Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¹ãºÍͨLTE cat4Ä£¿éL610-CN Ä£¿é
²úÆ·Ãû³Æ£º ¹ãºÍͨLTE cat4Ä£¿éL610-CN Ä£¿é
ÐÍ ºÅ£º L610-CN
»ù±¾ÌØÐÔ LTE FDD: Band 1/3/5/8 LTE TDD: Band 34/38/39/40/41 GSM: 900/1800MHz LCC 31x28x2.4mm Operating Temperature: -40¡æ~+85¡æ Storage Temperature: -40¡æ~+85¡æ Operating Voltage: 3.3V~4.3V typical 3.8V AT Command Set: 3GPP TS 27.007 and 27.005, and proprietary FIBOCOM AT commands TX Power GSM900: 32.5 dBm±1dB DCS1800: 29.5dBm±1dB LTE FDD: 23.0dBm±1dB LTE TDD: 23.0dBm±1dB ½Ó¿Ú SIM Card: 1.8V/3.0V USB 2.0 UART I2C PCM/I2S** ADC SDIO** SPI** GPIO Antenna: Main ÈÏÖ¤ CCC*/SRRC*/NAL*/CE*/RoHS* ´«ÊäËÙÂÊ LTE FDD: 10Mbps DL/5Mbps UL LTE TDD: 10Mbps DL/5Mbps UL GPRS: 107Kbps DL/85.6Kbps UL ¹¦ÄÜ MUX: Basic Mode SMS: MO/MT Text and PDU modes HTTP(S)/FTP(S)/TCP(S)/UDP/IPV4/IPV6/MQTT ECM/RNDIS/PPP DFOTA/FOAT VoLTE/TTS/Recording/FFS/BIP/NITZ/NTP/SSL
¹«Ë¾Ãû³Æ£º ÉîÛÚÊв©»¸¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83039550 / Àîºã
ÊÖ»ú£º 13392864818
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÒæÌïÄÏÂ·ÒæÌﻨ԰
ÓÊ ±à£º 518000
Ö÷ Ò³£º http://www.broad-tech.com
  • ÖÐÐË£¨ZTE£©MF833U1 4Gdongle
  • ¹ãºÍͨ4GÄ£¿éL716-CN
  • ÖÐÐË3GÄ£¿éMF206A
  • ÖÐÐËÄÚÖÃ3GÄ£¿é MF206(WCDMA)
  • ¹ãºÍͨG510ÎÞÏßGSMͨÐÅÄ£¿é
  • ¹ãºÍͨSQ808 SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨģ¿éSU806-CN SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨMA510-GLÈýÄ£ÎïÁªÄ£¿é
  • ¹ãºÍͨFM150 5GͨÐÅÄ£¿é
  • N700¹ãºÍͨģ¿éLPWAÄ£¿é
