| Feature |
Upgraded Measuring Speed using high-speed processing
(twice as fast in comparison with our conventional models) |
Compact design, lightest (in this class) |
Lowest cost Spectrum Analyzer with basic functionality in this class |
Main Performance |
Frequency range : 9kHz to 3GHz |
Noise level : -135dBm (center frequency 1GHz, Pre-Amp ON) |
Resolution bandwidths : 100Hz to 1MHz |
General Function |
RMS detection supports high-speed, high-stability power measurement |
Emission Mask, OBW/ACP, and other limit test functions |
USB Interface for saving/recalling configuration files and measurement data |
