²úÆ·Ãû³Æ£º
eMTϵÁÐÍþÂÚ´¥ÃþÆÁeMT3150AÈË»ú½çÃæ
ÐÍ ºÅ£º
eMT3150A
ÏÔʾ
ÏÔʾÀàÐÍ
15” TFT
·Ö±æÂÊ (WxH dots)
1024 x 768
ÏÔʾÁÁ¶È (cd/m2)
350
¶Ô±È¶È
700:1
±³¹âÀàÐÍ
LED
±³¹âÊÙÃü
50,000 Сʱ
ÏÔʾɫ²Ê
24 bits
´¥¿ØÃæ°å
ÀàÐÍ
4ÏßÄ£Äâµç×èʽ
´¥¿Ø¾«¶È
Active Area Length(X)±2%, Width(Y)±2%
ÄÚ´æ
Flash´¢´æÆ÷ (MB)
256
DRAM (MB)
256
´¦ÀíÆ÷
32Bit RISC CPU 800MHz
ͨѶ²º
SD ¿¨²å²Û
Ö§³ÖSD/SDHC
USB Ö÷É豸
USB 2.0 x 1
Mini USB ÏÂÔØ¿Ú
USB 2.0 x 1
ÒÔÌ«ÍøÂç
10/100 Base-T
COMÁ¬½Ó²º
COM1 (RS-232/RS-485 2W/4W),
COM3(RS-232/RS-485 2W)
CAN Bus
ÓÐ
ÉùÒôÊä³ö
Audio Line Out x 1
Ó°ÏñÊäÈë
NTSC/PAL RCA x 2
ÍòÄêÀú
ÄÚ½¨
µçÔ´
ÊäÈëµçÔ´
24±20%VDC
µçÔ´¹¦ºÄ
900mA@24V
¸ôÀëµçÔ´Æ÷
ÄÚ½¨
ÄÍѹ
500VAC (1 ·ÖÖÓ)
¾øÔµµç×è
³¬¹ý 50MW at 500VDC
¿¹Õð
10 to 25Hz(X,Y,Z ·½Ïò 2G30 ·ÖÖÓ)
¹æ¸ñ
Íâ¿Ç²ÄÖÊ
ÂÁÖÊ
ÍâÐγߴç WxHxD
350 x 277 x57mm
¿ª¿×³ß´ç (mm)
352 x 279
ÖØÁ¿ (kg)
Ô¼ 2.75 kg
²Ù×÷»·¾³
·À»¤µÈ¼¶
IP65 Ç°Ãæ°å·À»¤ (O ÐÎÃÜ·âȦ)
´¢´æ»·¾³Î¶È
-20° ~ 70°C (-4° ~158°F)
ʹÓû·¾³Î¶È
0° ~50°C(32° ~122°F)
ʹÓû·¾³Êª¶È
10% ~ 90% RH (ÎÞÀäÄý)
Å·ÃËCEÈÏÖ¤
·ûºÏ EN 55022: 2006+A1: 2007, Class A
EN6100-3-3:2006
EN61000-3-3:2008
EN 55024: 1998+A1: 2001+A2: 2003
ʹÓÃÈí¼þ
EasyBuilder Pro
