6ES75184AP000AB0 CPU 1518-4 PN/DP£¬4 MB ³ÌÐò£¬20 MB Êý¾Ý£»1 ns£»¼¯³É 2x PN ½Ó¿Ú£¬2x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75173AP000AB0 CPU 1517-3 PN/DP£¬2 MB ³ÌÐò£¬8 MB Êý¾Ý£»2 ns£»¼¯³É 2x PN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75163AN010AB0 CPU 1516-3 PN/DP£¬1 MB ³ÌÐò£¬5 MB Êý¾Ý£»10 ns £»¼¯³É 2xPN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP ½Ó¿Ú
6ES75152AM010AB0 CPU 1515-2 PN£¬500 KB ³ÌÐò£¬3 MB Êý¾Ý£»30 ns£»¼¯³É 2x PN ½Ó¿Ú,1x ÒÔÌ«Íø½Ó¿Ú
6ES75131AL010AB0 CPU 1513-1 PN£¬300 KB ³ÌÐò£¬1.5 MB Êý¾Ý£»40 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75111AK010AB0 CPU 1511-1 PN£¬150 KB ³ÌÐò£¬1 MB Êý¾Ý£»60 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75121CK000AB0 CPU 1512C-1 PN, 250 KB³ÌÐò£¬1 MBÊý¾Ý£»48 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 32 DI/32 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75111CK000AB0 CPU 1511C-1 PN, 175 KB³ÌÐò£¬1 MBÊý¾Ý£»60 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 16 DI/16 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75121DK010AB0 CPU 1512SP-1 PN£¬200KB ³ÌÐò£¬1 MB Êý¾Ý£»48 ns£»¼¯³É 1x PN ½Ó¿Ú (¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES75101DJ010AB0 CPU 1510SP-1 PN£¬100KB ³ÌÐò£¬750 KB Êý¾Ý£»72 ns£»¼¯³É 1x PN ½Ó¿Ú(¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES76772AA310EB0 CPU 1515SP PC,2 GB RAM,8 GB CFAST£» Ԥװ32λWINDOWS EMBEDDED STANDARD 7 E£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FB0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FK0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ128µãÊÚȨ)
6ES76772AA410FL0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ512µãÊÚȨ)
6ES76772AA410FM0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ2048µãÊÚȨ)
6ES76727AC000YA0 CPU 1507S,VERSION 1.8(1¸ö¸¡µãÊÚȨ), ½öÄÜÔÚSIMATIC IPCÉÏʹÓÃ
6ES78062CD000YA0 S7-1500Èí¼þ¿ØÖÆÆ÷ÓÃODK£¬Ê¹ÓÃC/C++À©Õ¹S7-1500Èí¼þ¿ØÖÆÆ÷µÄ¹¦ÄÜ
6ES71936AR000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×RJ45
6ES71936AF000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×FC¿ìÁ¬Ê½
6ES71936AP000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×SCRJ¹âÏË
6ES75455DA000AB0 S7-1510/1512 SP CPU DPͨÐÅÄ£¿é (RS-485 PROFIBUS-DP)
6ES79548LC020AA0 S7-1200/1500 4M ´æ´¢¿¨
6ES79548LE020AA0 S7-1200/1500 12M ´æ´¢¿¨
6ES79548LF020AA0 S7-1200/1500 24M ´æ´¢¿¨
6ES79548LL020AA0 S7-1200/1500 256M ´æ´¢¿¨
6ES79548LP010AA0 S7-1200/1500 2G ´æ´¢¿¨
6ES79548LT020AA0 S7-1200/1500 32G ´æ´¢¿¨
6ES71555AA000AB0 ET 200MP IM 155-5 PN ST ±ê×¼ÐͽӿÚÄ£¿é
6ES71555AA000AC0 ET 200MP IM 155-5 PN HF ¸ßÐÔÄÜÐͽӿÚÄ£¿é
6ES71555BA000AB0 ET 200MP IM 155-5 DP ST ±ê×¼ÐͽӿÚÄ£¿é
6ES75070RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ AC/DC 120/230 V
6ES75050RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ DC 24/48/60 V
6ES75050KA000AB0 PS£º25 W£¬¶î¶¨ÊäÈëµçѹ DC 24 V
6EP1332-4BA00 PM 1507£º72W£¬ 24 V/3 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6EP1333-4BA00 PM 1507£º192W£¬ 24 V/8 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6ES75325HF000AB0 AQ 8£ºÄ£ÄâÊä³öÄ£¿é£¬¸ßËÙ AQ 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325HD000AB0 AQ 4£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 4x U/I ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325NB000AB0 AQ 2£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75317KF000AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬AI 8x U/I/RTD/TC ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317NF100AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬¸ßËÙ£¬AI 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317QD000AB0 AI 4£ºÄ£ÄâÊä³öÄ£¿é£¬AI 4x U/I/RTD/TC ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75347QE000AB0 AI4/AQ2£ºÄ£ÄâÁ¿ÊäÈë/Êä³öÄ£¿é AI/AO 4x U/I/RTD/TC 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BL000AB0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BL100AA0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BH100AA0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75225FH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 16x 230 VAC/ 1A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 16x 230 VAC/ 2A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¸ßÐÔÄÜ DQ 8x 24VDC/ 2A HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225FF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 8 x 230 VAC/ 2A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 8x 230VAC/ 5A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL000AB0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 32x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL100AA0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬DI 32x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH000AB0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 16x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BH100AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH500AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬Ô´ÐÍ£¬DI 16x 24VDC SRC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211FH000AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 230V AC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75231BL000AA0 DI16/DQ16£ºÊý×ÖÁ¿ÊäÈë/Êä³öÄ£¿é£¬16x 24VDC/16x 24VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75501AA000AB0 TM Count 2 x 24 V£º2ͨµÀ¸ßËÙ¼ÆÊýÆ÷ÓëλÖòɼ¯(ÔöÁ¿ÐͱàÂëÆ÷£¬24VÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75511AB000AB0 TM PosInput 2£¬2ͨµÀ¼ÆÊýÓëλÖòɼ¯(ÔöÁ¿ÐÍ/¾ø¶ÔÖµ±àÂëÆ÷SSI£¬RS422ºÍ5V TTLÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75521AA000AB0 TM Timer DIDQ 16x24V ´øʱ¼ä´Á¡¢¸ßËÙ¼ÆÊý¡¢PWMµÈ¹¦ÄÜ, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75401AB000AA0 PtP RS422/485 ͨѶģ¿é
6ES75411AB000AB0 PtP RS422/485£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75401AD000AA0 PtP RS232ͨѶģ¿é
6ES75411AD000AB0 PtP RS232£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75901BC000AA0 S7-1500 °²×°µ¼¹ì£º2000 mm
6ES75901AJ300AA0 S7-1500 °²×°µ¼¹ì£º830 mm
6ES75901AF300AA0 S7-1500 °²×°µ¼¹ì£º530 mm
6ES75901AE800AA0 S7-1500 °²×°µ¼¹ì£º482 mm
6ES75901AC400AA0 S7-1500 °²×°µ¼¹ì£º245 mm
6ES75901AB600AA0 S7-1500 °²×°µ¼¹ì£º160 mm
6ES75922AX000AA0 ±êÇ©,35mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AX000AA0 ±êÇ©,25mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AM000XB0 35mmÄ£°åÇ°Á¬½ÓÆ÷£¬Âݶ¤ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XB0 35mmÄ£°åÇ°Á¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XA0 25mmÄ£°åÇ°Á¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75905AA000AA0 "ÓÃÓÚÁ¬½ÓPE£¨µØ£©µ½S7-1500°²×°µ¼¹ìµÄ½ÓµØÔª¼þ£¬
¶ÔÓÚ2000mmµÄ°²×°µ¼¹ìÊDZØÐëµÄ ÿ¸ö°ü×°20Ƭ"
6ES75911AA000AA0 S7-1511/13CPUÏÔʾÃæ°å
6ES75911BA000AA0 S7-1515/16/17/18CPUÏÔʾÃæ°å
6ES75908AA000AA0 S7-1500 PS/PM¹©µçÄ£°åÁ¬½ÓÍ·£¬ÄÚº¬10Ƭ
6ES75280AA707AA0 ½Ó¿ÚÄ£¿é(6ES7 155-5AA00-0AB0)Ç°¸Ç°å5Ƭ/°ü
6ES75280AA007AA0 I/OÄ£¿éÇ°¸Ç°å5Ƭ/°ü£¬35mmÄ£°åÊÊÓÃ
6ES75280AA000AA0 I/OÄ£¿éÇ°¸Ç°å5Ƭ/°ü£¬25mmÄ£°åÊÊÓÃ
6ES75900AA000AA0 UÐÍÁ¬½ÓÆ÷,£¬5Ƭ/°ü
6ES75923AA000AA0 ÌøÏߣ¬20Ƭ/°ü
6ES75905CA000AA0 ÆÁ±ÎÌ×¼þ£ºº¬ÆÁ±Î¶Ë×Ó£¬¿ò¼ÜÒÔ¼°24VDC½ÓÏ߶Ë
6ES75905BA000AA0 Ä£ÄâÁ¿/¼¼ÊõÄ£°åרÓÃÆÁ±Î¶Ë×Ó
6ES76772AA300AA0 CPU 1515SP PC,2 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
6ES76772AA400AA0 CPU 1515SP PC,4 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
6ES75111AK024YB5 "• SIMATIC CPU 1511-1 PN
• SIMATIC ´æ´¢¿¨£¬4 MB
• Êý×ÖÁ¿ÊäÈëDI 16 x 24 V DC HF
• Êý×ÖÁ¿Êä³ö DO 16 x 24 V DC/0.5 A ST
• STEP 7 Professional V13, 365ÌìÊÚȨ
• SIMATIC TOP connect
¸ÅÊö
S7-1500 ×Ô¶¯»¯ÏµÍ³¾ßÓÐÄ£¿é»¯µÄ½á¹¹£¬¿É°üº¬×î¶à 32 ¸öÄ£¿é¡£ ËüÓµÓзḻµÄÄ£¿é£¬ÇÒÕâЩģ¿é¾ù¿ÉÒÔ¶ÀÁ¢µØ×éºÏʹÓá£S7-1500 ×Ô¶¯»¯ÏµÍ³Ö§³Öµ¥²ãÅäÖã¬ÆäÖеÄËùÓÐÄ£¿é¾ù°²×°ÔÚÒ»¸ö°²×°µ¼¹ìÉÏ£¨Çë²Î¼ûÊÖ²áÒÔÁ˽âÇ°ÌáÌõ¼þ£©¡£
Ò»¸öϵͳ°üº¬ÏÂÁÐ×é¼þ£º
- ¿ØÖÆÆ÷£º
CPU ¾ßÓв»Í¬ÐÔÄܵȼ¶£¬²¢¾ßÓм¯³É PROFINET ½Ó¿Ú»ò PROFINET ºÍ PROFIBUS ½Ó¿Ú£¬ÓÃÓÚÁ¬½Ó·Ö²¼Ê½ I/O »òÓÃÓÚ±à³ÌÉ豸¡¢²Ù×÷×°Öá¢ÆäËü SIMATIC ¿ØÖÆÆ÷»òµÚÈý·½É豸¼äµÄͨÐÅ¡£
- ÓÃÓÚÊý×ÖÁ¿ºÍÄ£ÄâÁ¿ÊäÈë/Êä³öµÄÐźÅÄ£¿é¡£
- ¹¤ÒÕÄ£¿éÓÃÓÚ¸ßËÙ¼ÆÊý¡¢Î»Öüì²â»ò²âÁ¿µÈ¹¦ÄÜ¡£
- ͨÐÅÄ£¿éºÍͨÐÅ´¦ÀíÆ÷¿Éͨ¹ýͨÐŽӿڽ«¿ØÖÆÆ÷½øÐÐÀ©Õ¹
¸ù¾ÝÒªÇó£¬Ò²¿ÉʹÓÃÏÂÁÐÄ£¿é£º
- ÔÚ CPU Ïò±³°å×ÜÏßµÄÊä³ö¶ÔÓÚËùÓÐÁ¬½ÓµÄÄ£¿éÀ´Ëµ²»¹»³ä·ÖµÄÇé¿öÏ£¬µçÔ´Ä£¿é (PS) ͨ¹ý±³°å×ÜÏßΪ S7-1500 Ä£¿éµÄÄÚ²¿µç·¹©µç¡£
- ÓÃÓÚ½« SIMATIC S7-1500 Á¬½Óµ½ 120/230 VAC µçÔ´µÄ¸ºÔصçÔ´Ä£¿é (PM)¡£
- ½Ó¿ÚÄ£¿éÓÃÓÚÁ¬½Ó»ùÓÚ S7-1500 µÄ·Ö²¼Ê½ I/O¡£
Éè¼Æ
¼òµ¥µÄÉè¼ÆʹµÃ SIMATIC S7-1500 Ê®·ÖÁé»î£¬±ãÓÚά»¤¡£
- ¼¯³É±³°å×ÜÏߣº
¼¯³ÉµÄ±³°å×ÜÏߣ»±³°å×ÜÏß¼¯³ÉÔÚÄ£¿éÉÏ¡£ Ä£¿éͨ¹ý U ÐÎÁ¬½ÓÆ÷ÏàÁ¬£¬×ÜÏßÁ¬½ÓÆ÷²åÔÚÍâ¿ÇµÄ±³Ãæ¡£ ¿ÉÒÔ½ÚÊ¡°²×°Ê±¼ä¡£ ²»¾Ã½«»áÌṩ¾ßÓГÎÞÏìÓ¦ÈȲå°Î”¹¦ÄܵÄÓÐÔ´±³°å¡£
- Ä£¿é×é×°ÔÚ S7-1500 °²×°µ¼¹ìÉÏ£º
¾ßÓи÷ÖÖ³¤¶È£¬°üÀ¨ÇиîÖÁ¶¨³¤µÄÐͺš£ ÓÉÓÚ¾ßÓм¯³Éʽ DIN µ¼¹ì£¬¿ÉÒÔ¿¨×°¹ã·ºµÄ±ê×¼²¿¼þ£¬È總¼Ó¶Ë×Ó¡¢Ð¡ÐͶÏ·Æ÷»òСÐͼ̵çÆ÷¡£
- ÐÔÄÜ¿É¿¿£¬½ÓÏß·½±ã£º
- I/O ÐźÅÊÇͨ¹ýͳһµÄ 40 ÕëÇ°Á¬½ÓÆ÷À´Á¬½ÓµÄ¡£ ÐźÅÄ£¿éºÍÇ°Á¬½ÓÆ÷Ö®¼ä¾ßÓлúе±àÂ룬¿É·ÀÖ¹ÒòÒâÍâµÄ´íÎó²åÈë¶ø¶Ôµç·Ôì³ÉÆÆ»µ¡£
- ΪÁ˶ÔÇ°Á¬½ÓÆ÷½øÐмòµ¥½ÓÏߣ¬¿É½«¸ÃÁ¬½ÓÆ÷ÖÃÓÚ“Ô¤½ÓÏßλÖÔ¡£ ÔÚ´ËλÖÃÉÏ£¬²åÍ·ÉÐδÓëÄ£¿éµç·½Ó´¥¡£ ´ËλÖû¹¿ÉÓÃÓÚÔÚÔËÐйý³ÌÖнøÐиĶ¯¡£ Óû§¿É½èÖúÓÚÇ°¸ÇÄÚ²àµÄÒ»¸öÓ¡ÖƵçÀÂÁ¬½Óͼ½øÐÐÁ¬½Ó¡£
- Ç°Á¬½ÓÆ÷×÷Ϊ´øÂݶ¤ÐͶË×Ó»òÍÆÈëʽ¶Ë×ÓµÄÐͺÅÌṩ¡£ Á½¸öÐͺŶ¼¿ÉÒÔÁ¬½ÓÏßо½ØÃæ»ýΪ 0.252 ~ 1.5 mm2£¨AWG 24 ~ AWG 16£©µÄµ¼Ïß¡£
- ÁíÍ⣬Êý×ÖÁ¿ÐźÅÄ£¿é¿Éͨ¹ý TOP Connect ½øÐÐϵͳ½ÓÏß¡£ ͨ¹ý TOP Connect£¬¿ÉÒÔ¿ìËÙ¶øÇåÎúµØÁ¬½Óµ½ÏÖ³¡µÄ´«¸ÐÆ÷ºÍÖ´ÐÐÆ÷£¬²¢¿ÉÔÚ¿ØÖƹñÖнøÐмò±ã½ÓÏß¡£
- ¶ÔÓÚÄ£ÄâÁ¿Ä£¿é£¬¿ÉÒÔÖ±½ÓÔÚÄ£¿éÉϽøÐÐÆÁ±Î£»ËæÄ£¿éÌṩÁËÒ»¸öÆÁ±ÎÁ¬½ÓÌ×¼þ£¬ÎÞÐ蹤¾ß¼´¿É½øÐа²×°¡£
- ¹¤³§±êÇ©£º
Õë¶Ô S7-1500 µÄÐźÅÄ£¿éÌṩÁ˱êÇ©Ìõ¡£¿ÉʹÓÃһ̨±ê×¼¼¤¹â´òÓ¡»úÀ´´òÓ¡ÕâЩ DIN A4 ±êÇ©Ö½ÉϵıêÇ©¡£ ¿ÉÒÔ´Ó TIA Portal ½øÐÐ×Ô¶¯´òÓ¡£¬¶øÎÞÐèÖØÐÂÊäÈë·ûºÅ»òµØÖ·¡£ ͨ¹ýÕâЩ±êÇ©ÌõµÄÉè¼ÆÐÎʽ£¬¿ÉΪͨµÀ»òÕï¶ÏÏÔʾ 1:1 ·ÖÅä±êÇ©¡£ Èç¹ûÇ°¸Ç´ò¿ª£¬ÔòÕï¶ÏÏÔʾµ½¶Ë×ÓµÄÕâÖÖ 1:1 ·ÖÅä»á±£Áô¡£
- ¿É±äºÍ¿ÉÀ©Õ¹µÄÕ¾ÅäÖãº
- ÐźÅÄ£¿éºÍͨÐÅ´¦ÀíÆ÷¿ÉÒÔ²»ÊÜÏÞÖƵØÒÔÈκη½Ê½Á¬½Ó¡£ ϵͳ¿É×ÔÐÐ×é̬¡£
- ×î´óÅäÖðüÀ¨´øÓÐ 31 ¸öÄ£¿é£¨30 ¸öÄ£¿é + 1 ¸öµçÔ´£©µÄ CPU¡£ ÔÚ CPU Ïò±³°å×ÜÏßµÄÊä³ö¶ÔÓÚËùÓÐÁ¬½ÓµÄÄ£¿éÀ´Ëµ²»¹»³ä·ÖµÄÇé¿öÏ£¬ÐèÒªÓɵçÔ´ (PS) ͨ¹ý±³°å×ÜÏßΪ S7-1500 Ä£¿éµÄÄÚ²¿µç·¹©µç¡£
- ³ß´ç½ô´Õ£º
SIMATIC S7-1500 µÄ³ß´çʹÆäÄܹ»Ë³Àû°²×°µ½ SIMATIC S7-300 »ò ET 200M µÄ¿ÉÓð²×°¿Õ¼äÖС£
- Òƶ¯·óÉ裺
SIMATIC S7-1500 ¼°ÆäÄ£¿é¿ÉÒÔ´¹Ö±ºÍˮƽ°²×°£¬´Ó¶ø¿ÉÒÔ×î¼Ñ·½Ê½°²×°µ½¿ÉÓÿռäÄÚ¡£
I/O Ä£¿é
ÒÔÏÂÄ£¿éÀàÐÍ¿ÉÓÃÓÚ SIMATIC S7-1500/ET 200MP£º
- Êý×ÖÁ¿ÊäÈëÄ£¿é
- Êý×ÖÁ¿Êä³öÄ£¿é
- Êý×ÖÁ¿ÊäÈë/Êä³öÄ£¿é
- Ä£ÄâÁ¿ÊäÈëÄ£¿é
- Ä£Äâ I/O Ä£¿é
- Ä£ÄâÁ¿Êä³öÄ£¿é
- °üÀ¨¸ßËÙ (HS) Ä£ÄâÁ¿Ä£¿é£¬ÎÞÂÛ¼¤»îµÄͨµÀÊýÈçºÎ£¬»ù±¾Ö´ÐÐʱ¼ä¶¼ÊÇ 62.5 µs
- ÓÃÓÚ¼ÆÊýºÍ¶¨Î»µÄ¹¤ÒÕÄ£¿é
- ÓÃÓڵ㵽µãͨÐźÍ×ÜÏßÁ¬½ÓµÄͨÐÅÄ£¿é
- ²»¾Ã½«¿É¹©»õ ÓÃÓÚÃæÏò°²È«µÄÓ¦ÓõĹÊÕÏ°²È«Ä£¿é
ÌṩÁ˸÷ÖÖÄ£¿éµÈ¼¶£¬¿ÉʹÓû§ÔÚÆäÓ¦ÓÃÖÐʵÏÖ×î¼ÑÀ©Õ¹¡£ Ä£¿é±¾Éíͨ¹ý±êÇ©½øÐÐÏàÓ¦±ê¼Ç£º
- BA£¨»ù±¾ÐÍ£©£º ¼òÒ׵ͳɱ¾Ä£¿é£¬ÎÞÕï¶Ï¹¦ÄÜ£¬Ã»ÓвÎÊý
- ST£¨±ê×¼ÐÍ£©£º ¾ßÓÐÓëÄ£¿é»ò¸ºÔØ×éÏà¹ØµÄÕï¶ÏµÄÄ£¿é£¬Èç¹ûÊÊÓ㬴øÓвÎÊý£»Ä£ÄâÁ¿Ä£¿é£º ׼ȷ¶ÈµÈ¼¶ 0.3%
- HF£¨¸ßÐÔÄÜÐÍ£©£º ¾ßÓÐÓëͨµÀÏà¹ØµÄÕï¶ÏºÍ²ÎÊýÉèÖõÄÄ£¿é£»¶ÔÓÚÄ£ÄâÁ¿Ä£¿é£º ׼ȷ¶ÈµÈ¼¶ 0.1%£¬¿¹ÈŶȺ͵çÁ÷¸ôÀë³Ì¶ÈÌá¸ß
- HS£¨¸ßËÙÐÍ£©£º¾ßÓ쫶ËÂ˲¨ºÍת»»Ê±¼äµÄÄ£¿éÊÊÓÃÓÚ³¬¸ßËÙÓ¦Óã»ÀýÈç 8 ͨµÀÄ£ÄâÁ¿Ä£¿é£¬ÎÞÂÛ¼¤»îµÄͨµÀÊýÈçºÎ£¬»ù±¾Ö´ÐÐʱ¼ä¶¼ÊÇ 62.5 µs¡£
I/O Ä£¿éµÄ¸½¼þ£º
- ±êÇ©Ö½£º
¿É²åÈëµ½ I/O Ä£¿éÖУ¨10 ÕÅ DIN A4 ±êÇ©Ö½£¬Ã¿ÕűêÇ©Ö½´øÓÐ 10 ¸ö±êÇ©£¬Ô¤´©¿×£¬¿ÉʹÓñê×¼¼¤¹â´òÓ¡»ú½øÐдòÓ¡£»¿ÉÓÃÑÕÉ«£º Al »Ò£©
- ÆÁ±ÎÁ¬½Ó£º
SIMATIC S7-1500 ϵͳ£¨Ä£ÄâÁ¿Ä£¿éºÍ¹¤ÒÕÄ£¿é£©ÌṩÁËÒ»¸ö¼òÒ×ÆÁ±ÎÁ¬½ÓÌ×¼þ£¬ÎÞÐèʹÓù¤¾ß¼´¿É°²×°¡£ ´ËÌ×¼þ°üº¬Ò»¸ö 24 V DC À¡µçÔª¼þ¡¢Ò»¸öÆÁ±Î¼ÐºÍÒ»¸öͨÓÃÆÁ±Î¶Ë×Ó¡£ ¸ÃÆÁ±Î¶Ë×Ó¿ÉÓÃÓÚµ¥¸ùϸ¸ÉÏßµçÀ¡¢¶à¸ùϸ¸ÉÏßµçÀ»òÒ»¸ù´Ö¸ÉÏßµçÀ¡£ ÓÉÓÚ¶Ô 24 V DC µçÔ´ºÍ²âÁ¿ÐźŽøÐзÖÀ룬²¢ÇÒÔÚÆÁ±ÎºÍÐźŵçÀÂÖ®¼ä¾ßÓеÍ×迹Á¬½Ó£¬Òò´Ë¿ÉÈ·±£½Ï¸ßµÄ EMC Îȶ¨ÐԺͿ¹¸ÉÈÅÐÔ¡£
- ͳһµÄ 40 ÕëÇ°Á¬½ÓÆ÷
- I/O Ä£¿éµÄÇ°ÃÅ»ò×Ô×é×°±³°å×ÜÏßµÄ U ÐÍÁ¬½ÓÆ÷µÈÆäËü¸½¼þ
ͨÐÅ
