Type: Power Relay
DC Coil Voltage: 24 V
Maximum AC Voltage Rating: 400 V
Family: AZ2701
Relay Construction: Non-Latching
Contact Material: Silver Cadmium Oxide
Maximum DC Voltage Rating: 150 V
AC Coil Voltage: N/A
Coil Current: 80 mA
Packaging: N/A
Seal: Unsealed
Termination Style: Quick Connect
Coil Resistance: 300 Ohm
Contact Arrangement: DPST-NO
Maximum Current Rating: 30 A
Pin_Count: 6
Maximum Pick-Up Voltage: 18 VDC
Product Weight: 120 g
Minimum Dropout Voltage: >1.2 VDC
Mounting: N/A
Contact Form: 2 Form A
Maximum Power Rating: 840,8.31 W|kVA
Operating Temperature: -40 to 85 °C
Dimension: 52.5 x 33.5 x 53mm mm
Package Type: N/A
Operate Time: 30 ms
Coil Suppression Diode: No
Push to Test Button: No
Led Indicator: No
