²úÆ·Ãû³Æ£º
½ÜŵÄ͸ßÎÂ150¡æÈ«½ðÊô½Ó½ü¿ª¹Ø
ÐÍ ºÅ£º
LM18-3008NA-H
| ÍâÐÎ |
¶î¶¨¸ÐÓ¦¾àÀëSn |
Êä³ö״̬ |
Ä͸ßνӽü¿ª¹Ø¾ß±¸Ðͺţ¨ÄÏͨ½ÜŵµçÆø£© |
| NPN£¨ÈýÏߣ© |
PNP£¨ÈýÏߣ© |
Ö±Á÷£¨Á½Ïߣ© |
½»Á÷£¨Á½Ïߣ© |
| M12 |
·ÇÂñÈëʽ |
4mm |
³£¿ª |
LM12-3004NA-H |
LM12-3004PA-H |
LM12-3004LA-H |
LM12-2004A-H |
| ³£±Õ |
LM12-3004NB-H |
LM12-3004PB-H |
LM12-3004LB-H |
LM12-2004B-H |
| ÂñÈëʽ |
2mm |
³£¿ª |
LM12-3002NA-H |
LM12-3002PA-H |
LM12-3002LA-H |
LM12-2002A-H |
| ³£±Õ |
LM12-3002NB-H |
LM12-3002PB-H |
LM12-3002LB-H |
LM12-2002B-H |
| M18 |
·ÇÂñÈëʽ |
8mm |
³£¿ª |
LM18-3008NA-H |
LM18-3008PA-H |
LM18-3008LA-H |
LM18-2008A-H |
| ³£±Õ |
LM18-3008NB-H |
LM18-3008PB-H |
LM18-3008LB-H |
LM18-2008B-H |
| ÂñÈëʽ |
5mm |
³£¿ª |
LM18-3005NA-H |
LM18-3005PA-H |
LM18-3005LA-H |
LM18-2005A-H |
| ³£±Õ |
LM18-3005NB-H |
LM18-3005PB-H |
LM18-3005LB-H |
LM18-2005B-H |
| M30 |
·ÇÂñÈëʽ |
15mm |
³£¿ª |
LM30-3015NA-H |
LM30-3015PA-H |
LM30-3015LA-H |
LM30-2015A-H |
| ³£±Õ |
LM30-3015NB-H |
LM30-3015PB-H |
LM30-3015LB-H |
LM30-2015B-H |
| ÂñÈëʽ |
10mm |
³£¿ª |
LM30-3010NA-H |
LM30-3010PA-H |
LM30-3010LA-H |
LM30-2010A-H |
| ³£±Õ |
LM30-3010NB-H |
LM30-3010PB-H |
LM30-3010LB-H |
LM30-2010B-H |
| ¼¼Êõ²ÎÊý |
×î¸ß¹¤×÷ƵÂÊ |
·ÇÂñÈëʽ400Hz |
·ÇÂñÈëʽ400Hz |
200Hz |
10Hz |
| ÂñÈëʽ800Hz |
ÂñÈëʽ800Hz |
200Hz |
10Hz |
| ¶î¶¨¹¤×÷µçѹ |
10-30VDC |
10-30VDC |
10-30VDC |
90-250VAC |
| ¶î¶¨¹¤×÷µçÁ÷ |
≤200mA |
≤200mA |
≤200mA |
≤200mA |
| ¼«ÐÔ±£»¤ |
¾ß±¸ |
¾ß±¸ |
¾ß±¸ |
| ¶Ì·±£»¤ |
¾ß±¸ |
¾ß±¸ |
¾ß±¸ |
| ¹¤×÷»·¾³ÎÂ¶È |
-25¡æ¡«+120¡æ |
-20¡æ¡«+120¡æ |
-20¡æ¡«+120¡æ |
-20¡æ¡«+120¡æ |
| µçѹ½µ |
≤2.5V |
≤2.5V |
≤7V |
≤6.5V |
| »Ø²î |
≤15%Sn |
≤15%Sn |
≤15%Sn |
≤15%Sn |
| ÖØ¸´¾«¶È |
≤5%Sn |
≤5%Sn |
≤5%Sn |
≤5%Sn |
| »úеÊý¾Ý |
Íâ¿Ç²ÄÁÏ |
»ÆÍ¶Æ¸õ |
»ÆÍ¶Æ¸õ |
»ÆÍ¶Æ¸õ |
»ÆÍ¶Æ¸õ |
| Á¬½Ó |
µçÀ |
µçÀ |
µçÀ |
µçÀ |
| ±£»¤·ÖÀà |
IP67 |
IP67 |
IP67 |
IP67 |
