Lightwave Tunable Laser Source
- Wavelength range: 1450 nm to 1590 nm
- Wavelength accuracy: ±0.035 nm
- Wavelength resolution: .001 nm
- Wavelength stability: < ±100 MHz
- Output power: -7 to 7 dBm
- Sidemode suppression ratio: > 50 dB
- Linewidth: 100 kHz
Agilent 8168F with option 022 Tunable Laser Source
Specifications at a glance for the 8168F with option 003
- Wavelength Range: 1450nm to 1590nm
- Wavelength Resolution: 0.001nm, 125MHz at 1550nm
- Optical Output Level: +6.5dBm Typical
- Fiber Type: SMF-28
Additional Information
- Option 022: Angled Contact Connector
- Option 003: Built-in Attenuator - Optical Power Stability: +/-0.03dB (typ +/-0.01dB)
- Wavelength Accuracy: +/-0.1nm
Possible options for the 8168F:
- Option 003: built-in optical attenuator, 40 dB attenuation
- Option 007: Polarization maintaining fiber, Panda-type, for straight or angled connector types (cannot be combined with option 003 or 023).
- Option 021: straight contact connector
- Option 022: angled contact connector
- Option 023: Diamond HMS-10/HP/HRL angled, non-contact connector (cannot be combined with option 007).
