µÂ¹úƤ¶û´Å773400°²È«¼ÌµçÆ÷
PNOZmulti-°²È«ÊäÈë/Êä³öÄ£¿é
¼¼Êõ²ÎÊý:
²úÆ·°æ±¾£º1.0
Åú×¼£ºCE,cULusÈÏÖ¤,TÜV,BG,KOSHA,CCC
Êý×ÖÊäÈëÊýÁ¿£º8
ÊÊÓÃÓÚ¼«¶Ë»·¾³Ìõ¼þµÄ°æ±¾£º±ê×¼
¿í¶È³ß´ç£º22.5mm
¸ß¶È³ß´ç£º94.0mm
Éî¶È³ß´ç£º121.0mm
×ÜÖØ£º138g
¾»ÖØ£º120g
ÒÔÉãÊ϶ÈÒ»±íʾµÄ»·¾³Î¶ȣº0-60¡æ
¸½¼þ£º783400,793400
Ïà¹Ø²úÆ·:
773100 PNOZ m1p base unit
773105 PNOZ m1p base unit coated version
773110 PNOZ m0p base unit not expandable
773120 PNOZ m2p base unit press function
773200 PNOZ pps1p 100-240VAC
773300 PNOZ p1p 24VDC 2so
773400 PNOZ mi1p 8 input
773405 PNOZ mi1p 8 inputs coated version
773410 PNOZ mi2p 8 standard input
773500 PNOZ mo1p 4 so
773505 PNOZ mo1p 4so coated version
773510 PNOZ mo3p 2so
773520 PNOZ mo2p 2n/o
773525 PNOZ mo2p 2n/o coated version
773536 PNOZ mo4p 4n/o
773537 PNOZ mo4p 4n/o coated version
773540 PNOZ ml1p safe link
773630 PNOZ po3.1p 8n/o
773631 PNOZ po3.2p 4n/o
773632 PNOZ po3.3p 3n/o
773634 PNOZ po3p 3n/o 1n/c
773635 PNOZ po4p 4n/o
773700 PNOZ mc1p
773705 PNOZ mc1p coated version
773720 PNOZ mc0p Powersupply
773721 PNOZ mc3p Profibus
773722 PNOZ mc4p DeviceNet
773723 PNOZ mc5p INTERBUS
773724 PNOZ mc6p CANopen
773725 PNOZ mc7p CC-Link coated version
773726 PNOZ mc7p CC-Link
773727 PNOZ mc6p CANopen coated version
773728 PNOZ mc5.1p Interbus LWL / Fiberoptic
773729 PNOZ mc4p DeviceNet coated version
773730 PNOZ mc8p Ethernet IP / Modbus TCP
773731 PNOZ mc9p Profinet IO
773800 PNOZ ms1p standstill / speed monitor
773810 PNOZ ms2p standstill / speed monitor
773812 PNOZ ma1p 2 Analog Input
773839 PNOZ msi1Bp Adapter Si/Ha 25/25 5m
773840 PNOZ msi1Ap Adapter Si/Ha 25/25 2,5m
773841 PNOZ msi1Bp Adapter Si/Ha 25/25 2,5m
773842 PNOZ msi3Ap Adapter Si/Ha 15/15 2,5m
773843 PNOZ msi3Bp Adapter Si/Ha 15/15 2,5m
773850 PNOZ msi1p Adapter Si/Ha 25/25 2,5m
773844 PNOZ msi1AP Adapter Si/Ha 25/25 5m
773854 PNOZ msi10p adapter cable 2,5m
773855 PNOZ msi11p adapter cable 1,5m
773856 PNOZ msi 9p adapter cable 5m
773857 PNOZ msi5p Adapter Bos/Rex 15/15 2,5m
773858 PNOZ msi5p Adapter Bosc/Rex 15/15 1,5m
773859 PNOZ msi6p Adapter Elau 9/9 7,5m
773860 PNOZ msi6p Adapter Elau 9/9 2,5m
773861 PNOZ msi6p Adapter Elau 9/9 1,5m
773862 PNOZ msi8p Adapter Lenze 9/9 2,5m
773863 PNOZ msi8p Adapter Lenze 9/9 1,5m
773864 PNOZ msi7p Adapter SEW 15/15 2,5m
773865 PNOZ msi7p Adapter SEW 15/15 1,5m
773867 PNOZ msi16p ADAPTER Baumuell 15/15 2,5m
773868 PNOZ msi12p Rockwell 15/15 2,5m
773869 PNOZ msi13p Fanuc 20/20 2,5m
773870 PNOZ msi S09
773871 PNOZ msi S15
773872 PNOZ msi S25
773874 PNOZ msi15p Adapter Tendo 15/15 2,5m
773875 PNOZ msi17p Bos/Rex 15/15 4,0m
773878 PNOZ msi14p Leroy 15/15 2,5m
773880 PNOZ msi b1 Box 15p
773881 PNOZ msi b0 cable 15/RJ45
773882 PNOZ msi b1 Box 9p
773883 PNOZ msi b1 Box 25p
773884 PNOZ msi b0 cable 25/RJ45
773890 PNOZ mli1p 5m screw
773891 PNOZ mli1p 10m screw
773892 PNOZ mli1p 50m screw
773893 PNOZ mli1p 5m spring
773894 PNOZ mli1p 10m spring
773895 PNOZ mli1p 50m spring
773900 PNOZ pe1p
773950 PNOZ p1vp 30s
773951 PNOZ p1vp 300s
