²úÆ·Ãû³Æ£º
ADVANTEST/R3755A/R3760/ÍøÂç·ÖÎöÒÇ
ÐÍ ºÅ£º
R3755/R3760
| 300MHz Board Network Analyzer R3755A |
Compact size, light weight, low power consumption of less than 15 W, and with the capacity to drive up to eight units in parallel.
The R3755A network analyzer evaluates the frequency characteristics of electronic components, such as the crystal resonator and ceramic resonator used in a broad range of electronic equipment, as well as antennas for receiving/transmitting wireless signals. |
Frequency range: |
10kHz to 300MHz |
Output level: |
+18dBm to -43dBm (1MHz to 300MHz) |
Measurement parameter: |
A/R |
External dimensions: |
PCI board, half size, 1slot |
Input/output: |
Parallel I/O (Standard) |
6GHz Board Network Analyzer R3760 |
Compact size, light weight, low power consumption of less than 20 W, and with the capacity to drive up to eight units in parallel.
The R3760 network analyzer, low in cost and with a space-saving design, measures and evaluates the frequency characteristics of receiving/transmitting antennas and filters, which are used for wireless communications such as mobile phones, WiMAX, WiFi, and ETC systems for ubiquitous communication. |
Frequency range: |
300MHz to 6GHz |
Output level: |
0dBm to -10dBm (≤3GHz) |
Transmission/Reflection |
PCI board, half size, 2slots |
Input/output: |
