Î÷ÃÅ×Ó6ES7314-6CH04-0AB0
ÐÍ ºÅ£º 6ES7314-6CH04-0AB0 CPU314C-2DP, 24DI/16DO/5AI/2AO
SIMATIC S7-300, CPU 314C-2 DP COMPACT CPU WITH MPI, 24 DI/16 DO, 4AI, 2AO, 1 PT100, 4 FAST COUNTERS (60 KHZ), INTEGRATED DP INTERFACE, INTEGRATED 24V DC POWER SUPPLY, 192 KBYTE WORKING MEMORY, FRONT CONNECTOR (2 X 40PIN) AND MICRO MEMORY CARD REQUIRED
CPU 314C-2 DP Êǽô´ÕÐÍ CPU£¬Êʺϰ²×°ÔÚ·Ö²¼Ê½½á¹¹ÖС£Í¨¹ýÆäÀ©Õ¹¹¤×÷´æ´¢Æ÷£¬¸Ã½ô´ÕÐÍCPUÒ²ÊÊÓÃÓÚÖеȹæÄ£µÄÓ¦Ó᣼¯³ÉµÄÊý×ÖÁ¿ºÍÄ£ÄâÁ¿ I/O ¿ÉÖ±½ÓÓë¹ý³ÌÁ¬½Ó£¬PROFIBUS DP Ö÷Õ¾/´ÓÕ¾½Ó¿ÚÔÊÐíÁ¬½Ó¶ÀÁ¢µÄ I/O µ¥Ôª¡£Òò´Ë£¬CPU 314C-2 DP ¼È¿ÉÒÔÓÃ×÷±¾µØµ¥Ôª½øÐпìËÙÔ¤´¦Àí£¬Ò²¿ÉÒÔÓÃ×÷´ø´ÓÊôÏÖ³¡×ÜÏßϵͳµÄÒ»¸ö¸ß¼¶¿ØÖÆ¡£
¶©»õºÅ
| 6ES7312-5BE03-0AB0 |
CPU312C, 10DI/6DO, 32 KB |
| 6ES7312-5BF04-0AB0 |
CPU312C, 10DI/6DO, 64 KB |
| 6ES7313-5BF03-0AB0 |
CPU313C, 16DO/4AI/2AO, 64 KB |
| 6ES7313-5BG04-0AB0 |
CPU313C, 24DI/16DO/5AI/2AO, 128 KB |
| 6ES7313-6BF03-0AB0 |
CPU313C-2 PTP, 16DI/16DO, 64 KB |
| 6ES7313-6BG04-0AB0 |
CPU313C-2 PTP, 16DI/16DO, 128 KB |
| 6ES7313-6CF03-0AB0 |
CPU313C-2 DP, 16DI/16DO, 64 KB |
| 6ES7313-6CG04-0AB0 |
CPU313C-2 DP, 16DI/16DO, 128 KB |
| 6ES7314-6BG03-0AB0 |
CPU314C-2PTP, 24DI/16DO/4AI/2AO, 96 KB |
| 6ES7314-6BH04-0AB0 |
CPU314C-2PTP, 24DI/16DO/5AI/2AO, 192 KB |
| 6ES7314-6CG03-0AB0 |
CPU314C-2DP, 24DI/16DO/4AI/2AO, 96 KB |
| 6ES7314-6CH04-0AB0 |
CPU314C-2DP, 24DI/16DO/5AI/2AO, 192 KB |
