Ô×°ÕýÆ·Tri-tronicsBF-A-36T¹âÏË·Å´óÆ÷
²úÆ·Ïêϸ½éÉÜ
Fiber Optic Light Guides are flexible and robust, making them ideal for harsh environments, and small spaces. They are resistant to high temperature, vibration, condensation and corrosion.
Stainless steel armored cables provide maximum protection against shock and abrasion. The interlocked metal hose is both flexible and strong. However, it is not waterproof, oil tight, or vapor proof.
PVC jacketed monocoil provides ample protection for most industrial applications. It is flat-wound steel spring, forming a crush-proof flexible tube around the glass. PVC monocoil fibers are waterproof, oil tight, crush resistant, and very flexible.
