²úÆ·Ãû³Æ£º
¶à·¹â¿ª¹Ø£¨1¡Á4 1¡Á8 1¡Á16£©
ÐÍ ºÅ£º
SM
Parameters
FY-1×N
Insertion Loss
dB
1<N≤45
45<N≤88
88<N≤128
Typ:0.8 Max:1.0
Typ:1.2 Max:1.5
Typ:1.7 Max:2.0
Wavelength Range
nm
850±40/1300±40
850£¨SM£©
1260~1650
1260~1620£¨SM£©
Test Wavelength
nm
850/1310
850
1310/1550
1310/1490/1550/1625
Return Loss
dB
SM≥50¡¢MM≥30
Crosstalk
dB
SM≥55¡¢MM≥35
PDL
dB
≤0.05
WDL
dB
dB
≤0.25
TDL
dB
≤0.25
Repeatability
dB
≤±0.05
Durability
cycles
≥10 Million
Transmission Power mW
mW
≤500
Switch Time
ms
≤10(Sequence switch time of adjacent channel)
Operating Temperature
°C
-20¡«+70
Storage Temperature
°C
-40¡«+85
Power Supply
V
+5 or 12
Relative Humidity
5¡«+95
Dimension
mm
1<N<4 (135×40×32)
4≤N≤12 (135×64×32)
12<N≤16(184×78×36)
16<N≤45(184×78×66)
N≤<88 (184×156×66)
88≤N≤128(184×220×66)
N≤16(140×77.5×32)
N≤32(140×77.5×64)
Ordering Information
Channel
Mode
Wavelength
Voltage Type
Fiber type
Fiber diameter
Fiber Length
Connector
1~128
S=SM M=MM
85=850nm
13=1310nm
15=1550nm
162= 1625nm
165=1650nm
13/15=1310/1550nm
3=5V
5=12V
5=50/125
6=62.5/125
9=9/125
X= Other
25=250um
90=900um;
20=2.0mm
30=3.0mm
X= Other
05=0.5m
10=1.0m
15=1.5m
X=Other
0=None
1=FC/PC
2=FC/APC
3=SC/PC
4=SC/APC
5=ST/PC
6=ST/APC
7=LC/PC
8=LC/APC
X=Others
Pin Configurations
DB-9 male connector (max.1×16)
Pin No.
Signal Name
I / O
Description
1
D0
Input
TTL, Channel selection bit 0
2
D1
Input
TTL, Channel selection bit 1
3
D2
Input
TTL, Channel selection bit 2
4
D3
Input
TTL, Channel selection bit 3
5
/RESET
Input
TTL, Low level reset to channel 0. High level means channel selection bits are effective.
6
/READY
Output
TTL, Ready (High=Not ready, Low=Ready)
7
ERROR
Output
TTL, Error (High=Error, Low=No error)
8
GND
Input
Ground
9
+5VDC
Input
5.0±5% VDC Power Supply (max 550mA)
