Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÈðÊ¿¼ÑÀÖCARLO GAVAZZIµç¸Ð½Ó½ü¿ª¹ØICB12SF04NC
²úÆ·Ãû³Æ£º ÈðÊ¿¼ÑÀÖCARLO GAVAZZIµç¸Ð½Ó½ü¿ª¹ØICB12SF04NC
ÐÍ ºÅ£º ICB12SF04NC
ICB12LF04NC   M12x66mm Nichel Plated Brass 4mm Normally Closed
ICB12LF04NCM1 M12x66mm Nichel Plated Brass 4mm Normally Closed
ICB12LF04NO   M12x66mm Nichel Plated Brass 4mm Normally Open
ICB12LF04NOM1 M12x66mm Nichel Plated Brass 4mm Normally Open
ICB12LF04PC   M12x66mm Nichel Plated Brass 4mm Normally Closed
ICB12LF04PCM1 M12x66mm Nichel Plated Brass 4mm Normally Closed
ICB12LF04PO   M12x66mm Nichel Plated Brass 4mm Normally Open
ICB12LF04POM1 M12x66mm Nichel Plated Brass 4mm Normally Open
ICB12SF04NC   M12x50mm Nichel Plated Brass 4mm Normally Closed
ICB12SF04NCM1 M12x50mm Nichel Plated Brass 4mm Normally Closed
ICB12SF04NO   M12x50mm Nichel Plated Brass 4mm Normally Open
ICB12SF04NOM1 M12x50mm Nichel Plated Brass 4mm Normally Open
ICB12SF04PC   M12x50mm Nichel Plated Brass 4mm Normally Closed
ICB12SF04PCM1 M12x50mm Nichel Plated Brass 4mm Normally Closed
ICB12SF04PO   M12x50mm Nichel Plated Brass 4mm Normally Open
ICB12SF04POM1 M12x50mm Nichel Plated Brass 4mm Normally Open
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÌìΪ»úµçÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 29412191 / º«ËÉ¿ý
ÊÖ»ú£º 13714766891
µØ Ö·£º ÉîÛÚÊйâÃ÷Çø¹Û¹â·3009ºÅÕÐÉֿ̾Ƽ¼Ô°A4¶°13Â¥1302
ÓÊ ±à£º 518107
Ö÷ Ò³£º https://dayfor.1688.com/
  • VICKERSµ¥Ïò·§CV11-10-P-0-5
  • ÃÀ¹úEATONÒÁ¶Ùµç²ÙBZM3/CD3 AC/DC110V
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX225
  • ÃÀ¹úEATONÒÁ¶ÙËܿǶÏ·Æ÷BZM2C3AX125
  • SCHMERSALÊ©ÂõÈü°²È«¿ª¹ØAZ16-02ZVRK-M16
  • µÂ¹úPILZƤ¶û×Ȱ²È«¿ª¹ØÑÓ³¤ÏßAL-SKP4-2-S370£¨8043760£©
  • acA5472-5gc µÂ¹ú°Í˹ÀÕBasler¹¤ÒµÏà»ú
  • ÈÕ±¾ÈýÑó²½½øµç»ú103H8222-5241
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6SL3210-5FE10-4UA0
  • SIEMENSÎ÷ÃÅ×ÓÄ£¿é6ES7288-3AQ02-0AA0
