PK610±à³ÌµçÀÂ
transmitters to a PC on which the PC software V 600 plus resp.
2W2 is installed for purposes of programming the transmitter in
standard or Ex version (if available).
The transmitter can be programmed either with or without the
power supply connected on the SINEAX, SIRAX resp. KINAX.
The connections between
PK 610 ↔ SINEAX, SIRAX or KINAX – as well as the dif-
ferent mounting possibilities, e.g. inside or outside the explosion
danger area – are described in the operating instructions for each
device.
PK610±à³ÌµçÀ¸¨ÖúµçÀÂ
137887
147787
147779
980179
141440
141416
988058
143587
152603
154071
