pickup measurement of high-speed rewritable CD/DVD
It is possible to measure high power density without saturation up to 200mW even at 0.1mmφ spot diameter.
4) Low-price general-purpose optical sensor (82311B/82321B)
Both thin-type and cylindrical-type optical sensors are available. Manual measurement and system built-in measurement can be performed easily.
Sensor power calibration wavelength: 405/650/780nm
Maximum three-wavelength power calibration is available on just one sensor by adding the calibration wavelength options. (405nm: OPT+21/650nm: OPT+22/780nm:OPT+23)
The optical sensors for the TQ8210/TQ8215 series (82014A/82017A/82015/Q82018A) are also usable.
¹«Ë¾Ãû³Æ£º ÉîÛÚÊЕ‰³½µç×ӿƼ¼ÓÐÏÞ¹«Ë¾×¤ÈذìÊ´¦
µç »°£º 028 85224905 / ºôÓÀ
ÊÖ»ú£º 13982098642
µØ Ö·£º Îäºî´óµÀÓŲ©¹ú¼Ê2£­1018
ÓÊ ±à£º 610043
Ö÷ Ò³£º http://www.wl95.com
  • ÊÛÐÞÊÕ Advantest R3765BH ʸÁ¿ÍøÂç·ÖÎöÒÇ
  • ¿çÓò·ÖÎöÒÇ
  • ¿çÓò·ÖÎöÒÇ
  • ¿çÓò·ÖÎöÒÇ
  • Ë«¹â¹¦ÂÊ´«¸ÐÆ÷
  • ¾­¼ÃÐÍ»úеУ׼Ì×¼þ
  • ¹âÆ×·ÖÎöÒÇ
  • ¹âÆ×·ÖÎöÒÇ
  • S-²ÎÊýʸÁ¿ÍøÂç·ÖÎöÒÇ
  • ΢²¨ÍøÂç·ÖÎöÒÇ
