Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¹ãºÍͨGSM/GPRS¶þºÏһģ¿éG500-GL
²úÆ·Ãû³Æ£º ¹ãºÍͨGSM/GPRS¶þºÏһģ¿éG500-GL
ÐÍ ºÅ£º G500-GL
»ù±¾ÌØÐÔ  GSM: 850/900/1800/1900MHz
A-GPS/ GPS/BDS/GLONASS ? LCC+LGA: 18.7 x 16.0 x 2.25mm
 Operating temperature: -40¡æ ~ +85¡æ
 Storage Temperature: -45 ¡æ~ +90¡æ
 Operating Voltage: 2.8V~3.6V, Typical 3.3V
AT Command Set: FIBOCOM proprietary AT commands/GSM 07.05/GSM 07.07/GSM 07.10
 TX Power£º 850/900 MHz£º33dBm±2dB 1800/1900 MHz£º30dBm±2dB
 RX Sensitivity£º 850/900MHz: -107.5 dBm 1800/1900MHz: -107.5 dBm ½Ó¿Ú
SIM Card: 1.8V/3.0V x 1
 UART x 4
 ADC x 1
 GPIO
Antenna: GSM £¦ GNSS ÈÏÖ¤
CE-RED/RoHS ? SRRC/NAL/CCC ´«ÊäËÙÂÊ
 Multi-slot class 12
GPRS: Max 85.6Kbps (DL)/85.6Kbps (UL)
 Coding Scheme CS1-CS4 ¹¦ÄÜ
 TCP/UDP/HTTP(S)/FFS/SSL/TLS/PPP/MQTT/ FTP/NTP/PPP/Cell ID/LBS
GNSS
DFOTA
OpenCPU
¹«Ë¾Ãû³Æ£º ÉîÛÚÊв©»¸¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83039550 / Àîºã
ÊÖ»ú£º 13392864818
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÒæÌïÄÏÂ·ÒæÌﻨ԰
ÓÊ ±à£º 518000
Ö÷ Ò³£º http://www.broad-tech.com
  • ÖÐÐË£¨ZTE£©MF833U1 4Gdongle
  • ¹ãºÍͨ4GÄ£¿éL716-CN
  • ÖÐÐË3GÄ£¿éMF206A
  • ÖÐÐËÄÚÖÃ3GÄ£¿é MF206(WCDMA)
  • ¹ãºÍͨG510ÎÞÏßGSMͨÐÅÄ£¿é
  • ¹ãºÍͨSQ808 SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨģ¿éSU806-CN SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨMA510-GLÈýÄ£ÎïÁªÄ£¿é
  • ¹ãºÍͨFM150 5GͨÐÅÄ£¿é
  • N700¹ãºÍͨģ¿éLPWAÄ£¿é
