S7-1500 °²×°µ¼¹ì£º2000 mm
6ES75184AP000AB0 CPU 1518-4 PN/DP£¬4 MB ³ÌÐò£¬20 MB Êý¾Ý£»1 ns£»¼¯³É 2x PN ½Ó¿Ú£¬2x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75173AP000AB0 CPU 1517-3 PN/DP£¬2 MB ³ÌÐò£¬8 MB Êý¾Ý£»2 ns£»¼¯³É 2x PN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75163AN010AB0 CPU 1516-3 PN/DP£¬1 MB ³ÌÐò£¬5 MB Êý¾Ý£»10 ns £»¼¯³É 2xPN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP ½Ó¿Ú
6ES75152AM010AB0 CPU 1515-2 PN£¬500 KB ³ÌÐò£¬3 MB Êý¾Ý£»30 ns£»¼¯³É 2x PN ½Ó¿Ú,1x ÒÔÌ«Íø½Ó¿Ú
6ES75131AL010AB0 CPU 1513-1 PN£¬300 KB ³ÌÐò£¬1.5 MB Êý¾Ý£»40 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75111AK010AB0 CPU 1511-1 PN£¬150 KB ³ÌÐò£¬1 MB Êý¾Ý£»60 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75121CK000AB0 CPU 1512C-1 PN, 250 KB³ÌÐò£¬1 MBÊý¾Ý£»48 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 32 DI/32 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75111CK000AB0 CPU 1511C-1 PN, 175 KB³ÌÐò£¬1 MBÊý¾Ý£»60 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 16 DI/16 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75121DK010AB0 CPU 1512SP-1 PN£¬200KB ³ÌÐò£¬1 MB Êý¾Ý£»48 ns£»¼¯³É 1x PN ½Ó¿Ú (¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES75101DJ010AB0 CPU 1510SP-1 PN£¬100KB ³ÌÐò£¬750 KB Êý¾Ý£»72 ns£»¼¯³É 1x PN ½Ó¿Ú(¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES76772AA310EB0 CPU 1515SP PC,2 GB RAM,8 GB CFAST£» Ԥװ32λWINDOWS EMBEDDED STANDARD 7 E£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FB0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FK0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ128µãÊÚȨ)
6ES76772AA410FL0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ512µãÊÚȨ)
6ES76772AA410FM0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ2048µãÊÚȨ)
6ES76727AC000YA0 CPU 1507S,VERSION 1.8(1¸ö¸¡µãÊÚȨ), ½öÄÜÔÚSIMATIC IPCÉÏʹÓÃ
6ES78062CD000YA0 S7-1500Èí¼þ¿ØÖÆÆ÷ÓÃODK£¬Ê¹ÓÃC/C++À©Õ¹S7-1500Èí¼þ¿ØÖÆÆ÷µÄ¹¦ÄÜ
6ES71936AR000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×RJ45
6ES71936AF000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×FC¿ìÁ¬Ê½
6ES71936AP000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×SCRJ¹âÏË
6ES75455DA000AB0 S7-1510/1512 SP CPU DPͨÐÅÄ£¿é (RS-485 PROFIBUS-DP)
6ES79548LC020AA0 S7-1200/1500 4M ´æ´¢¿¨
6ES79548LE020AA0 S7-1200/1500 12M ´æ´¢¿¨
6ES79548LF020AA0 S7-1200/1500 24M ´æ´¢¿¨
6ES79548LL020AA0 S7-1200/1500 256M ´æ´¢¿¨
6ES79548LP010AA0 S7-1200/1500 2G ´æ´¢¿¨
6ES79548LT020AA0 S7-1200/1500 32G ´æ´¢¿¨
6ES71555AA000AB0 ET 200MP IM 155-5 PN ST ±ê×¼ÐͽӿÚÄ£¿é
6ES71555AA000AC0 ET 200MP IM 155-5 PN HF ¸ßÐÔÄÜÐͽӿÚÄ£¿é
6ES71555BA000AB0 ET 200MP IM 155-5 DP ST ±ê×¼ÐͽӿÚÄ£¿é
6ES75070RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ AC/DC 120/230 V
6ES75050RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ DC 24/48/60 V
6ES75050KA000AB0 PS£º25 W£¬¶î¶¨ÊäÈëµçѹ DC 24 V
6EP1332-4BA00 PM 1507£º72W£¬ 24 V/3 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6EP1333-4BA00 PM 1507£º192W£¬ 24 V/8 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6ES75325HF000AB0 AQ 8£ºÄ£ÄâÊä³öÄ£¿é£¬¸ßËÙ AQ 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325HD000AB0 AQ 4£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 4x U/I ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325NB000AB0 AQ 2£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75317KF000AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬AI 8x U/I/RTD/TC ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317NF100AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬¸ßËÙ£¬AI 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317QD000AB0 AI 4£ºÄ£ÄâÊä³öÄ£¿é£¬AI 4x U/I/RTD/TC ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75347QE000AB0 AI4/AQ2£ºÄ£ÄâÁ¿ÊäÈë/Êä³öÄ£¿é AI/AO 4x U/I/RTD/TC 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BL000AB0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BL100AA0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BH100AA0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75225FH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 16x 230 VAC/ 1A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 16x 230 VAC/ 2A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¸ßÐÔÄÜ DQ 8x 24VDC/ 2A HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225FF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 8 x 230 VAC/ 2A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 8x 230VAC/ 5A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL000AB0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 32x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL100AA0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬DI 32x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH000AB0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 16x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BH100AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH500AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬Ô´ÐÍ£¬DI 16x 24VDC SRC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211FH000AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 230V AC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75231BL000AA0 DI16/DQ16£ºÊý×ÖÁ¿ÊäÈë/Êä³öÄ£¿é£¬16x 24VDC/16x 24VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75501AA000AB0 TM Count 2 x 24 V£º2ͨµÀ¸ßËÙ¼ÆÊýÆ÷ÓëλÖòɼ¯(ÔöÁ¿ÐͱàÂëÆ÷£¬24VÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75511AB000AB0 TM PosInput 2£¬2ͨµÀ¼ÆÊýÓëλÖòɼ¯(ÔöÁ¿ÐÍ/¾ø¶ÔÖµ±àÂëÆ÷SSI£¬RS422ºÍ5V TTLÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75521AA000AB0 TM Timer DIDQ 16x24V ´øÊ±¼ä´Á¡¢¸ßËÙ¼ÆÊý¡¢PWMµÈ¹¦ÄÜ, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75401AB000AA0 PtP RS422/485 ͨѶģ¿é
6ES75411AB000AB0 PtP RS422/485£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75401AD000AA0 PtP RS232ͨѶģ¿é
6ES75411AD000AB0 PtP RS232£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75901BC000AA0 S7-1500 °²×°µ¼¹ì£º2000 mm
6ES75901AJ300AA0 S7-1500 °²×°µ¼¹ì£º830 mm
6ES75901AF300AA0 S7-1500 °²×°µ¼¹ì£º530 mm
6ES75901AE800AA0 S7-1500 °²×°µ¼¹ì£º482 mm
6ES75901AC400AA0 S7-1500 °²×°µ¼¹ì£º245 mm
6ES75901AB600AA0 S7-1500 °²×°µ¼¹ì£º160 mm
6ES75922AX000AA0 ±êÇ©,35mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AX000AA0 ±êÇ©,25mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬Âݶ¤ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XA0 25mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75905AA000AA0 "ÓÃÓÚÁ¬½ÓPE£¨µØ£©µ½S7-1500°²×°µ¼¹ìµÄ½ÓµØÔª¼þ£¬
¶ÔÓÚ2000mmµÄ°²×°µ¼¹ìÊDZØÐëµÄ ÿ¸ö°ü×°20Ƭ"
6ES75911AA000AA0 S7-1511/13CPUÏÔÊ¾Ãæ°å
6ES75911BA000AA0 S7-1515/16/17/18CPUÏÔÊ¾Ãæ°å
6ES75908AA000AA0 S7-1500 PS/PM¹©µçÄ£°åÁ¬½ÓÍ·£¬ÄÚº¬10Ƭ
6ES75280AA707AA0 ½Ó¿ÚÄ£¿é(6ES7 155-5AA00-0AB0)ǰ¸Ç°å5Ƭ/°ü
6ES75280AA007AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬35mmÄ£°åÊÊÓÃ
6ES75280AA000AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬25mmÄ£°åÊÊÓÃ
6ES75900AA000AA0 UÐÍÁ¬½ÓÆ÷,£¬5Ƭ/°ü
6ES75923AA000AA0 ÌøÏߣ¬20Ƭ/°ü
6ES75905CA000AA0 ÆÁ±ÎÌ×¼þ£ºº¬ÆÁ±Î¶Ë×Ó£¬¿ò¼ÜÒÔ¼°24VDC½ÓÏß¶Ë
6ES75905BA000AA0 Ä£ÄâÁ¿/¼¼ÊõÄ£°åרÓÃÆÁ±Î¶Ë×Ó
6ES76772AA300AA0 CPU 1515SP PC,2 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
6ES76772AA400AA0 CPU 1515SP PC,4 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
άÐÞ·þÎñ
»ÎÒÃǵÄÈ«ÇòάÐÞ·þÎñÍøÂç°ïÖúÄú½«´ËÀà·çÏÕ½µÎª×îµÍ¡£Î÷ÃÅ×ÓάÐÞ·þÎñ½«°ïÖúÄúµÄÏÖ³¡¹ÊÕϵõ½¼°Ê±Åųý£¬ÊÇÉ豸ͣ»úʱ¿ì½Ý¶øÊµ»ÝµÄ½â¾ö·½°¸¡£«
άÐÞ·þÎñ——ÄúµÄ»ñÒæ
¹¤³§Éú²úÖÐÉ豸ͣ»ú²»½ö´øÀ´Ò»ÏµÁÐÂé·³£¬¶øÇÒ»¹ÒªÎª´Ë¸¶³ö¸ß°ºµÄ³É±¾´ú¼Û¡£Ê¹ÓÃÎ÷ÃÅ×ÓάÐÞ·þÎñ£¬Äú½«£º´ó´óËõ¶ÌÍ£»úʱ¼ä£»ÇáËÉÁªÂçÈ«ÇòάÐÞÍøÂ磻»ñµÃ¿É¿¿µÄάÐÞÖÊÁ¿±£ÕÏ£»»ñµÃ¶À¼ÒÔ³§±¸¼þ¡£
άÐÞ·þÎñ¼Û¸ñÕþ²ß
ÎÒÃǵĶàÊý²úƷʵÐÐÒ»¿Ú¼ÛάÐÞ¡£ µ±Äúѯ¼Ûʱ£¬ÎÒÃÇÎÞÐè¼ÆËãάÐÞ¹¤Ê±¼´¿ÉÁ¢¿ÌÌṩάÐÞ¼Û¸ñ¡£Í¬Ê±£¬Ó¦ÄúµÄÐèÒªÎÒÃÇ¿ÉÒÔΪÄúÌṩάÐÞ±¨¸æ¡£
¸ù¾ÝÄúµÄÐèÇó£¬ÎÒÃÇÓµÓв»Í¬ÀàÐ͵ÄάÐÞ·þÎñ¿É¹©Ñ¡Ôñ£º
±ê׼άÐÞ£ºÍ¨³£µÄάÐÞʱ¼äΪÊÕµ½²úÆ·ºóµÄ5¸ö¹¤×÷ÈÕÒÔÄÚ¡£
¼Ó¼±Î¬ÐÞ£ºÔÚ½ô¼±Çé¿öÏ£¬ÎÒÃÇΪ¶àÊý²úÆ·ÌṩάÐÞʱ¼äΪ2¸ö¹¤×÷ÈÕÒÔÄڵķþÎñ¡£¿Í»§ÐèΪ´ËÖ§¸¶¶îÍâ·ÑÓá£
·Ç¹¤×÷ʱ¼äάÐÞ£ºÔÚ½ô¼±Çé¿öÏ¿ÉÒÔΪ¶àÊý²úÆ·ÔÚÖÜÄ©¼°½Ú¼ÙÈÕÌṩ·þÎñ¡£
ÉÏÃÅÈ¡¼þ£ºÕë¶Ô²¿·Ö²úÆ·ÌṩÉÏÃÅÈ¡¼þ¼°Î¬ÐÞºóËͻصķþÎñ¡£
ÏÖ³¡Î¬ÐÞ£º¶ÔÓÚÌå»ý½Ï´ó»ò½ÏÖØµÄ²úÆ·£¬ÎÒÃÇÒ²¿ÉÒÔÓ¦ÄúµÄÒªÇóÔÚ¿Í»§ÏÖ³¡ÌṩάÐÞ·þÎñ¡£
