Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú PILZ(Ƥ¶û×È)°²È«¼ÌµçÆ÷
²úÆ·Ãû³Æ£º PILZ(Ƥ¶û×È)°²È«¼ÌµçÆ÷
ÐÍ ºÅ£º 773631 773725 773878
773631 PNOZ po3.2p 4n/o  PILZ(Ƥ¶û×È)°²È«¼ÌµçÆ÷,¿â´æ³ä×ã£¬ÌØ¼ÛÈÈÂô£¡
Pilz 773100 PNOZ m1p base unit
Pilz 773631 PNOZ po3.2p 4n/o
773951 PNOZ p1vp 300s
Hermann PilzÓÚ1948ÄêÔڵ¹ú°£Ë¹ÁÖ¸ùÊгÉÁ¢¸Ã¹«Ë¾£¬ÖÂÁ¦ÓÚ²£Á§´µÖÆÒµ¡£ËûΪºóÀ´¶ÀÁ¢´´°ìÖеȹæÄ£µÄ¼Ò×åÆóÒµµÄ³É¹¦µì¶¨ÁË»ù´¡¡£ Hermann PilzÓÐ×Å×Ô¼º¶ÀÌØµÄ¹ÜÀí·½Ê½¡£ÔçÔÚµ±Ê±£¬ÔÚ¹¤³ÌÉÏ£¬±ã¶ÔÔ±¹¤ÊµÐÐÁ˳аüÔðÈÎÖÆ£¬ÔðÈη¶Î§´Óº¸½Óµ½²âÊÔÔÙµ½ÅÉËÍ£¬¹á´©ÓÚ¶ÀÁ¢´¦Àí¹¤×÷ÖеÄÿһ²½»·½Ú¡£
PNOZ X °²È«¼ÌµçÆ÷µÄ¿É¿¿ÐԺͿÉÓÃÐÔÒѾ­µÃµ½ÑéÖ¤¡£ÔÚ¸÷ÖÖ°²È«Ó¦ÓÃÖУ¬¶¼ÄÜÕÒµ½ PNOZ X °²È«¼ÌµçÆ÷¡£Ã¿¸ö°²È«¹¦ÄÜ£¬¶¼Ê¹ÓÃÒ»¸ö PNOZ X¡£Æä¼¼ÊõÌØµãÊÇ»ùÓڼ̵çÆ÷¼¼ÊõÖеÄͨÓõçѹ»úµçʽ´¥µã¡£³ß´ç´Ó 22.5 µ½ 90 mm ²»µÈ£¬´¥µãÊýÁ¿Îª 2 µ½ 8 ¸ö²»µÈ¡£ÎÞÂÛÄúµÄ°²È«ÐèÇóÊÇʲô£¬PNOZ X Ò»¶¨ÊÇÄúÊʺϵĽâ¾ö·½°¸
PILZ(Ƥ¶û×È)¼ÌµçÆ÷²¿·ÖÐͺűíʾÈçÏ£º
Pilz 773050 PNOZmulti Systemhandbuch D
Pilz773105 PNOZ m1p base unit coated version
Pilz773110 PNOZ m0p base unit not expandable
Pilz 773120 PNOZ m2p base unit press function
Pilz 773200 PNOZ pps1p 100-240VAC
Pilz 773300 PNOZ p1p 24VDC 2so
Pilz 773400 PNOZ mi1p 8 input
Pilz 773405 PNOZ mi1p 8 inputs coated version
Pilz 773410 PNOZ mi2p 8 standard input
Pilz 773500 PNOZ mo1p 4 so
Pilz 773505 PNOZ mo1p 4so coated version
Pilz 773510 PNOZ mo3p 2so
Pilz 773520 PNOZ mo2p 2n/o
Pilz 773525 PNOZ mo2p 2n/o coated version
Pilz 773536 PNOZ mo4p 4n/o
Pilz 773537 PNOZ mo4p 4n/o coated version
Pilz 773540 PNOZ ml1p safe link
Pilz 773630 PNOZ po3.1p 8n/o
Pilz 773632 PNOZ po3.3p 3n/o
Pilz 773634 PNOZ po3p 3n/o 1n/c
Pilz 773635 PNOZ po4p 4n/o
Pilz 773700 PNOZ mc1p
Pilz 773705 PNOZ mc1p coated version
Pilz 773720 PNOZ mc0p Powersupply
Pilz 773721 PNOZ mc3p Profibus
Pilz 773722 PNOZ mc4p DeviceNet
Pilz 773723 PNOZ mc5p INTERBUS
Pilz 773724 PNOZ mc6p CANopen
Pilz 773725 PNOZ mc7p CC-Link coated version
Pilz 773726 PNOZ mc7p CC-Link
Pilz 773727 PNOZ mc6p CANopen coated version
Pilz 773728 PNOZ mc5.1p Interbus LWL / Fiberoptic
Pilz 773729 PNOZ mc4p DeviceNet coated version
Pilz 773730 PNOZ mc8p Ethernet IP / Modbus TCP
Pilz 773731 PNOZ mc9p Profinet IO
Pilz 773800 PNOZ ms1p standstill / speed monitor
Pilz 773810 PNOZ ms2p standstill / speed monitor
Pilz 773812 PNOZ ma1p 2 Analog Input
Pilz 773839 PNOZ msi1Bp Adapter Si/Ha 25/25 5m
Pilz 773840 PNOZ msi1Ap Adapter Si/Ha 25/25 2,5m
Pilz 773841 PNOZ msi1Bp Adapter Si/Ha 25/25 2,5m
Pilz 773842 PNOZ msi3Ap Adapter Si/Ha 15/15 2,5m
Pilz 773843 PNOZ msi3Bp Adapter Si/Ha 15/15 2,5m
Pilz 773850 PNOZ msi1p Adapter Si/Ha 25/25 2,5m
Pilz 773844 PNOZ msi1AP Adapter Si/Ha 25/25 5m
Pilz 773854 PNOZ msi10p adapter cable 2,5m
Pilz 773855 PNOZ msi11p adapter cable 1,5m
Pilz 773856 PNOZ msi 9p adapter cable 5m
Pilz 773857 PNOZ msi5p Adapter Bos/Rex 15/15 2,5m
Pilz 773858 PNOZ msi5p Adapter Bosc/Rex 15/15 1,5m
Pilz 773859 PNOZ msi6p Adapter Elau 9/9 7,5m
Pilz 773860 PNOZ msi6p Adapter Elau 9/9 2,5m
Pilz 773861 PNOZ msi6p Adapter Elau 9/9 1,5m
Pilz 773862 PNOZ msi8p Adapter Lenze 9/9 2,5m
Pilz 773863 PNOZ msi8p Adapter Lenze 9/9 1,5m
Pilz 773864 PNOZ msi7p Adapter SEW 15/15 2,5m
Pilz 773865 PNOZ msi7p Adapter SEW 15/15 1,5m
Pilz 773867 PNOZ msi16p ADAPTER Baumuell 15/15 2,5m
773868 PNOZ msi12p Rockwell 15/15 2,5m
773869 PNOZ msi13p Fanuc 20/20 2,5m
773870 PNOZ msi S09
773871 PNOZ msi S15
773872 PNOZ msi S25
773874 PNOZ msi15p Adapter Tendo 15/15 2,5m
773875 PNOZ msi17p Bos/Rex 15/15 4,0m
773878 PNOZ msi14p Leroy 15/15 2,5m
773880 PNOZ msi b1 Box 15p
773881 PNOZ msi b0 cable 15/RJ45
773882 PNOZ msi b1 Box 9p
773883 PNOZ msi b1 Box 25p
773884 PNOZ msi b0 cable 25/RJ45
773890 PNOZ mli1p 5m screw
773891 PNOZ mli1p 10m screw
773892 PNOZ mli1p 50m screw
773893 PNOZ mli1p 5m spring
773894 PNOZ mli1p 10m spring
773895 PNOZ mli1p 50m spring
773900 PNOZ pe1p
773950 PNOZ p1vp 30s
774000 PNOZ 10 24VAC 6n/o 4n/c
774001 PNOZ 10 42VAC 6n/o 4n/c
774002 PNOZ 10 48VAC 6n/o 4n/c
774003 PNOZ 10 110-120VAC 6n/o 4n/c
774006 PNOZ 10 230-240VAC 6n/o 4n/c
774009 PNOZ 10 24VDC 6n/o 4n/c
774012 PNOZ 2VJ 24VDC 3n/o 1n/c 2n/o t
774013 PNOZ 2VQ 24VDC 3n/o 1n/c 2n/o t
774015 PZW 30/110-120VAC 1n/o 2n/c
774017 PZW 30/230VAC 1n/o 2n/c
774019 PZW 30/24VDC 1n/o 2n/c
774020 PZA 300/24VAC 1n/o 2n/c
774021 PZA 300/42VAC 1n/o 2n/c
774023 PZA 300/110-120VAC 1n/o 2n/c
774026 PZA 300/230VAC 1n/o 2n/c
774028 PZA 600/24VDC 1n/o 2n/c
774029 PZA 300/24VDC 1n/o 2n/c
774030 PZA 30/24VDC 1n/o 2n/c
774031 PZA 30/24VAC 1n/o 2n/c
774035 PZA 30/110-120VAC 1n/o 2n/c
774038 PZA 3/230VAC 1n/o 2n/c
774040 PZA 30/230VAC 1n/o 2 n/c
774041 PZA 3/24VDC 1n/o 2n/c
774042 PZW 3/24VDC 1n/o 2n/c
774044 PZW 3/110-120VAC 1n/o 2n/c
774048 PZW 3/230VAC 1n/o 2n/c
774049 PNOZ X7 48VAC 2n/o
774050 PNOZ 15 24VDC 3n/o 1n/o 1n/c
774051 PNOZ X7.1 24VAC/DC 1n/o 1n/c
774053 PNOZ X7 110VAC 2n/o
774054 PNOZ X7 115VAC 2n/o
774055 PNOZ X7 120VAC 2n/o
774056 PNOZ X7 230VAC 2n/o
774057 PNOZ X7 240VAC 2n/o
774058 PNOZ X7 42VAC 2n/o
774059 PNOZ X7 24VACDC 2n/o
774060 PNOZ 16 24VAC 24VDC 2n/o
774061 PNOZ 16 42VAC 24VDC 2n/o
774062 PNOZ 16 48VAC 24VDC 2n/o
774063 PNOZ 16 110VAC 24VDC 2n/o
774064 PNOZ 16 115VAC 24VDC 2n/o
774065 PNOZ 16 120VAC 24VDC 2n/o
774066 PNOZ 16 230VAC 24VDC 2n/o
774067 PNOZ 16 240VAC 24VDC 2n/o
774070 PNOZ 16S 24VAC 24VDC 2n/o 2so
774071 PNOZ 16S 42VAC 24VDC 2n/o 2so
774072 PNOZ 16S 48VAC 24VDC 2n/o 2so
774073 PNOZ 16S 110VAC 24VDC 2n/o 2so
774074 PNOZ 16S 115VAC 24VDC 2n/o 2so
774075 PNOZ 16S 120VAC 24VDC 2n/o 2so
774076 PNOZ 16S 230VAC 24VDC 2n/o 2so
774077 PNOZ 16S 240VAC 24VDC 2n/o 2so
774080 PNOZ 11 24VAC 24VDC 7n/o 1n/c
774081 PNOZ 11 42VAC 24VDC 7n/o 1n/c
774082 PNOZ 11 48VAC 24VDC 7n/o 1n/c
774085 PNOZ 11 110-120VAC 24VDC 7n/o 1n/c
774086 PNOZ 11 230-240VAC 24VDC 7n/o 1n/c
774090 SCHUTZKAPPE P-93 (VE 20 St.)
774100 PNOZ EX 230VAC 3n/o 1n/c
774104 PNOZ EX 115VAC 3n/o 1n/c
774105 PNOZ EX 120VAC 3n/o 1n/c
774106 PNOZ EX 115VAC 3n/o 1n/c FM/USA
774107 PNOZ EX 120VAC 3n/o 1n/c FM/USA
774108 PNOZ EX 230VAC 3n/o 1n/c FM/USA
774120 PNOZ K2.1 24VDC 2n/o Sonderger?t
774125 P2HZ K3 24VDC 2n/o 1n/c Ger?t o. CE
774130 PNOZ e1p 24VDC 2so
774131 PNOZ e1vp 10/24VDC 1so 1so t
774132 PNOZ e1vp 300/24VDC 1so 1so t
774133 PNOZ e1.1p 24VDC 2so
774135 PNOZ e2.2p 24VDC 2so
774136 PNOZ e2.1p 24VDC 2so
774137 PNOZ e3vp 10/24VDC 1so 1so t
774138 PNOZ e3vp 300/24VDC 1so 1so t
774139 PNOZ e3.1p 24VDC 2so
774140 PZE 9 24VAC 8n/o 1n/c
774141 PZE 9 42VAC 8n/o 1n/c
774142 PZE 9 48VAC 8n/o 1n/c
774143 PZE 9 110-120VAC 8n/o 1n/c
774144 PZE 9 120 Vac 8n/o 1n/c
774148 PZE 9 230-240VAC 8n/o 1n/c
774150 PZE 9 24VDC 8n/o 1n/c
774180 PNOZ e4.1p 24VDC 2so
774181 PNOZ e4vp 10/24VDC 1so 1so t
774190 PNOZ e5.11p 24VDC 2so
774191 PNOZ e5.13p 24VDC 2so
774192 PNOZ e6.1p 24VDC 4n/o 2so
774193 PNOZ e6vp 24VDC 4n/o 1so 1so t
774195 Terminal block filter 1
774196 Terminal block filter 2
774300 PNOZ X1 24VAC/DC 3n/o 1n/c
774303 PNOZ X2 24VAC/DC 2n/o
774304 PNOZ X2C 24VAC/DC 2n/o
774305 PNOZ X2.1C 24VAC/DC 2n/o
774306 PNOZ X2.1 24VAC/DC 2n/o
774309 PNOZ X3.2 230VAC 24VDC 3n/o 1n/c 1so
774310 PNOZ X3 24VAC 24VDC 3n/o 1n/c 1so
774311 PNOZ X3 42VAC 24VDC 3n/o 1n/c 1so
774312 PNOZ X3 48VAC 24VDC 3n/o 1n/c 1so
774314 PNOZ X3 110VAC 24VDC 3n/o 1n/c 1so
774315 PNOZ X3 115VAC 24VDC 3n/o 1n/c 1so
774316 PNOZ X3 120VAC 24VDC 3n/o 1n/c 1so
774318 PNOZ X3 230VAC 24VDC 3n/o 1n/c 1so
774319 PNOZ X3 240VAC 24VDC 3n/o 1n/c 1so
774321 PNOZ X3.1 230VAC 24VDC 3n/o 1n/c 1so
774322 PNOZ X3.1 240VAC 24VDC 3n/o 1n/c 1so
774323 PNOZ X5J 24VDC 2n/o
774324 PNOZ X5.1 24VDC 2n/o
774325 PNOZ X5 24VACDC 2n/o
774326 PNOZ X5 12VDC 2n/o
774327 PNOZ X5 12VDC 2n/o coated version
774330 P2HZ X1 24VAC 3n/o 1n/c
774331 P2HZ X1 42VAC 3n/o 1n/c
774332 P2HZ X1 48VAC 3n/o 1n/c
774340 P2HZ X1 24VDC 3n/o 1n/c
774341 P2HZ X1 26VDC 3n/o 1n/c
774345 P2HZ X2 24VAC 2n/o
774350 P2HZ X3 24VDC 2n/o 1n/c
774360 P1HZ X1 24VDC 2n/o
774400 PDZ 24VDC 2n/o 2n/c
774401 PAD/BO 512/6/5VDC
774402 PAD/SI 800/512I/5VDC
774403 PAD/SI 800/1024I/5VDC
774404 PAD/SI 800/2048I/5VDC
774405 PAD/SI 800/4096I/5VDC
774406 PAD/SI 840/512I/5VDC
774407 PAD/SI 840/1024I/5VDC
774408 PAD/SI 840/2048I/5VDC
774409 PAD/SI 840/4096I/5VDC
774410 PAD/SI 800/32I/5VDC
774411 PAD/SI 840/256I/5VDC
774412 PAD/SI 840/128I/5VDC
774413 PAD/SI 840/64I/5VDC
774414 PAD/SI 840/32I/5VDC
774415 PAD/SI 840/16I/5VDC
774420 PDZK WDP3-01 1000/20 24 Vdc
774434 P2HZ X1 110VAC 3n/o 1n/c
774435 P2HZ X1 115VAC 3n/o 1n/c
774436 P2Z X1 120VAC 3n/o 1n/c
774438 P2HZ X1 230VAC 3n/o 1n/c
774439 P2HZ X1 240VAC 3n/o 1n/c
774500 PNOZ XV2 30/24VDC 2n/o 2n/o t
774502 PNOZ XV2 3/24VDC 2n/o 2n/o t
774504 PNOZ XV2 0.5/24VDC 2n/o 2n/o fix
774505 PNOZ XV2 3/24VDC 2n/o 2n/o fix
774506 PNOZ XV2 10/24VDC 2n/o 2n/o fix
774508 PNOZ XV2 300/24VDC 2n/o 2n/o t
774510 PNOZ XV2.1 30/24VAC 24VDC 2n/o 2n/o t
774515 PNOZ XV2.1 30/120VAC 24VDC 2n/o 2n/o t
774516 PNOZ XV2.1 30/230VAC 24VDC 2n/o 2n/o t
774517 PNOZ X2.4V 1/24VDC 4n/o 1so fix
774520 PNOZ XV2.1 3/24VAC 24VDC 2n/o 2n/o t
774524 PNOZ XV2.1 3/115VAC 24VDC 2n/o 2n/o t
774525 PNOZ XV2.1 3/120VAC 24VDC 2n/o 2n/o t
774526 PNOZ XV2.1 3/230VAC 24VDC 2n/o 2n/o t
774530 PNOZ XV3.1 30/24VDC 3n/o 1n/c 2n/o t
774532 PNOZ XV3.1 3/24VDC 3n/o 1n/c 2n/o t
774534 PNOZ XV3.1 0.5/24 Vdc 3n/o 1n/c 2n/o fix
774536 PNOZ XV2.1 0.5/230 Vac 24 Vdc 2n/o 2n/o f
774538 PNOZ XV3.1 300/24VDC 3n/o 1n/c 2n/o t
774540 PNOZ XV3 30/24VDC 3n/o 2n/o t
774541 PNOZ XV3 300/24VAC 3n/o 2n/o t
774542 PNOZ XV3 3/24VDC 3n/o 2n/o t
474591    PNOZ 5 24 V AC 2S
474790    PNOZ V 30 s 24 V DC
474899    PNOZ 6 24 V DC
474908    PNOZ 6 230 V AC
750002    PNOZ s Set screw terminals 12,5mm
750003    PNOZ s Set screw terminals 17,5mm
750004    PNOZ s Set screw terminals 22,5mm
750008    PNOZ s Set1 screw terminals 45mm
750012    PNOZ s Set2 screw terminals 45mm
750020    PNOZ s connector (10 pieces)
750101    PNOZ s1 24VDC 2 n/o
750102    PNOZ s2 24VDC 3 n/o 1 n/c
750103    PNOZ s3 24VDC 2 n/o
750104    PNOZ s4 24VDC 3 n/o 1 n/c
750105    PNOZ s5 24VDC 2 n/o 2 n/o t
750106    PNOZ s6 24VDC 3 n/o 1 n/c
750107    PNOZ s7 24VDC 4 n/o 1 n/c
750108    PNOZ s8 24VDC 2 n/o
750109    PNOZ s9 24VDC 3 n/o t 1 n/c t
750110    PNOZ s10 24VDC 4 n/o 1 n/c
750111    PNOZ s11 24VDC 8 n/o 1 n/c
750124    PNOZ s4.1 24VDC 3 n/o 1 n/c
750126    PNOZ s6.1 24VDC 3 n/o 1 n/c
750134    PNOZ s4 48-240VACDC 3 n/o 1 n/c
750135    PNOZ s5 48-240VACDC 2 n/o 2 n/o t
750136    PNOZ s6 48-240VACDC 3 n/o 1 n/c
750154    PNOZ s4.1 48-240VACDC 3 n/o 1 n/c
750156    PNOZ s6.1 48-240VACDC 3 n/o 1 n/c
750167    PNOZ s7.1 24VDC 3 n/o  cascade
750177    PNOZ s7.2 24VDC 4 n/o 1 n/c expand
751002    PNOZ s Set spring loaded terminals 12,5m
751003    PNOZ s Set spring loaded terminals 17,5m
751004    PNOZ s Set spring loaded terminals 22,5m
751008    PNOZ s Set1spring loaded terminals 45mm
751012    PNOZ s Set2 spring loaded terminals 45mm
751101    PNOZ s1 C 24VDC 2 n/o
751102    PNOZ s2 C 24VDC 3 n/o 1 n/c
751103    PNOZ s3 C 24VDC 2 n/o
751104    PNOZ s4 C 24VDC 3 n/o 1 n/c
751105    PNOZ s5 C 24VDC 2 n/o 2 n/o t
751106    PNOZ s6 C 24VDC 3 n/o 1 n/c
751107    PNOZ s7 C 24VDC 4 n/o 1 n/c
751108    PNOZ s8 C 24VDC 2 n/o
751109    PNOZ s9 C 24VDC 3 n/o t 1 n/c t
751110    PNOZ s10 C 24VDC 4 n/o 1 n/c
751111    PNOZ s11 C 24VDC 8 n/o 1 n/c
751124    PNOZ s4.1 C 24VDC 3 n/o 1 n/c
751126    PNOZ s6.1 C 24VDC 3 n/o 1 n/c
751134    PNOZ s4 C 48-240VACDC 3 n/o 1 n/c
751135    PNOZ s5 C 48-240VACDC 2 n/o 2 n/o t
751136    PNOZ s6 C 48-240VACDC 3 n/o 1 n/c
751154    PNOZ s4.1 C 48-240VACDC 3 n/o 1 n/c
751156    PNOZ s6.1 C 48-240VACDC 3 n/o 1 n/c
751167    PNOZ s7.1 C 24VDC 3 n/o  cascade
751177    PNOZ s7.2 C 24VDC 4 n/o 1 n/c expand
751185    PNOZ s5 C 24VDC 2 n/o 2 n/o t coated
751189    PNOZ s9 C 24VDC 3 n/o  t 1 n/c t coated
772050    PNOZmm0p Starterkit 1
772051    PNOZmm0p Starterkit
774544    PNOZ XV3 0.5/24VDC 3n/o 2n/o t fix
774545    PNOZ XV3 3/24VDC 3n/o 2n/o t fix
774546    PNOZ XV2.1 3/230 Vac/24 Vdc 2n/o 2n/o fix
774547    PNOZ XV3 10/24VDC 3n/o 2n/o t fix
774548    PNOZ XV3 300/24VDC 3n/o 2n/o t
774549    PNOZ X13 24VDC 5n/o 1n/c
774550    PNOZ XV2.1 30/24-240VACDC 2n/o 2n/o t
774552    PNOZ XV2.1 3/24-240VACDC 2n/o 2n/o t
774554    PNOZ XV2.1 0.5/24-240 VacDC 2n/o 2n/o fix
774558    PNOZ XV2.1 300/24-240VACDC 2n/o 2n/o t
774560    PNOZ XHCV 0,7/24VDC 2n/o fix
774600    PNOZ XM1 24VDC 4n/o 1n/c 2so
774601    PNOZ X9 42VAC 24VDC 7n/o 2n/c 2so
774605    PNOZ X9 100-120VAC 24VDC 7n/o 2n/c 2so
774606    PNOZ X9 200-230VAC 24VDC 7n/o 2n/c 2so
774607    PNOZ X2.2 24VAC/DC 2n/o
774608    PNOZ X9 200VAC 24VDC -774606
774609    PNOZ X9 24VAC 24VDC 7n/o 2 n/c 2so
774610    PNOZ XV3.1 30/24-240VACDC 3no 1nc 2no t
774612    PNOZ XV3.1 3/24-240VACDC 3no 1nc 2no t
774618    PNOZ XV3.1 300/24-240VACDC 3no 1nc 2no t
774620    PNOZ XE1 24VDC
774621    PNOZ XE2 24VDC
774700    PNOZ X10 24VAC 6n/o 4n/c 3LED
774701    PNOZ X10 42VAC 6n/o 4n/c 3LED
774703    PNOZ X10 110-120VAC 6n/o 4n/c 3LED
774706    PNOZ X10 230-240VAC 6n/o 4n/c 3LED
774709    PNOZ X10 24VDC 6n/o 4n/c 3LED
774721    PNOZ X6 42VAC 3n/o
774725    PNOZ X6 110-120VAC 3n/o
774726    PNOZ X6 230-240VAC 3n/o
774729    PNOZ X6 24VAC 24VDC 3n/o
774730    PNOZ X4 24VDC 3n/o 1n/c
774731    PNOZ X4 24VAC 3n/o 1n/c
774732    PNOZ X4 24 Vdc 3n/o 1n/c white box
774734    PNOZ X4 110VAC 3n/o 1n/c
774735    PNOZ X4 115VAC 3n/o 1n/c
774736    PNOZ X4 120VAC 3n/o 1n/c
774738    PNOZ X4 230VAC 3n/o 1n/c
774739    PNOZ X4 240VAC 3n/o 1n/c
774740    PNOZ X10.1 24 VAC 6n/o 4n/c 6LED
774741    PNOZ X10.1 42 VAC 6n/o 4n/c 6LED
774745    PNOZ X10.1 110-120VAC 6n/o 4n/c 6LED
774746    PNOZ X10.1 230-240VAC 6n/o 4n/c 6LED
774749    PNOZ X10.1 24VDC 6n/o 4n/c 6LED
774789    PNOZ V 3s 24VDC  3n/o 1n/c 1n/o (t)
774790    PNOZ V 30s 24VDC  3n/o 1n/c 1n/o (t)
774791    PNOZ V 300s 24VDC  3n/o 1n/c 1n/o (t)
775505    PU3Z 120-240VAC 3n/o 1n/c 6so
775510    PU3Z 24VDC 3n/o 1n/c 6so
775600    PNOZ 1 24VAC  3n/o 1n/c
775620    PNOZ 1 48VAC  3n/o 1n/c
775630    PNOZ 1 110-120VAC  3n/o 1n/c
775650    PNOZ 1 230-240VAC  3n/o 1n/c
775695    PNOZ 1 24VDC  3n/o 1n/c
775730    BUCH MASCHINENSICHERHEIT
775735    Buch Maschinensicherheit, spanisch
775800    PNOZ 2 24VAC 3n/o 1n/c
775810    PNOZ 2 42VAC 3n/o 1n/c
775830    PNOZ 2 110VAC 3n/o 1n/c
775850    PNOZ 2 230VAC 3n/o 1n/c
775855    PNOZ 2 240VAC 3n/o 1n/c
777053    PNOZ X7P 110-120VAC 2n/o
777056    PNOZ X7P 230-240VAC 2n/o
777059    PNOZ X7P 24VAC/DC 2n/o
777070    PNOZ 16SP 24VAC 24VDC 2n/o
777071    PNOZ 16SP 42VAC 24VDC 2n/o
777072    PNOZ 16SP 48VAC 24VDC 2n/o
777073    PNOZ 16SP 110VAC 24VDC 2n/o
777074    PNOZ 16SP 115VAC 24VDC 2n/o
777075    PNOZ 16SP 120VAC 24VDC 2n/o
777076    PNOZ 16SP 230VAC 24VDC 2n/o
777077    PNOZ 16SP 240VAC 24VDC 2n/o
777080    PNOZ X11P 24VAC 24VDC 7n/o 1n/c 2so
777083    PNOZ X11P 110-120VAC 24VDC 7n/o 1n/c 2so
777086    PNOZ X11P 230-240VAC 24VDC 7n/o 1n/c 2so
777100    PNOZ X1P 24VDC 3n/o 1n/c
777140    PZE 9P 24VACDC 8n/o 1n/c
777148    PZE 9P 24VACDC 100-240VACDC 8n/o 1n/c
777150    PZE X5P 24VDC 5n/o 2so
777300    PNOZ X2.9P 24VDC 3n/o 1n/c
777301    PNOZ X2.8P 24VACDC 3n/o 1n/c
777302    PNOZ X2.8P 24-240VAC/DC 3n/o 1n/c
777303    PNOZ X2P 24VACDC 2n/o
777304    PNOZ X2.3P 24VACDC 3n/o
777305    PNOZ X2.7P 24VACDC 3n/o 1n/c
777306    PNOZ X2.7P 24-240VAC/DC 3n/o 1n/c
777307    PNOZ X2P 48-240VACDC 2n/o
777308    PNOZ X2.5P 24VDC 2n/o 1so
777310    PNOZ X3P 24VDC 24VAC 3n/o 1n/c 1so
777313    PNOZ X3P  24-240VACDC 3n/o 1n/c 1so
777314    PNOZ X3.10P  24VACDC 3n/o 1n/c 1so
777500    PNOZ XV2P 30/24VDC 2n/o 2n/o t
777502    PNOZ XV2P 3/24VDC 2n/o 2n/o t
777503    PNOZ XV2P 1/24VDC 2n/o 2n/o fix
777504    PNOZ XV2P 0.5/24VDC 2n/o 2n/o fix
777510    PNOZ XV3P 30/24 VDC 3n/o 2n/o t
777511    PNOZ XV3.3P 30/24VDC 3n/o 2n/o t
777512    PNOZ XV3P 3/24 VDC 3n/o 2n/o t
777514    PNOZ XV3P 0.5/24VDC 3n/o 2n/o t fix
777515    PNOZ XV3P 3/24 Vdc 3n/o 2n/o t fix
777517    PNOZ XV3P 10/24 Vdc 3n/o 2n/o t fix
777518    PNOZ XV3P 300/24VDC 3n/o 2n/o t
777520    PNOZ XV3.1P 30/24VDC 3n/o 1n/c 2n/o t
777522    PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t
777525    PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t fix
777530    PNOZ XV3.1P 30/24-240VACDC 3no 1nc 2no t
777532    PNOZ XV3.1P 3/24-240VACDC 3no 1nc 2no t
777538    PNOZ XV3.1P 300/24-240VACDC 3no 1nc 2no
777540    PNOZ XV2.1P 30/24-240VACDC 2n/o 2n/o t
777542    PNOZ XV2.1P 3/24-240VACDC 2n/o 2n/o t
777544    PNOZ XV2.1P 0.5/24-240 VacDC 2n/o 2n/o fi
777545    PNOZ XV2.1P 3/24-240 VacDC 2n/o 2n/o fix
777547    PNOZ XV2.1P 10/24-240 VacDC 2n/o 2n/o fix
777548    PNOZ XV2.1P 300/24-240VACDC 2n/o 2n/o t
777600    PNOZ X2.1VP 0.75/24VDC 1so  2n/o fix
777601    PNOZ XV1P 3/24VDC 2n/o 1n/o t
777602    PNOZ XV1P 30/24VDC 2n/o 1n/o t
777606    PNOZ X9P 24VDC 100-240VACDC 7no 2nc 2so
777607    PNOZ X9P 12VDC 7n/o 2n/c 2so
777609    PNOZ X9P 24VDC 7n/o 2n/c 2so
777750    PNOZ X10.11P 24VDC 6n/o 4n/c 6LED
777760    PNOZ X8P 24 VDC 3n/o 2n/c 2so
777764    PNOZ X8P 110VAC 3n/o 2n/c 2so
777765    PNOZ X8P 115VAC 3n/o 2n/c 2so
777766    PNOZ X8P 120VAC 3n/o 2n/c 2so
777768    PNOZ X8P 230VAC 3n/o 2n/c 2so
777770    PNOZ X8P 24VAC 3n/o 2n/c 2so
779000    PNOZmulti Tool-Kit
779110    PNOZmulti Bus-Terminator
779112    PNOZmulti Bus-Terminator coated
779120    PNOZpower Bus-Terminator
779125    PNOZ pe2p Bus-Interface
779200    PNOZmulti Chipcard Set  10 pieces 8kB
779201    PNOZmulti Chipcard 1 piece 8kB
779208    PNOZmulti chipcard 3 Vestas 1pc 32k
779211    PNOZmulti Chipcard 1 piece 32kB
779212    PNOZmulti Chipcard Set 10 pieces 32kB
779230    Chip Card Reader
779240    PNOZmulti Chipcard Holder (Sparepart)
779250    PNOZmulti Seal 10 pieces
779300    PNOZ mz1
784130    PNOZ e1p C 24VDC 2so
784131    PNOZ e1vp C 10/24VDC 1so 1so t
784132    PNOZ e1vp C 300/24VDC 1so 1so t
784133    PNOZ e1.1p C 24VDC 2so
784135    PNOZ e2.2p C 24VDC 2so
784136    PNOZ e2.1p C 24VDC 2so
784137    PNOZ e3vp C 10/24VDC 1so 1so t
784138    PNOZ e3vp C 300/24VDC 1so 1so t
784139    PNOZ e3.1p C 24VDC 2so
784180    PNOZ e4.1p C 24VDC 2so
784181    PNOZ e4vp C 10/24VDC 1so 1so t
784190    PNOZ e5.11p C 24VDC 2so
784191    PNOZ e5.13p C 24VDC 2so
784192    PNOZ e6.1p C 24VDC 4n/o 2so
784193    PNOZ e6vp C 24VDC 4n/o 1so 1so t
784198    PNOZ e8.1p C 24VDC 2so
787053    PNOZ X7P C 110-120VAC 2n/o
787056    PNOZ X7P C 230-240VAC 2n/o
787059    PNOZ X7P C 24VAC/DC 2n/o
787070    PNOZ 16SP C 24VAC 24VDC 2n/o
787071    PNOZ 16SP C 42VAC 24VDC 2n/o
787072    PNOZ 16SP C 48VAC 24VDC 2n/o
787073    PNOZ 16SP C 110VAC 24VDC 2n/o
787074    PNOZ 16SP C 115VAC 24VDC 2n/o
787075    PNOZ 16SP C 120VAC 24VDC 2n/o
787076    PNOZ 16SP C 230VAC 24VDC 2n/o
787077    PNOZ 16SP C 240VAC 24VDC 2n/o
787080    PNOZ X11P C 24VAC 24VDC 7n/o 1n/c 2so
787083    PNOZ X11P C 110-120VAC 7n/o 1n/c 2so
787086    PNOZ X11P C 230-240VAC 7n/o 1n/c 2so
787100    PNOZ X1P C 24VDC 3n/o 1n/c
787300    PNOZ X2.9P C 24VDC 3n/o 1n/c
787301    PNOZ X2.8P C 24VACDC 3n/o 1n/c
787302    PNOZ X2.8P C 24-240VAC/DC 3n/o 1n/c
787303    PNOZ X2P C 24VACDC 2n/o
787304    PNOZ X2.3P C 24VACDC 3n/o
787305    PNOZ X2.7P C 24VACDC 3n/o 1n/c
787306    PNOZ X2.7P C 24-240VAC/DC 3n/o 1n/c
787307    PNOZ X2P C 48-240VACDC 2n/o
787308    PNOZ X2.5P C 24VDC 2n/o 1so
787310    PNOZ X3P C 24VDC 24VAC 3n/o 1n/c 1so
787313    PNOZ X3P C 24-240VACDC 3n/o 1n/c 1so
787314    PNOZ X3.10P  C 24VACDC 3n/o 1n/c 1so
787500    PNOZ XV2P C 30/24VDC 2n/o 2n/o t
787502    PNOZ XV2P C 3/24VDC 2n/o 2n/o t
787503    PNOZ XV2P C 1/24VDC 2n/o 2n/o fix
787504    PNOZ XV2P C 0.5/24VDC 2n/o 2n/o fix
787510    PNOZ XV3P C 30/24 VDC 3n/o 2n/o t
787511    PNOZ XV3.3P C 30/24VDC 3n/o 2n/o t
787512    PNOZ XV3P C 3/24 VDC 3n/o 2n/o t
787518    PNOZ XV3P C 300/24VDC 3n/o 2n/o t
787520    PNOZ XV3.1P C 30/24VDC 3n/o 1n/c 2n/o t
787522    PNOZ XV3.1P C 3/24VDC 3n/o 1n/c 2n/o t
787530    PNOZ XV3.1P C 30/24-240VACDC 3no 1nc 2no
787532    PNOZ XV3.1P C 3/24-240VACDC 3no 1nc 2no
787538    PNOZ XV3.1P C300/24-240VACDC 3no 1nc 2no
787540    PNOZ XV2.1P C 30/24-240VACDC 2n/o 2n/o t
787542    PNOZ XV2.1P C 3/24-240VACDC 2n/o 2n/o t
787548    PNOZ XV2.1P C 300/24-240VACDC 2n/o 2n/o
787600    PNOZ X2.1VP C 0.75/24VDC 1so  2n/o fix
787601    PNOZ XV1P C 3/24VDC 2n/o 1n/o t
787602    PNOZ XV1P C 30/24VDC 2n/o 1n/o t
787606    PNOZ X9P C 24VDC 100-240VACDC 7no 2nc2so
787609    PNOZ X9P C 24VDC 7n/o 2n/c 2so
787750    PNOZ X10.11P C 24VDC 6n/o 4n/c 6LED
787760    PNOZ X8P C 24 VDC 3n/o 2n/c 2so
787764    PNOZ X8P C 110VAC 3n/o 2n/c 2so
787765    PNOZ X8P C 115VAC 3n/o 2n/c 2so
787766    PNOZ X8P C 120VAC 3n/o 2n/c 2so
787768    PNOZ X8P C 230VAC 3n/o 2n/c 2so
787770    PNOZ X8P C 24VAC 3n/o 2n/c 2so
793300    PNOZ p1p Set plug in screw terminals
793305    PNOZ p1p inverse Set plug in screw term.
793631    PNOZ po3.2p Set plug in screw terminals
305159  374205 777520  774585
ÒÔÉÏΪPILZ(Ƥ¶û×È)¼ÌµçÆ÷µÄ²¿·ÖÐͺţ¬Èç¹ûÄúÓйØÓÚ´Ë·½ÃæµÄ²úÆ·ÐèÇó£¬ÇëËæÊ±ÓëÎÒÃÇÁªÏµ£¬ÎÒÃǽ«½ß³ÏΪÄú·þÎñ¡£
¹«Ë¾Ãû³Æ£º ¸£ÖÝ´¨Äɹ¤Òµ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾
µç »°£º 0591 87985782 / ¿µÉú
ÊÖ»ú£º 13159259028
µØ Ö·£º ¸£ÖÝÊвÖÉ½Çø½¨ÐÂÕò½ðɽ´óµÀ620ºÅ½ðɽ½ÛÔ°ÖÞÉÌס¥AÇø
ÓÊ ±à£º 361000
Ö÷ Ò³£º www.cn-auto.net/fzchuanna.1688.com
  • EF8320G202 ASCOµç´Å·§
  • IDEC(ºÍȪ)¼ÌµçÆ÷
  • ACS350-03E ABB±äƵÆ÷
  • SJ300-110HFE HITACHIÈÕÁ¢±äƵÆ÷
  • NET-35B ̨ÍåÃ÷γµçÔ´
  • MTSÎ»ÒÆ´«¸ÐÆ÷
  • Âí¿ÏÒÀÂêÊ¿(markem)´òÓ¡Í·
  • 35A-AAA-DDCA ÃÀ¹úMACµç´Å·§
  • APM-A3A1F ɽÎäAZBI¿ª¹Ø
  • ËÉÏÂ(Panasonic)PLC£¬±äƵÆ÷
