¡¢ 6ES75184AP000AB0 CPU 1518-4 PN/DP£¬4 MB ³ÌÐò£¬20 MB Êý¾Ý£»1 ns£»¼¯³É 2x PN ½Ó¿Ú£¬2x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75173AP000AB0 CPU 1517-3 PN/DP£¬2 MB ³ÌÐò£¬8 MB Êý¾Ý£»2 ns£»¼¯³É 2x PN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75163AN010AB0 CPU 1516-3 PN/DP£¬1 MB ³ÌÐò£¬5 MB Êý¾Ý£»10 ns £»¼¯³É 2xPN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP ½Ó¿Ú
6ES75152AM010AB0 CPU 1515-2 PN£¬500 KB ³ÌÐò£¬3 MB Êý¾Ý£»30 ns£»¼¯³É 2x PN ½Ó¿Ú,1x ÒÔÌ«Íø½Ó¿Ú
6ES75131AL010AB0 CPU 1513-1 PN£¬300 KB ³ÌÐò£¬1.5 MB Êý¾Ý£»40 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75111AK010AB0 CPU 1511-1 PN£¬150 KB ³ÌÐò£¬1 MB Êý¾Ý£»60 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75121CK000AB0 CPU 1512C-1 PN, 250 KB³ÌÐò£¬1 MBÊý¾Ý£»48 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 32 DI/32 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75111CK000AB0 CPU 1511C-1 PN, 175 KB³ÌÐò£¬1 MBÊý¾Ý£»60 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 16 DI/16 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75121DK010AB0 CPU 1512SP-1 PN£¬200KB ³ÌÐò£¬1 MB Êý¾Ý£»48 ns£»¼¯³É 1x PN ½Ó¿Ú (¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES75101DJ010AB0 CPU 1510SP-1 PN£¬100KB ³ÌÐò£¬750 KB Êý¾Ý£»72 ns£»¼¯³É 1x PN ½Ó¿Ú(¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES76772AA310EB0 CPU 1515SP PC,2 GB RAM,8 GB CFAST£» Ԥװ32λWINDOWS EMBEDDED STANDARD 7 E£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FB0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FK0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ128µãÊÚȨ)
6ES76772AA410FL0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ512µãÊÚȨ)
6ES76772AA410FM0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ2048µãÊÚȨ)
6ES76727AC000YA0 CPU 1507S,VERSION 1.8(1¸ö¸¡µãÊÚȨ), ½öÄÜÔÚSIMATIC IPCÉÏʹÓÃ
6ES78062CD000YA0 S7-1500Èí¼þ¿ØÖÆÆ÷ÓÃODK£¬Ê¹ÓÃC/C++À©Õ¹S7-1500Èí¼þ¿ØÖÆÆ÷µÄ¹¦ÄÜ
6ES71936AR000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×RJ45
6ES71936AF000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×FC¿ìÁ¬Ê½
6ES71936AP000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×SCRJ¹âÏË
6ES75455DA000AB0 S7-1510/1512 SP CPU DPͨÐÅÄ£¿é (RS-485 PROFIBUS-DP)
6ES79548LC020AA0 S7-1200/1500 4M ´æ´¢¿¨
6ES79548LE020AA0 S7-1200/1500 12M ´æ´¢¿¨
6ES79548LF020AA0 S7-1200/1500 24M ´æ´¢¿¨
6ES79548LL020AA0 S7-1200/1500 256M ´æ´¢¿¨
6ES79548LP010AA0 S7-1200/1500 2G ´æ´¢¿¨
6ES79548LT020AA0 S7-1200/1500 32G ´æ´¢¿¨
6ES71555AA000AB0 ET 200MP IM 155-5 PN ST ±ê×¼ÐͽӿÚÄ£¿é
6ES71555AA000AC0 ET 200MP IM 155-5 PN HF ¸ßÐÔÄÜÐͽӿÚÄ£¿é
6ES71555BA000AB0 ET 200MP IM 155-5 DP ST ±ê×¼ÐͽӿÚÄ£¿é
6ES75070RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ AC/DC 120/230 V
6ES75050RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ DC 24/48/60 V
6ES75050KA000AB0 PS£º25 W£¬¶î¶¨ÊäÈëµçѹ DC 24 V
6EP1332-4BA00 PM 1507£º72W£¬ 24 V/3 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6EP1333-4BA00 PM 1507£º192W£¬ 24 V/8 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6ES75325HF000AB0 AQ 8£ºÄ£ÄâÊä³öÄ£¿é£¬¸ßËÙ AQ 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325HD000AB0 AQ 4£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 4x U/I ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325NB000AB0 AQ 2£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75317KF000AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬AI 8x U/I/RTD/TC ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317NF100AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬¸ßËÙ£¬AI 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317QD000AB0 AI 4£ºÄ£ÄâÊä³öÄ£¿é£¬AI 4x U/I/RTD/TC ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75347QE000AB0 AI4/AQ2£ºÄ£ÄâÁ¿ÊäÈë/Êä³öÄ£¿é AI/AO 4x U/I/RTD/TC 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BL000AB0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BL100AA0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BH100AA0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75225FH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 16x 230 VAC/ 1A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 16x 230 VAC/ 2A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¸ßÐÔÄÜ DQ 8x 24VDC/ 2A HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225FF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 8 x 230 VAC/ 2A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 8x 230VAC/ 5A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL000AB0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 32x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL100AA0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬DI 32x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH000AB0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 16x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BH100AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH500AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬Ô´ÐÍ£¬DI 16x 24VDC SRC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211FH000AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 230V AC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75231BL000AA0 DI16/DQ16£ºÊý×ÖÁ¿ÊäÈë/Êä³öÄ£¿é£¬16x 24VDC/16x 24VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75501AA000AB0 TM Count 2 x 24 V£º2ͨµÀ¸ßËÙ¼ÆÊýÆ÷ÓëλÖòɼ¯(ÔöÁ¿ÐͱàÂëÆ÷£¬24VÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75511AB000AB0 TM PosInput 2£¬2ͨµÀ¼ÆÊýÓëλÖòɼ¯(ÔöÁ¿ÐÍ/¾ø¶ÔÖµ±àÂëÆ÷SSI£¬RS422ºÍ5V TTLÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75521AA000AB0 TM Timer DIDQ 16x24V ´øÊ±¼ä´Á¡¢¸ßËÙ¼ÆÊý¡¢PWMµÈ¹¦ÄÜ, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75401AB000AA0 PtP RS422/485 ͨѶģ¿é
6ES75411AB000AB0 PtP RS422/485£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75401AD000AA0 PtP RS232ͨѶģ¿é
6ES75411AD000AB0 PtP RS232£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75901BC000AA0 S7-1500 °²×°µ¼¹ì£º2000 mm
6ES75901AJ300AA0 S7-1500 °²×°µ¼¹ì£º830 mm
6ES75901AF300AA0 S7-1500 °²×°µ¼¹ì£º530 mm
6ES75901AE800AA0 S7-1500 °²×°µ¼¹ì£º482 mm
6ES75901AC400AA0 S7-1500 °²×°µ¼¹ì£º245 mm
6ES75901AB600AA0 S7-1500 °²×°µ¼¹ì£º160 mm
6ES75922AX000AA0 ±êÇ©,35mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AX000AA0 ±êÇ©,25mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬Âݶ¤ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XA0 25mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75905AA000AA0 "ÓÃÓÚÁ¬½ÓPE£¨µØ£©µ½S7-1500°²×°µ¼¹ìµÄ½ÓµØÔª¼þ£¬
¶ÔÓÚ2000mmµÄ°²×°µ¼¹ìÊDZØÐëµÄ ÿ¸ö°ü×°20Ƭ"
6ES75911AA000AA0 S7-1511/13CPUÏÔÊ¾Ãæ°å
6ES75911BA000AA0 S7-1515/16/17/18CPUÏÔÊ¾Ãæ°å
6ES75908AA000AA0 S7-1500 PS/PM¹©µçÄ£°åÁ¬½ÓÍ·£¬ÄÚº¬10Ƭ
6ES75280AA707AA0 ½Ó¿ÚÄ£¿é(6ES7 155-5AA00-0AB0)ǰ¸Ç°å5Ƭ/°ü
6ES75280AA007AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬35mmÄ£°åÊÊÓÃ
6ES75280AA000AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬25mmÄ£°åÊÊÓÃ
6ES75900AA000AA0 UÐÍÁ¬½ÓÆ÷,£¬5Ƭ/°ü
6ES75923AA000AA0 ÌøÏߣ¬20Ƭ/°ü
6ES75905CA000AA0 ÆÁ±ÎÌ×¼þ£ºº¬ÆÁ±Î¶Ë×Ó£¬¿ò¼ÜÒÔ¼°24VDC½ÓÏß¶Ë
6ES75905BA000AA0 Ä£ÄâÁ¿/¼¼ÊõÄ£°åרÓÃÆÁ±Î¶Ë×Ó
6ES76772AA300AA0 CPU 1515SP PC,2 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
6ES76772AA400AA0 CPU 1515SP PC,4 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
S7-1500 ¾ßÓв»Í¬µÄͨÐŽӿڣº
- PROFINET IO IRT ½Ó¿Ú£¨2 ¶Ë¿Ú½»»»»ú£©£¬¼¯³ÉÔÚ CPU ÖУ»
ÓÃÓÚ»ñµÃÈ·¶¨µÄÏìӦʱ¼äºÍ¸ßÉ豸¾«¶È¡£
- ÓÃÓÚÁ¬½Óµ½ PROFIBUS ºÍ¹¤ÒµÒÔÌ«Íø×ÜÏßϵͳµÄͨÐÅÄ£¿é£¨²»¾ÃÌṩ PROFINET£©
- ÓÃÓڵ㵽µãÁ¬½ÓµÄͨѶģ¿é¡£
CPU 1515 PN ¾ßÓÐÒ»¸ö¸½¼ÓµÄ¼¯³É PROFINET ½Ó¿Ú£¬Æä¾ßÓе¥¶ÀµÄ IP µØÖ·£¬ÀýÈ磬ÓÃÓÚÍøÂç·ÖÀë¡£ ¶ÔÓÚ CPU 1516-3 PN/DP£¬¿Éͨ¹ý¸Ã¼¯³É PROFIBUS ½Ó¿ÚÀ´Á¬½Ó PROFIBUS ½Úµã¡£ ͨ¹ýÒ»¸ö PROFIBUS CM£¬¿É·½±ãµØ¶Ô²»´ø¼¯³É PROFIBUS ½Ó¿ÚµÄ CPU ½øÐÐÀ©Õ¹¡£
ͨ¹ý PROFINET IO ½øÐйý³ÌͨÐÅ
SIMATIC S7-1500 ͨ¹ý¼¯³ÉµÄ PROFINET ½Ó¿ÚÁ¬½Óµ½ PROFINET IO ×ÜÏßϵͳ£¬¿ÉʵÏÖ¾ßÓÐÈ·¶¨ÏìӦʱ¼äºÍ¸ß¾«¶ÈÉ豸ÐÔÄܵķֲ¼Ê½×Ô¶¯»¯ÅäÖá£
´ÓÓû§µÄ½Ç¶ÈÀ´¿´£¬PROFINET IO Éϵķֲ¼Ê½ I/O ´¦ÀíÓ뼯ÖÐʽ I/O ´¦ÀíûÓÐÇø±ð£¨ÏàͬµÄ×é̬£¬±àÖ·¼°±à³Ì£©¡£
¿É½«ÏÂÁÐÉ豸×÷Ϊ IO ¿ØÖÆÆ÷½øÐÐÁ¬½Ó£º
- SIMATIC S7-1500
- SIMATIC S7-1200
- SIMATIC S7-300£¨Ê¹ÓÃÅ䱸 PROFINET ½Ó¿Ú»ò PROFINET CP µÄ CPU£©
- SIMATIC S7-400£¨Ê¹ÓÃÅ䱸 PROFINET ½Ó¿Ú»ò PROFINET CP µÄ CPU£©
- SIMATIC ET 200£¨Í¨¹ý´øÓÐ PROFINET ½Ó¿ÚµÄ CPU£©
ÒÔÏÂÉ豸¿É×÷ΪÆÕͨÉ豸»òÖÇÄÜÉ豸À´Á¬½Ó£º
- SIMATIC S7-1500
- SIMATIC S7-1200£¨FW 4.0 »ò¸ü¸ß°æ±¾£©
- ET 200S IM151-8 PN/DP CPU, ET 200pro IM154-8 PN/DP CPU
- ET 200SP CPU 1510SP-1 PN¡¢CPU 1512SP-1 PN
- ET 200 ·Ö²¼Ê½ I/O É豸
- ×÷Ϊֱ½Ó°´¼üÄ£¿éÔËÐеÄÈË»ú½çÃæÉ豸
- ÏÖ³¡É豸
PROFIBUS DP ½øÐйý³ÌͨÐÅ
SIMATIC S7-1500 ͨ¹ýͨÐÅ´¦ÀíÆ÷»òͨ¹ýÅ䱸¼¯³É PROFIBUS DP ½Ó¿ÚµÄ CPU Á¬½Óµ½ PROFIBUS DP ×ÜÏßϵͳ¡£ ͨ¹ý´øÓÐ PROFIBUS DP ½Ó¿ÚµÄ CPU »òͨѶģ¿é,¿É¹¹½¨Ò»¸ö¸ßËٵķֲ¼Ê½×Ô¶¯»¯ÏµÍ³£¬²¢ÇÒʹµÃ²Ù×÷´ó´ó¼ò»¯¡£
´ÓÓû§µÄ½Ç¶ÈÀ´¿´£¬PROFIBUS DP Éϵķֲ¼Ê½I/O´¦ÀíÓ뼯ÖÐʽI/O´¦ÀíûÓÐÇø±ð£¨ÏàͬµÄ×é̬£¬±àÖ·¼°±à³Ì£©¡£
ÒÔÏÂÉ豸¿É×÷ΪÖ÷Õ¾Á¬½Ó£º
- SIMATIC S7-1500
£¨Í¨¹ý´ø PROFIBUS DP ½Ó¿Ú»ò PROFIBUS DP ͨÐÅÄ£¿éµÄ CPU£©
- SIMATIC S7-300
(ʹÓôø PROFIBUS DP ½Ó¿ÚµÄ CPU »ò PROFIBUS DP CP)
- SIMATIC S7-400
- SIMATIC S5-115U/H¡¢S5-135U ºÍ S5-155U/H£¬´øIM 308
- SIMATIC 505
ÒÔÏÂÉ豸¿É×÷ΪÆÕͨ´ÓÕ¾»òÖÇÄÜ´ÓÕ¾À´Á¬½Ó£º
- ·Ö²¼Ê½ I/O É豸£¬ÀýÈç ET 200
- ÏÖ³¡É豸
- SIMATIC S7-200¡¢S7-1200¡¢S7-300
- C7-633/P DP, C7-633 DP, C7-634/P DP, C7-634 DP, C7-626 DP
- SIMATIC S7-400 (Ö»ÓÐͨ¹ý CP 443-5)
- SIMATIC S7-1500£¨Ö»ÄÜͨ¹ý CP/CM 1542-5£©
²»¹ý£¬°²×°ÓÐ STEP 7 µÄ±à³ÌÆ÷/PC »ò SIMATIC HMI Ãæ°å½öʹÓò¿·Öͨ¹ý PROFIBUS DP ÔËÐÐµÄ PG ºÍ OP ¹¦ÄÜ¡£
ͨ¹ýÒÔÌ«ÍøµÄÊý¾ÝͨÐÅ
S7-1500 ¿Éͨ¹ý¼¯³É PROFINET ½Ó¿Ú»òͨ¹ýͨÐÅÄ£¿éÁ¬½Óµ½¹¤ÒµÒÔÌ«Íø×ÜÏßϵͳ¡£ ¿ÉÒÔÁ¬½ÓÒÔÏÂÉ豸£º
- SIMATIC S7-1200
- SIMATIC S7-1500
- SIMATIC S7-300
- SIMATIC S7-400
- ±à³ÌÆ÷
- PC¡¢¹¤Òµ PC
- SIMATIC HMI ²Ù×÷Ô±¿ØÖƺͼàÊÓϵͳ
±¸¼þ·þÎñ
»ÎÒÃÇÀûÓÃÎ÷ÃÅ×ÓÈ«ÇòÍøÂçÒÔ¼°ÓÅ»¯µÄÎïÁ÷Á´À´Ìṩ¸ßÖÊÁ¿µÄÔ³§±¸¼þ£¬ÒÔ¼°°´ÕÕÌØ¶¨ÐèÒªÉè¼ÆµÄ±¸¼þ°ü£¬°ïÖúÄúÌá¸ßÉ豸ºÍϵͳÔËÐеĿɿ¿ÐÔ£¬×î´óÏ޶ȵؽµµÍÍ£¹¤Í£²úËù´øÀ´µÄËðʧ¡£«
ÔÚµ±½ñÊÀ½ç£¬ËùÓеÄÐÐÒµ¶ÔÓÚÉ豸ºÍϵͳÔËÐеĿɿ¿ÐÔÒªÇóÔ½À´Ô½¸ß¡£Éú²ú¹ý³ÌÖÐÈôȱÉÙÖØÒª±¸¼þ£¬¿ÉÄܻᵼÖ¾޴óµÄ¾¼ÃËðʧ¡£
Î÷ÃÅ×ÓÔ³§±¸¼þ²úÆ·£¬ÊÇÒÀ¾Ý¹¤ÒµÁìÓòÉ豸ʹÓÃÒªÇó¶øÉè¼ÆµÄ£¬¾ßÓм«¸ßµÄÔËÐпɿ¿ÐÔ¡£
ʹÓÃÎ÷ÃÅ×ÓÔ×°±¸¼þ£¬½«±£ÕÏÄúÏÖÓлúÆ÷ºÍÉ豸ÖÐËùÓÐϵͳ×é¼þµÄ˳Àûе÷ÔËת¡£
¼´Ê¹ÔÚ²úÆ·ºÍϵͳֹͣÊг¡¹©Ó¦ºóµÄÊ®ÄêÄÚ£¬ÎÒÃÇÈÔÈ»¼ÌÐøÌṩÏà¹Ø±¸¼þ£¬×î´ó³Ì¶ÈÈ·±£ÄúµÄÉú²úºÍ»ñÒæ¡£
Î÷ÃÅ×Ó±¸¼þ·þÎñ£¬ÎªÄúÌṩ£º
Ò»Ìì24Сʱ¡¢Ò»Äê365ÌìµÄÈ«Ììºò±¸¼þ¹©Ó¦£»È«Çò»¯ÎïÁ÷ÍøÂ磬ʵÏÖ¿ìËÙ½»¸¶£»³¤ÆÚ±¸¼þ±£ÕÏ(³¤´ï10Äê)£¬½µµÍ¿Í»§¶Ë±¸¼þ´¢±¸£»Ô³§±¸¼þ£¬±£ÕÏÓëÏÖÓÐϵͳµÄ×î¼Ñ¼æÈÝ£»Ë𻵱¸¼þÕÛ¼Û·µ»¹»úÖÆ£¬ÓÅ»¯¿Í»§Í¶×Ê¡£
