Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú AZ2700½ø¿ÚÔ­×°¼ÌµçÆ÷ ¿­ÈøÏúÊÛZETTLER
²úÆ·Ãû³Æ£º AZ2700½ø¿ÚÔ­×°¼ÌµçÆ÷ ¿­ÈøÏúÊÛZETTLER
ÐÍ ºÅ£º AZ2700-2A-12D
Type:     Power Relay
DC Coil Voltage:     12 V
Maximum AC Voltage Rating:     400 V
Family:     AZ2700
Relay Construction:     Non-Latching
Contact Material:     Silver Cadmium Oxide
Maximum DC Voltage Rating:     150 V
AC Coil Voltage:     N/A
Coil Current:     160 mA
Packaging:     N/A
Seal:     Unsealed
Termination Style:     0.25Quick Connect
Coil Resistance:     75 Ohm
Contact Arrangement:     DPST-NO-DM
Maximum Current Rating:     30 A
Pin_Count:     6
Maximum Pick-Up Voltage:     9 VDC
Product Weight:     120 g
Minimum Dropout Voltage:     >0.6 VDC
Mounting:     Flange Mount
Contact Form:     2 Form X
Maximum Power Rating:     840,8.31 W|kVA
Operating Temperature:     -40 to 85 °C
Dimension:     68 x 33.5 x 47mm mm
Package Type:     N/A
Operate Time:     30 ms
Coil Suppression Diode:     No
Push to Test Button:     No
Led Indicator:     No
¹«Ë¾Ãû³Æ£º ÉîÛÚ¿­Èøµç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 021 51873582-8012 / ½¹¿Ë¾²
ÊÖ»ú£º 15216705947
µØ Ö·£º ÉϺ£¼Î¶¨Çø½­ÇÅÍò´ï¹ã³¡8ºÅд×ÖÂ¥915ÊÒ
ÓÊ ±à£º 201800
Ö÷ Ò³£º http://www.kisacn.com
  • Ô­×°ÏÖ»õ13AC1 Honeywell ΢¶¯ ¿ì¶¯¿ª¹Ø¿­Èø¾­Óª
  • ¿­ÈøÏÖ»õ¹©Ó¦ZX10C30J01 ½ø¿ÚÔ­×°Honeywell ÏÞλ¿ª¹Ø
  • Ô­×°ÏÖ»õV15T16-CZ200 Honeywell ÏÞλ¿ª¹Ø ¿­Èø´úÀí
  • ½ø¿ÚÔ­×°ÏÖ»õ2NT1-7 Honeywell ²¦¶¯¿ª¹Ø
  • ´úÀíÏúÊÛ ZM90G20F01 È«ÐÂÕýÆ·Honeywell ΢¶¯ ¿ì¶¯¿ª¹Ø
  • ½ø¿ÚÔ­×°ÏÖ»õCT06220 3M µçÀÂÊø´ø ¿­Èø¾­Ïú
  • CTB1X1BKA-C 3M µçÀÂÊø´øÉîÛÚ¿­Èøµç×Ó´úÀíÏúÊÛ
  • ¿­Èøµç×ÓÌØ¼ÛÈÈÂôSJ3550-1 3M µçÀÂÊø´ø
  • ½ø¿ÚÔ­×°CT8NT40-C 3M µçÀÂÊø´ø¿­Èø´óÁ¿ÏúÊÛ
  • CT8BK50-C 3M µçÀÂÊø´ø ¿­Èøµç×Ó½ø¿ÚÔ­×°ÈÈÏú
