SIMATIC S7-1500 COMPACT CPU CPU 1511C-1PN, CENTRAL PROCESSING UNIT WITH WORKING MEMORY 175 KB FOR PROGRAM AND 1 MB FOR DATA, 16 DIGITAL INPUTS, 16 DIGITAL OUTPUTS, 5 ANALOG INPUTS, 2 ANALOG OUTPUTS, 6 HIGH SPEED COUNTERS, 1. INTERFACE: PROFINET IRT WITH 2 PORT SWITCH, 60 NS BIT-PERFORMANCE, INCL. FRONT CONNECTOR PUSH-IN, SIMATIC MEMORY CARD NECESSARY |
| Ò»°ãÐÅÏ¢ |
| ²úÆ·ÀàÐͱêÖ¾ |
CPU 1511C-1 PN |
| Ó²¼þ¹¦ÄÜ״̬ |
FS01 |
| ¹Ì¼þ°æ±¾ |
V1.8 |
| ¸½´ø³ÌÐò°üµÄ |
| ¡ñ STEP 7 TIA ¶Ë¿Ú£¬¿É×é̬ / ÒѼ¯³É£¬×Ô°æ±¾ |
V13 SP1 Éý¼¶°æ 4 |
| ÅäÖÿØÖÆ |
| ͨ¹ýÊý¾Ý×é |
ÊÇ |
| ÏÔʾ |
| ÆÁÄ»¶Ô½ÇÏß (cm) |
3.45 cm |
| ²Ù×÷Ôª¼þ |
| °´¼üÊýÁ¿ |
6 |
| ÔËÐÐģʽ¿ª¹Ø |
1 |
| µçÔ´µçѹ |
| µçÔ´µÄµçѹÀàÐÍ |
24 V DC |
| ÔÊÐí·¶Î§£¬ÏÂÏÞ (DC) |
19.2 V; Êý×ÖÊäÈë/Êä³öµçÔ´ DC 20.4 V |
| ÔÊÐí·¶Î§£¬ÉÏÏÞ (DC) |
28.8 V |
| ·´¼«ÐÔ±£»¤ |
ÊÇ |
| µçÔ´ºÍµçѹ¶Ï·¿ç½Ó |
| ¡ñ Í£µç/¶Ïµç¿ç½Óʱ¼ä |
5 ms; ºÍ CPU ²¿¼þÉϵĹ©µçµçѹÓÐ¹Ø |
| ÊäÈëµçÁ÷ |
| ºÄÓõçÁ÷£¨¶î¶¨Öµ£© |
0.8 A; ΪÖ÷°åÊý×ÖÍâΧÉ豸¶ÀÁ¢¹©µç |
| ½ÓͨµçÁ÷£¬×î´óÖµ |
1.9 A; ¶î¶¨Öµ |
| I²t |
0.34 A²·s |
| Êý×ÖÊäÈë¶Ë |
| ¡ñ À´×Ô¸ºÔصçѹ L+£¨¿ÕÔØ£©£¬×î´óÖµ |
20 mA; ÿ×é |
| Êý×ÖÊä³ö¶Ë |
| ¡ñ À´×Ô¸ºÔصçѹ L+£¬×î´óÖµ |
30 mA; ÿ×飬ÎÞ¸ºÔØ |
| Êä³öµçѹ |
| ¶î¶¨Öµ (DC) |
24 V |
| ´«¸ÐÆ÷¹©µç |
| Êä³ö¶ËÊýÁ¿ |
1; Ò»¸ö¹«Óà 24 V ´«¸ÐÆ÷µçÔ´ |
| 24 V ´«¸ÐÆ÷¹©µç |
| ¡ñ 24 V |
ÊÇ; L+ (-0.8 V) |
| ¡ñ ¶Ì·±£»¤ |
ÊÇ |
| ¡ñ Êä³öµçÁ÷£¬×î´óÖµ |
1 A |
| ¹¦ÂÊ |
| À´×Ô±³°å×ÜÏߵŦºÄ£¨´ïµ½¾ùºâ£© |
8.5 W |
| ±³°å×ÜÏßÉϵÄÀ¡µç¹¦ÂÊ |
10 W |
| ¹¦ÂÊËðʧ |
| ¹¦ÂÊËðʧ£¬µäÐÍÖµ |
11.8 W |
| ´æ´¢Æ÷ |
| ÐèÒª SIMATIC ´æ´¢¿¨ |
ÊÇ |
| ¹¤×÷´æ´¢Æ÷ |
| ¡ñ ¼¯³É£¨ÓÃÓÚ³ÌÐò£© |
175 kbyte |
| ¡ñ ¼¯³É£¨ÓÃÓÚÊý¾Ý£© |
1 Mbyte |
| ×°ÔØ´æ´¢Æ÷ |
| ¡ñ ²å°Îʽ£¨SIMATIC ´æ´¢¿¨£©£¬×î´óÖµ |
32 Gbyte |
| »º³å |
| ¡ñ Ãâά»¤ |
ÊÇ |
| CPU-´¦Àíʱ¼ä |
| ¶ÔÓÚλÔËË㣬µäÐÍÖµ |
60 ns |
| ¶ÔÓÚ×ÖÔËË㣬µäÐÍÖµ |
72 ns |
| ¶ÔÓÚ¶¨µãÔËË㣬µäÐÍÖµ |
96 ns |
| ¶ÔÓÚ¸¡µãÔËË㣬µäÐÍÖµ |
384 ns |
| CPU-×é¼þ |
| ÔªËØÊýÁ¿£¨×ÜÊý£© |
2 000 |
| DB |
| ¡ñ ±àºÅ·¶Î§ |
1 ... 60 999£»»®·ÖÈçÏ£ºÓû§¿ÉÓñàºÅ·¶Î§£º1 ... 59 999 ºÍÓÉ SFC 86 ´´½¨µÄÊý¾Ý¿éµÄ±àºÅ·¶Î§£º60 000 ... 60 999 |
| ¡ñ ÈÝÁ¿£¬×î´óÖµ |
1 Mbyte; Èç¹ûÄ£¿é·ÃÎÊδ¾ÓÅ»¯£¬Êý¾Ý¿âµÄ×î´óÈÝÁ¿Îª 64 KB |
| FB |
| ¡ñ ±àºÅ·¶Î§ |
0 ... 65 535 |
| ¡ñ ÈÝÁ¿£¬×î´óÖµ |
175 kbyte |
| FC |
| ¡ñ ±àºÅ·¶Î§ |
0 ... 65 535 |
| ¡ñ ÈÝÁ¿£¬×î´óÖµ |
175 kbyte |
| OB |
| ¡ñ ÈÝÁ¿£¬×î´óÖµ |
175 kbyte |
| ¡ñ ¿ÉÓÃÑ»· OB ÊýÁ¿ |
100 |
| ¡ñ ʱ¼ä±¨¾¯ OB ÊýÁ¿ |
20 |
| ¡ñ ÑÓ³Ù±¨¾¯ OB ÊýÁ¿ |
20 |
| ¡ñ »½ÐѾ¯¸æ OB ÊýÁ¿ |
20 |
| ¡ñ ¹ý³Ì±¨¾¯ OB ÊýÁ¿ |
50 |
| ¡ñ DPV1 ±¨¾¯ OB µÄÊýÁ¿ |
3 |
| ¡ñ µÈʱģʽ Ob ÊýÁ¿ |
1 |
| ¡ñ ¼¼Êõͬ²½¾¯¸æ OB ÊýÁ¿ |
2 |
| ¡ñ Æô¶¯ OB ÊýÁ¿ |
100 |
| ¡ñ Òì²½´íÎó OB ÊýÁ¿ |
4 |
| ¡ñ ͬ²½´íÎó OB ÊýÁ¿ |
2 |
| ¡ñ Õï¶Ï±¨¾¯ OB µÄÊýÁ¿ |
1 |
| ǶÌ×Éî¶È |
| ¡ñ ÿ¸öÓÅÏȵȼ¶ |
24 |
| ¼ÆÊýÆ÷¡¢¶¨Ê±Æ÷¼°ÆäÊ£´Å |
| S7 ¼ÆÊýÆ÷ |
| ¡ñ ÊýÁ¿ |
2 048 |
| Ê£´Å |
| — ¿Éµ÷Õû |
ÊÇ |
| IEC ¼ÆÊýÆ÷ |
| ¡ñ ÊýÁ¿ |
ÈÎÒ⣨½öÓÉϵͳÄÚ´æ½øÐÐÏÞÖÆ£© |
| Ê£´Å |
| — ¿Éµ÷Õû |
ÊÇ |
| S7 ʱ¼ä |
| ¡ñ ÊýÁ¿ |
2 048 |
| Ê£´Å |
| — ¿Éµ÷Õû |
ÊÇ |
| IEC ¼ÆÊ±Æ÷ |
| ¡ñ ÊýÁ¿ |
| Ê£´Å |
| — ¿Éµ÷Õû |
ÊÇ |
| Êý¾Ý·¶Î§¼°ÆäÊ£´Å |
| ±£ÁôµÄÈ«²¿Êý¾Ý·¶Î§£¨°üÀ¨Ê±¼ä¡¢¼ÆÊýÆ÷¡¢±ê¼Ç£©£¬×î´óÖµ |
128 kbyte; ×ܼƣ»Õë¶Ô´æ´¢Æ÷¡¢¼ÆÊ±Æ÷¡¢¼ÆÊýÆ÷¡¢Êý¾Ý¿âºÍ¼¼ÊõÊý¾Ý£¨ÖᣩµÄ¿ÉÓÃÊ£´Å´æ´¢Æ÷£º 88 KB |
| ¡ñ ÊýÁ¿£¬×î´óÖµ |
16 kbyte |
| ¡ñ ¶¨Ê±±ê¼ÇÊýÁ¿ |
8; 8 ¸öʱÖÓ´æ´¢Æ÷¶þ½øÖÆÎ» bit ºÏ¶øÎªÒ»¸öʱÖÓ´æ´¢Æ÷×Ö½Ú byte |
| Êý¾Ý×é¼þ |
| ¡ñ ¿Éµ÷ÕûÊ£´Å |
ÊÇ |
| ¡ñ Ô¤ÉèÊ£´Å |
·ñ |
| ±¾µØÊý¾Ý |
| ¡ñ ÿ¸öÓÅÏȵȼ¶£¬×î´óÖµ |
64 kbyte; ÿ¸ö¿é×î´ó 16 KB |
| µØÖ··¶Î§ |
| IO Ä£¿éÊýÁ¿ |
1 024; Ä£¿é / ×ÓÄ£¿éµÄ×î´óÊýÁ¿ |
| ÍâÉèµØÖ··¶Î§ |
| ¡ñ ÊäÈë¶Ë |
32 kbyte; ËùÓÐÊäÈë¶ËλÓÚ¹ý³ÌÓ³ÏñÄÚ |
| ¡ñ Êä³ö¶Ë |
32 kbyte; ËùÓÐÊä³ö¶ËλÓÚ¹ý³ÌÓ³ÏñÄÚ |
| ÿ¸ö¼¯³ÉµÄ IO ×Óϵͳ |
| — ÊäÈë¶Ë£¨ÈÝÁ¿£© |
8 kbyte |
| — Êä³ö¶Ë£¨ÈÝÁ¿£© |
8 kbyte |
| ÿ¸ö CM / CP |
| — ÊäÈë¶Ë£¨ÈÝÁ¿£© |
8 kbyte |
| — Êä³ö¶Ë£¨ÈÝÁ¿£© |
8 kbyte |
| ·ÖÁ¿¹ý³ÌÓ³Ïñ |
| ¡ñ ·ÖÁ¿¹ý³ÌÓ³ÏñÊýÁ¿£¬×î´óÖµ |
32 |
| Ó²¼þÀ©Õ¹ |
| ·Ö²¼Ê½ IO ϵͳÊýÁ¿ |
20 |
| DP Ö÷Õ¾ÊýÁ¿ |
| ¡ñ ¹ØÓÚ CM |
4; ×î¶à×ܹ²¿É²å½Ó 4 ¸ö CM/CP£¨PROFIBUS¡¢PROFINET¡¢ÒÔÌ«Íø£© |
| IO ¿ØÖÆÆ÷ÊýÁ¿ |
| ¡ñ ¼¯³É |
1 |
| ¡ñ ¹ØÓÚ CM |
| ×é¼þÔØÌå |
| ¡ñ ÿ¸ö×é¼þÔØÌåµÄ×é¼þ£¬×î´óÖµ |
32; CPU + 31 ¸öÄ£¿é |
| ¡ñ ÐÐÊý£¬×î´óÖµ |
1 |
| PtP CM |
| ¡ñ PtP CM ÊýÁ¿ |
½öͨ¹ý¿ÉÓõIJå²ÛÏÞÖÆ¿ÉÁ¬½ÓµÄ PtP CM ÊýÁ¿ |
| ʱ¼ä |
| ʱÖÓ |
| ¡ñ ÀàÐÍ |
Ó²¼þʱÖÓ |
| ¡ñ »º³å³ÖÐøÊ±¼ä |
6 wk; µ±»·¾³Î¶ÈΪ 40°C ʱ£¬µäÐÍÖµ |
| ¡ñ ÿÈÕÆ«²î£¬×î´óÖµ |
10 s; µäÐÍÖµ£º2 s |
| ÔËÐÐʱ¼ä¼ÆÊýÆ÷ |
| ¡ñ ÊýÁ¿ |
16 |
| ʱ¼äͬ²½ |
| ¡ñ Ìṩ֧³Ö |
ÊÇ |
| ¡ñ ÔÚ AS ÖУ¬Ö÷Õ¾ |
ÊÇ |
| ¡ñ ÔÚ AS ÖУ¬´ÓÕ¾ |
ÊÇ |
| ¡ñ ÔÚÒÔÌ«ÍøÉÏͨ¹ý NTP |
ÊÇ |
| Êý×ÖÊäÈë |
| ¼¯³ÉͨµÀ (DI) |
16 |
| ¿É±à³ÌµÄÊý×ÖÊäÈë¶Ë |
ÊÇ |
| Ô´ÐÍÊäÈë/©ÐÔÊäÈë |
P ¶ÁÈ¡ |
| ÊäÈëÌØÐÔ·ûºÏ IEC 61131£¬ÀàÐÍ 3 |
ÊÇ |
| Êý×ÖÊäÈë¶Ë¹¦ÄÜ£¬¿ÉÉèÖòÎÊý |
| ¡ñ Tor Æô¶¯/Í£Ö¹ |
ÊÇ; ¼¼Êõ¹¦Äܼ¤»îʱ |
| ¡ñ ²¶»ñ |
ÊÇ; ¼¼Êõ¹¦Äܼ¤»îʱ |
| ¡ñ ͬ²½ |
ÊÇ; ¼¼Êõ¹¦Äܼ¤»îʱ |
| ÊäÈëµçѹ |
| ¡ñ ÊäÈëµçѹÀàÐÍ |
DC |
| ¡ñ ¶î¶¨Öµ (DC) |
24 V |
| ¡ñ ¶ÔÓÚÐźœ0” |
-3 ÖÁ +5V |
| ¡ñ ¶ÔÓÚÐźœ1” |
+11 ÖÁ +30V |
| ÊäÈëµçÁ÷ |
| ¡ñ ¶ÔÓÚÐźœ1”£¬µäÐÍÖµ |
2.5 mA |
| ÊäÈëÑÓ³Ù£¨ÊäÈëµçѹΪ¶î¶¨ÖµÊ±£© |
| ¶ÔÓÚ±ê×¼ÊäÈë¶Ë |
| — ¿É²ÎÊý»¯ |
ÊÇ; ÎÞ / 0.05 / 0.1 / 0.4 / 1.6 / 3.2 / 12.8 / 20 ms |
| — ´Ó“0”µ½“1”ʱ£¬×îСֵ |
6 µs; ÉèÖòÎÊýʱ“ÎÞ” |
| — ´Ó“0”µ½“1”ʱ£¬×î´óÖµ |
20 ms |
| — ´Ó“1”µ½“0”ʱ£¬×îСֵ |
| — ´Ó“1”µ½“0”ʱ£¬×î´óÖµ |
20 ms |
| ¶ÔÓÚ±¨¾¯ÊäÈë¶Ë |
| — ¿É²ÎÊý»¯ |
ÊÇ; Óë±ê×¼ÊäÈë¶ËÏàͬ |
| ¶ÔÓÚ¼ÆÊýÆ÷/¼¼Êõ¹¦ÄÜ |
| — ¿É²ÎÊý»¯ |
20 ms |
20 ms |
| µ¼Ïß³¤¶È |
| ¡ñ ÆÁ±Î£¬×î´óÖµ |
1 000 m; 600 ÓÃÓÚ¼¼Êõ¹¦ÄÜ£»ÓëÊäÈëÆµÂÊ¡¢Êµ¼ÊÖµ±àÂëÆ÷ºÍµçÀÂÖÊÁ¿Óйأ»100 kHz ʱ× 50 m |
| ¡ñ δÆÁ±Î£¬×î´óÖµ |
600 m; ÓÃÓÚ¼¼Êõ¹¦ÄÜ£º·ñ |
| Êý×ÖÊä³ö |
| Êý×ÖÊä³öÀàÐÍ |
¾§Ìå¹Ü |
| ¼¯³ÉͨµÀ (DO) |
16 |
| P ¿ª¹Ø |
ÊÇ; ÍÆÀʽÊä³ö¶Ë |
| ¶Ì·±£»¤ |
ÊÇ; µç×Ó/ÈÈѧ |
| ¡ñ ÏìÓ¦ãУ¬µäÐÍÖµ |
±ê×¼Êä³ö¶ËΪ 1.6 A£¬¸ßËÙÊä³ö¶ËΪ 0.5 A£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö |
| ¸ÐӦʽ¹Ø±ÕµçѹµÄÏÞÖÆ |
-0.8 V |
| ¿ØÖÆÊý×ÖÊäÈë |
ÊÇ |
| Êý×ÖÊä³ö¶Ë¹¦ÄÜ£¬¿ÉÉèÖòÎÊý |
| ¡ñ ±È½Ïֵת»» |
ÊÇ; ×÷Ϊ¸ßËÙ¼ÆÊýÆ÷µÄÊä³öÐźŠ|
| Êä³ö¶ËµÄͨ¶ÏÄÜÁ¦ |
| ¡ñ µç×è¸ºÔØÊ±µÄ×î´óÖµ |
0.5 A; ¸ßËÙÊä³ö¶ËΪ 0.1 A£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö |
| ¡ñ ÕÕÃ÷¸ºÔØÊ±µÄ×î´óÖµ |
5 W; ¸ßËÙÊä³ö¶ËΪ 1 W£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö |
| ¸ºÔصç×跶Χ |
| ¡ñ ÏÂÏÞ |
48 Ω; ¸ßËÙÊä³ö¶ËΪ 240 Ohm£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö |
| ¡ñ ÉÏÏÞ |
12 kΩ |
| Êä³öµçѹ |
| ¡ñ Êä³öµçѹÀàÐÍ |
DC |
| ¡ñ ¶ÔÓÚÐźœ0”µÄ×î´óÖµ |
1 V; ¸ßËÙÊä³ö¶Ëʱ£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö |
| ¡ñ ¶ÔÓÚÐźŠ“1”£¬×îСֵ |
L+ (-0.8 V) |
| Êä³öµçÁ÷ |
| ¡ñ ¶ÔÓÚÐźœ1”µÄ¶î¶¨Öµ |
0.5 A; ¸ßËÙÊä³ö¶ËΪ 0.1 A£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö£¬×¢Òâ½µÈÝ |
| ¡ñ Õë¶ÔÐźœ1”µÄÔÊÐí·¶Î§£¬×îСֵ |
2 mA |
| ¡ñ Õë¶ÔÐźœ1”µÄÔÊÐí·¶Î§£¬×î´óÖµ |
0.6 A; ¸ßËÙÊä³ö¶ËΪ 0.12 A£»ÕâÖ¸µÄÊÇʹÓÃÒ»¸ö¸ßËÙÊä³ö¶Ë£¨DQ1¡¢DQ3 ... DQ7£©×÷Ϊ¸ßËÙ¼ÆÊýÆ÷ (HSC) Êä³ö¶ËµÄÇé¿ö£¬×¢Òâ½µÈÝ |
| ¡ñ Õë¶ÔÐźœ0”µÄÊ£ÓàµçÁ÷£¬×î´óÖµ |
0.5 mA |
| µç×è¸ºÔØÊ±µÄÊä³öÑÓ³Ù |
| ¡ñ ´Ó “0” µ½“1”£¬×î´óÖµ |
100 µs |
| ¡ñ ´Ó ”1” µ½“0”£¬×î´óÖµ |
500 µs; Ëæ¸ºÔر仯 |
| ÓÃÓÚ¼¼Êõ¹¦ÄÜ |
| — ´Ó “0” µ½“1”£¬×î´óÖµ |
5 µs; ÓëʹÓõÄÊä³öÏà¹Ø£¬²Î¼ûÊÖ²áÖеĸ½¼Ó˵Ã÷ |
| — ´Ó ”1” µ½“0”£¬×î´óÖµ |
| Á½¸öÊä³ö¶Ë²¢Áª |
| ¡ñ ÓÃÓÚÂß¼Á¬½Ó |
ÊÇ; ÓÃÓÚ¼¼Êõ¹¦ÄÜ£º·ñ |
| ¡ñ ÓÃÓÚÔö¼Ó¹¦ÂÊ |
·ñ |
| ¡ñ ÓÃÓÚÈßÓà¿ØÖÆ¸ºÔØ |
| ¿ª¹ØÆµÂÊ |
100 Hz |
| ¡ñ µç¸Ð¸ºÔØÊ±µÄ×î´óÖµ |
0.5 Hz; ¸ù¾Ý IEC 60947-5-1£¬DC-13£»×¢Òâ½µ¶îÇúÏß |
10 Hz |
| Êä³ö¶ËµÄ×ܵçÁ÷ |
| ¡ñ ÿ¸öͨµÀµÄ×î´óµçÁ÷ |
0.5 A; ²Î¼ûÊÖ²áÖеĸ½¼Ó˵Ã÷ |
| ¡ñ ÿ¸ö×éµÄ×î´óµçÁ÷ |
8 A; ²Î¼ûÊÖ²áÖеĸ½¼Ó˵Ã÷ |
| ¡ñ ÿ¸öµçÔ´µÄµçÁ÷Öµ£¬×î´óÖµ |
4 A; ÿ×é 2 ¸öµçÔ´£¬Ã¿¸öµçÔ´µÄ×î´óµçÁ÷Ϊ 4 A£¬²Î¼ûÊÖ²áÖеĸ½¼Ó˵Ã÷ |
| ÓÃÓÚ¼¼Êõ¹¦ÄÜ |
| — ÿ¸öͨµÀµÄ×î´óµçÁ÷ |
0.1 A; ²Î¼ûÊÖ²áÖеĸ½¼Ó˵Ã÷ |
| µ¼Ïß³¤¶È |
| ¡ñ ÆÁ±Î£¬×î´óÖµ |
1 000 m; ÓÃÓÚ¼¼Êõ¹¦ÄÜ 600 m£»ÓëÊä³öƵÂÊ¡¢¸ºÔغ͵çÀÂÖÊÁ¿ÓÐ¹Ø |
| ¡ñ δÆÁ±Î£¬×î´óÖµ |
| Ä£ÄâÊäÈë |
| Ä£ÄâÊäÈë¶ËÊýÁ¿ |
5; ÓÃÓÚ U/I ʱ 4 ¸ö£¬ÓÃÓÚ R£¨µç×裩/RTD£¨Èȵç×裩ʱ 1 ¸ö |
| ¡ñ µçÁ÷²âÁ¿Ê± |
4; ×î´óÖµ |
| ¡ñ µçѹ²âÁ¿Ê± |
4; ×î´óÖµ |
| ¡ñ ²âÁ¿µç×è/µç×èÐÍÈȵçżʱ |
1 |
| µçѹÊäÈëÔÊÐíµÄÊäÈëµçѹ£¨»Ù»µÏÞÖÆ£©£¬×î´óÖµ |
28.8 V |
| µçÁ÷ÊäÈëÔÊÐíµÄÊäÈëµçÁ÷£¨»Ù»µÏÞÖÆ£©£¬×î´óÖµ |
40 mA |
| Ñ»·Ê±¼ä£¨ËùÓÐͨµÀ£© ×îСֵ |
1 ms; Óë¿Éµ÷½Ú²ÎÊýµÄ¸ÉÈÅÆµÂÊÒÖÖÆÏà¹Ø£¬ÏêϸÐÅÏ¢²Î¼ûÊÖ²áÖеēת»»¹ý³Ì” |
| ζȲâÁ¿µÄ¼¼Êõµ¥Î»£¬¿Éµ÷½Ú |
ÊÇ; °C / °F / K |
| ÊäÈ뷶Χ£¨¶î¶¨Öµ£©£¬µçѹ |
| ¡ñ 0 ÖÁ +10 V |
ÊÇ; ÎïÀí²âÁ¿·¶Î§£º ±10 V |
| ¡ñ ÊäÈëµç×裨0 ÖÁ 10 V£© |
100 kΩ |
| ¡ñ 1 V ÖÁ 5 V |
| ¡ñ ÊäÈëµç×裨1 V ÖÁ 5 V£© |
100 kΩ |
| ¡ñ -10 V ÖÁ +10 V |
ÊÇ |
| ¡ñ ÊäÈëµç×裨-10 V ÖÁ +10 V£© |
100 kΩ |
| ¡ñ -5 V ÖÁ +5 V |
| ¡ñ ÊäÈëµç×裨-5 V ÖÁ +5 V£© |
100 kΩ |
| ÊäÈ뷶Χ£¨¶î¶¨Öµ£©£¬µçÁ÷ |
| ¡ñ 0 ÖÁ 20 mA |
ÊÇ; ÎïÀí²âÁ¿·¶Î§£º ±20 mA |
| ¡ñ ÊäÈëµç×裨0 ÖÁ 20 mA£© |
50 Ω; Áí¼ÓÔ¼ 55 Ohm£¬ÓÃÓÚͨ¹ý PTC ʵÏÖ¹ýѹ±£»¤ |
| ¡ñ -20 mA ÖÁ +20 mA |
ÊÇ |
| ¡ñ ÊäÈëµç×裨-20 mA ÖÁ +20 mA£© |
| ¡ñ 4 mA ÖÁ 20 mA |
| ¡ñ ÊäÈëµç×裨4 mA ÖÁ 20 mA£© |
| ÊäÈ뷶Χ£¨¶î¶¨Öµ£©£¬µç×èÎÂ¶È¼Æ |
| ¡ñ Ni 100 |
ÊÇ; ±ê×¼/Æøºò |
| ¡ñ ÊäÈëµç×è (Ni 100) |
10 MΩ |
| ¡ñ Pt 100 |
ÊÇ; ±ê×¼/Æøºò |
| ¡ñ ÊäÈëµç×è (Pt 100) |
10 MΩ |
| ÊäÈ뷶Χ£¨¶î¶¨Öµ£©£¬µç×è |
| ¡ñ 0 ÖÁ 150 Å·Ä· |
ÊÇ; ÎïÀí²âÁ¿·¶Î§£º0 ÖÁ 600 Ohm |
| ¡ñ ÊäÈëµç×裨0 ÖÁ 150 Å·Ä·£© |
10 MΩ |
| ¡ñ 0 ÖÁ 300 Å·Ä· |
| ¡ñ ÊäÈëµç×裨0 ÖÁ 300 Å·Ä·£© |
10 MΩ |
| ¡ñ 0 ÖÁ 600 Å·Ä· |
ÊÇ |
| ¡ñ ÊäÈëµç×裨0 ÖÁ 600 Å·Ä·£© |
10 MΩ |
| µ¼Ïß³¤¶È |
| ¡ñ ÆÁ±Î£¬×î´óÖµ |
800 m; U/I ÖУ¬R/RTD ʱ 200 m |
| Ä£ÄâÊä³ö |
| ¼¯³ÉͨµÀ (AO) |
2 |
| µçѹÊä³ö£¬¶Ì·±£»¤ |
ÊÇ |
| Êä³ö·¶Î§£¬µçѹ |
| ¡ñ 0 ÖÁ 10 V |
ÊÇ |
| ¡ñ 1 V ÖÁ 5 V |
ÊÇ |
| ¡ñ -10 V ÖÁ +10 V |
ÊÇ |
| Êä³ö·¶Î§£¬µçÁ÷ |
| ¡ñ 0 ÖÁ 20 mA |
ÊÇ |
ÊÇ |
| ¡ñ 4 mA ÖÁ 20 mA |
ÊÇ |
| ¸ºÔصç×裨ÔڶÊä³ö·¶Î§ÄÚ£© |
| ¡ñ µçѹÊä³ö¶ËµÄ×îСֵ |
1 kΩ |
| ¡ñ µçѹÊä³ö¶ËµÄµçÈݸºÔØ£¬×î´óÖµ |
100 nF |
| ¡ñ µçÁ÷Êä³ö¶ËµÄ×î´óÖµ |
500 Ω |
| ¡ñ µçÁ÷Êä³ö¶ËµÄµç¸Ð¸ºÔØ£¬×î´óÖµ |
1 mH |
| µ¼Ïß³¤¶È |
| ¡ñ ÆÁ±Î£¬×î´óÖµ |
200 m |
| ÊäÈë¶ËµÄÄ£ÄâÖµ¹¹³É |
| ¼¯³ÉºÍת»»Ê±¼ä/ÿͨµÀ·Ö±æÂÊ |
| ¡ñ ´øÓйýµ÷ÖÆµÄ·Ö±æÂÊ£¨°üÀ¨·ûºÅÔÚÄÚµÄλÊý£©£¬×î´óÖµ |
16 bit |
| ¡ñ ¿É²ÎÊý»¯µÄ¼¯³Éʱ¼ä |
ÊÇ; 2.5 / 16.67 / 20 / 100 ms£¬×÷ÓÃÓÚËùÓÐͨµÀ |
| ¡ñ ¶ÔÓÚ¸ÉÈÅÆµÂÊ f1£¨µ¥Î» Hz£©µÄ¸ÉÈŵçѹÒÖÖÆ |
400 / 60 / 50 / 10 |
| ²âÁ¿ÖµÂ˲¨ |
| ¡ñ ¿É²ÎÊý»¯ |
ÊÇ |
| ¡ñ µÈ¼¶£º ÎÞ |
ÊÇ |
| ¡ñ µÈ¼¶£ºÈõ |
ÊÇ |
| ¡ñ µÈ¼¶£º ÖÐµÈ |
ÊÇ |
| ¡ñ µÈ¼¶£º Ç¿ |
ÊÇ |
| Êä³ö¶ËµÄÄ£ÄâÖµ¹¹³É |
16 bit |
| ÆðÕñʱ¼ä |
| ¡ñ ¶ÔÓÚµç×è¸ºÔØ |
1.5 ms |
| ¡ñ ¶ÔÓÚµçÈݸºÔØ |
2.5 ms |
| ¡ñ ¶ÔÓÚµç¸Ð¸ºÔØ |
2.5 ms |
| ´«¸ÐÆ÷ |
| ÐźŴ«¸ÐÆ÷Á¬½Ó |
| ¡ñ ÓÃÓÚµçѹ²âÁ¿ |
ÊÇ |
| ¡ñ ¶ÔÓÚ×÷ΪËÄÏßÖÆ²âÁ¿±äËÍÆ÷ʱµÄµçÁ÷²âÁ¿ |
ÊÇ |
| ¡ñ ¶ÔÓÚÀûÓÃÁ½ÏßÖÆ½Ó¿Ú½øÐеĵç×è²âÁ¿ |
ÊÇ |
| ¡ñ ¶ÔÓÚÀûÓÃÈýÏßÖÆ½Ó¿Ú½øÐеĵç×è²âÁ¿ |
ÊÇ |
| ¡ñ ¶ÔÓÚÀûÓÃËÄÏßÖÆ½Ó¿Ú½øÐеĵç×è²âÁ¿ |
ÊÇ |
| ¿ÉÁ¬½Ó´«¸ÐÆ÷ |
| ¡ñ Ë«Ïß´«¸ÐÆ÷ |
ÊÇ |
| — ÔÊÐíµÄ±Õ·µçÁ÷£¨Ë«Ïß´«¸ÐÆ÷£© ×î´óÖµ |
1.5 mA |
| ´«¸ÐÆ÷Ðźţ¬ÔöÁ¿±àÂëÆ÷£¨·Ç¶Ô³Æ£© |
| ¡ñ ÊäÈëµçѹ |
24 V |
| ¡ñ ÊäÈëÆµÂÊ£¬×î´óÖµ |
100 kHz |
| ¡ñ ¼ÆÊýƵÂÊ£¬×î´óÖµ |
400 kHz; Ëı¶·ÖÎöʱ |
| ¡ñ ÐźÅÂ˲¨Æ÷£¬¿ÉÉèÖòÎÊý |
ÊÇ |
| ¡ñ ´øÓÐ A/B ¹ì¼£µÄÔöÁ¿±àÂëÆ÷£¬90° ÏàÒÆ |
ÊÇ |
| ¡ñ ´øÓÐ A/B ¹ì¼£µÄÔöÁ¿±àÂëÆ÷£¬90° ÏàÒÆºÍÁã¹ì¼£ |
ÊÇ |
| ¡ñ Âö³å±àÂëÆ÷ |
ÊÇ |
| ¡ñ ¾ßÓз½ÏòµÄÂö³å±àÂëÆ÷ |
ÊÇ |
| ¡ñ ÿ¸ö¼ÆÊý·½Ïò¾ßÓÐÕýÐźŵÄÂö³å±àÂëÆ÷ |
ÊÇ |
| Îó²î/¾«¶È |
| ÏßÐÔ´íÎó£¨ÓëÊäÈ뷶ΧÓйأ©£¬(+/-) |
0.1 % |
| ζȴíÎó£¨ÓëÊäÈ뷶ΧÓйأ©£¬(+/-) |
0.005 %/K |
| ÊäÈë¶ËÖ®¼äµÄ´®ÈÅ£¬×î´óÖµ |
-60 dB |
| 25 °C ʱÆðÕñ״̬ϵÄÖØ¸´¾«¶È£¨ÓëÊäÈ뷶ΧÓйأ©£¬(+/-) |
0.05 % |
| Êä³ö²¨ÎÆ£¨ÓëÊä³ö·¶Î§Óйأ¬´ø¿í 0 ÖÁ 50 kHz£©£¬(+/-) |
0.02 % |
| ÏßÐÔ´íÎó£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.15 % |
| ζȴíÎó£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.005 %/K |
| Êä³ö¶ËÖ®¼äµÄ´®ÈÅ£¬×î´óÖµ |
-80 dB |
| 25 °C ʱÆðÕñ״̬ϵÄÖØ¸´¾«¶È£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.05 % |
| Õû¸öζȷ¶Î§ÄڵIJÙ×÷´íÎóÏÞÖÆ |
| ¡ñ µçѹ£¬ÓëÊäÈ뷶ΧÓйأ¬(+/-) |
0.3 % |
| ¡ñ µçÁ÷£¬ÓëÊäÈ뷶ΧÓйأ¬(+/-) |
0.3 % |
| ¡ñ µç×裬ÓëÊäÈ뷶ΧÓйأ¬(+/-) |
0.3 % |
| ¡ñ Èȵç×裬ÓëÊäÈ뷶ΧÓйأ¬(+/-) |
Pt100 ±ê×¼ÐÍ£º±2 K¡¢Pt100 ÆøºòÐÍ£º±1 K¡¢Ni100 ±ê×¼ÐÍ£º±1.2 K¡¢Ni100 ÆøºòÐÍ£º±1 K |
| ¡ñ µçѹ£¬ÓëÊä³ö·¶Î§Óйأ¬(+/-) |
0.3 % |
| ¡ñ µçÁ÷£¬ÓëÊä³ö·¶Î§Óйأ¬(+/-) |
0.3 % |
| »ù±¾´íÎóÏÞÖÆ£¨25 °C ʱµÄ²Ù×÷´íÎóÏÞÖÆ£© |
0.2 % |
0.2 % |
0.2 % |
Pt100 ±ê×¼ÐÍ£º±1 K¡¢Pt100 ÆøºòÐÍ£º±0.5 K¡¢Ni100 ±ê×¼ÐÍ£º±0.6 K¡¢Ni100 ÆøºòÐÍ£º±0.5 K |
0.2 % |
0.2 % |
| ¹ÊÕϵçѹÒÖÖÆ f = n x (f1 +/- 1 %)£¬f1 = ¸ÉÈÅÆµÂÊ |
| ¡ñ ´®Áª¸ÉÈÅ£¨¸ÉÈÅ·åÖµ < ÊäÈ뷶ΧµÄ¶î¶¨Öµ£©£¬×îСֵ |
30 dB |
| ¡ñ ²¢Áªµçѹ£¬×î´óÖµ |
10 V |
| ¡ñ ¹²Ä£¸ÉÈÅ£¬×îСֵ |
60 dB; 400Hz ʱ£º 50dB |
| ½Ó¿Ú |
| PROFINET ½Ó¿ÚÊýÁ¿ |
1 |
| 1. ½Ó¿Ú |
| ÎïÀí½Ó¿Ú |
| ¡ñ ¶Ë¿ÚÊýÁ¿ |
2 |
| ¡ñ ¼¯³É¿ª¹Ø |
ÊÇ |
| ¡ñ RJ 45£¨ÒÔÌ«Íø£© |
ÊÇ; X1 |
| ¹¦ÄÜÐÔ |
| ¡ñ PROFINET IO ¿ØÖÆÆ÷ |
ÊÇ |
| ¡ñ PROFINET IO É豸 |
ÊÇ |
| ¡ñ SIMATIC ͨѶ |
ÊÇ |
| ¡ñ ¿ª·Åʽ IE ͨѶ |
ÊÇ |
| ¡ñ ÍøÂç·þÎñÆ÷ |
ÊÇ |
| ¡ñ ÆøÒºÈßÓà |
ÊÇ |
| ÎïÀí½Ó¿Ú |
| RJ 45£¨ÒÔÌ«Íø£© |
| ¡ñ 100 Mbit/s |
ÊÇ |
| ¡ñ ×Ô¶¯ÐÉÌ |
ÊÇ |
| ¡ñ ×Ô¶¯½»²æ |
ÊÇ |
| ¡ñ ¹¤ÒµÒÔÌ«Íø×´Ì¬ LED |
ÊÇ |
| ÐÒé |
| Á¬½ÓÊýÁ¿ |
| ¡ñ Á¬½ÓÊýÁ¿£¬×î´óÖµ |
96; ͨ¹ý CPU ºÍËùÁ¬½Ó CP/CM µÄÄÚÖÃ½Ó¿Ú |
| ¡ñ Ϊ ES/HMI/Web Ô¤ÁôµÄÁ¬½ÓÊýÁ¿ |
10 |
| ¡ñ ͨ¹ý¼¯³É½Ó¿ÚµÄÁ¬½ÓÊýÁ¿ |
64 |
| ¡ñ S7 ·¾¶Á¬½ÓÊýÁ¿ |
16 |
| ·þÎñ |
| — PG/OP ͨѶ |
ÊÇ |
| — S7 ·ÓÉ |
ÊÇ |
| — µÈʱģʽ |
ÊÇ |
| — ¿ª·Åʽ IE ͨѶ |
ÊÇ |
| — IRT |
ÊÇ |
| — MRP |
ÊÇ; ×÷Ϊ MRP ÈßÓà¹ÜÀíÆ÷ºÍ/»ò MRP ¿Í»§»ú£»»·Â·ÖеÄ×î´óÉ豸Êý£º 50 |
| — PROFIenergy |
ÊÇ |
| — °´ÓÅÏȼ¶Æô¶¯ |
ÊÇ; ×î¶à 32 ¸ö PROFINET É豸 |
| — ¿ÉÁ¬½ÓµÄ IO É豸ÊýÁ¿£¬×î´óÖµ |
128; ͨ¹ý PROFIBUS »ò PROFINET ×ܹ²×î¶à¿ÉÁ¬½Ó 256 ¸ö·Ö²¼Ê½ÍâΧÉ豸 |
| — ÆäÖÐ IO É豸¾ß±¸Í¬²½ÊµÊ±¹¦ÄÜ (IRT)£¬×î´óÖµ |
64 |
| — ÓÃÓÚ RT µÄ¿ÉÁ¬½Ó IO É豸ÊýÁ¿£¬×î´óÖµ |
128 |
| — Ïß·Éϵģ¬×î´óÖµ |
128 |
| — ¿Éͬʱ¼¤»î/È¡ÏûµÄ IO É豸ÊýÁ¿£¬×î´óÖµ |
8 |
| — ÿ̨¹¤¾ßµÄ IO É豸ÊýÁ¿£¬×î´óÖµ |
8 |
| — ¸üÐÂʱ¼ä |
¸üÐÂʱ¼ä×îСֵȡ¾öÓÚÉèÖÃµÄ PROFINET IO ͨѶ²¿¼þ£¬È¡¾öÓÚ IO ×°ÖÃÊýÁ¿ºÍ×é̬µÄÓÐЧÊý¾ÝÊýÁ¿ |
| ¸üÐÂʱ¼ä£¬IRT ʱ |
| — ·¢ÉäÂö³åΪ 250 µs ʱ |
250 µs ÖÁ 4 ms£»ËµÃ÷£ºÍ¬²½Ä£Ê½µÄ IRT ¶ÔʱÖÓͬ²½×éÖ¯¿éµÄ×îС¸üÐÂʱ¼ä 625 µs ÖÁ¹ØÖØÒª¡£ |
| — ·¢ÉäÂö³åΪ 500 µs ʱ |
500 µs ÖÁ 8 ms£»ËµÃ÷£ºÍ¬²½Ä£Ê½µÄ IRT ¶ÔʱÖÓͬ²½×éÖ¯¿éµÄ×îС¸üÐÂʱ¼ä 625 µs ÖÁ¹ØÖØÒª¡£ |
| — ·¢ÉäÂö³åΪ 1 ms ʱ |
1 ms ÖÁ 16 ms |
| — ·¢ÉäÂö³åΪ 2 ms ʱ |
2 ms ÖÁ 32 ms |
| — ·¢ÉäÂö³åΪ 4 ms ʱ |
4 ms ÖÁ 64 ms |
| — Ôھ߱¸Í¬²½ÊµÊ±¹¦ÄÜ (IRT) ºÍ“ÆæÊý”·¢ËÍÂö³åÒѲÎÊý»¯Çé¿öÏ |
¸üÐÂʱ¼ä = ÉèÖÃµÄ“ÆæÊý”·¢ÉäÂö³å£¨125 µs µÄÈÎÒâ±¶Êý£º375 µs¡¢625 µs ... 3 875 µs£© |
| ¸üÐÂʱ¼ä£¬RT ʱ |
250 µs ÖÁ 128 ms |
500 µs ÖÁ 256 ms |
1 ms ÖÁ 512 ms |
2 ms ÖÁ 512 ms |
4 ms ÖÁ 512 ms |
| PROFINET IO É豸 |
| ·þÎñ |
| — PG/OP ͨѶ |
ÊÇ |
| — S7 ·ÓÉ |
ÊÇ |
| — µÈʱģʽ |
·ñ |
| — ¿ª·Åʽ IE ͨѶ |
ÊÇ |
| — IRT |
ÊÇ |
| — MRP |
ÊÇ |
| — PROFIenergy |
ÊÇ |
| — ¹²ÏíÉ豸 |
ÊÇ |
| — ¹²ÏíÉ豸ÖÐµÄ IO ¿ØÖÆÆ÷µÄ×î´óÊýÁ¿ |
4 |
| SIMATIC ͨѶ |
| ¡ñ S7 ͨѶ£¬×÷Ϊ·þÎñÆ÷ |
ÊÇ |
| ¡ñ S7 ͨѶ£¬×÷Ϊ¿Í»§»ú |
ÊÇ |
| ¡ñ ÿ¸öÈÎÎñµÄÓÐЧÊý¾Ý£¬×î´óÖµ |
²Î¼ûÔÚÏß°ïÖú£¨S7 ͨѶ£¬Óû§Êý¾Ý´óС£© |
| ¿ª·Åʽ IE ͨѶ |
| ¡ñ TCP/IP |
ÊÇ |
| — Êý¾Ý³¤¶È£¬×î´óÖµ |
64 kbyte |
| — ¸÷¶Ë¿ÚµÄ¶à¸öÎÞÔ´Á¬½Ó£¬Ìṩ֧³Ö |
ÊÇ |
| ¡ñ ISO-on-TCP (RFC1006) |
ÊÇ |
64 kbyte |
| ¡ñ UDP |
ÊÇ |
1 472 byte |
| ¡ñ DHCP |
·ñ |
| ¡ñ SNMP |
ÊÇ |
| ¡ñ DCP |
ÊÇ |
| ¡ñ LLDP |
ÊÇ |
| ÍøÂç·þÎñÆ÷ |
| ¡ñ HTTP |
ÊÇ; ±ê×¼ºÍÓû§¶¨ÒåÒ³Ãæ |
| ¡ñ HTTPS |
| ÆäËûÐÒé |
| ¡ñ MODBUS |
ÊÇ; MODBUS TCP |
| ÆøÒºÈßÓà |
| ¡ñ Ïß·ÖжÏʱµÄÇл»Ê±¼ä£¬ÀàÐÍ |
200 ms |
| ¡ñ »·Â·ÖеÄÓû§ÊýÁ¿£¬×î´óÖµ |
50 |
| µÈʱģʽ |
| ½ÚÅÄͬ²½ÔËÐУ¨Ó¦ÓóÌÐòÖÁ¶Ë¿Úͬ²½£© |
ÊÇ; ´ø×îС×éÖ¯¿é£¬6 ¸ö 625 µs Ñ»· |
| µÈ¾àÀë |
ÊÇ |
| S7 ÏûÏ¢¹¦ÄÜ |
| ÏûÏ¢¹¦ÄܵĿÉ×¢²áÕ¾µãÊýÁ¿£¬×î´óÖµ |
32 |
| Óë×é¼þÏà¹ØµÄÏûÏ¢ |
ÊÇ |
| ¿ÉÅäÖþ¯±¨µÄÊýÁ¿£¬×î´óÖµ |
5 000 |
| ÔÚ¾¯±¨³ØÖÐͬʱÏìÓ¦¾¯±¨µÄÊýÁ¿ |
| ¡ñ ±¸ÓÃÓû§¾¯±¨ÊýÁ¿ |
300 |
| ¡ñ ÓÃÓÚϵͳÕï¶ÏµÄ±¸Óþ¯±¨ÊýÁ¿ |
100 |
| ¡ñ ÓÃÓÚÔ˶¯¼¼Êõ¿ØÖƶÔÏóµÄ±¸Óþ¯±¨ÊýÁ¿ |
80 |
| µ÷ÊÔ¹¦ÄܲâÊÔ |
| ¹²Í¬µ÷ÊÔ£¨¹¤³Ì×飩 |
ÊÇ; ×î¶à¿ÉƽÐÐÔÚÏß·ÃÎÊ 5 ¸ö¹¤³Ì×é̬ϵͳ |
| ×é¼þ״̬ |
ÊÇ; ×î¶à¿Éͬʱ 8 ¸ö£¨Í¨¹ýËùÓÐ ES ¿Í»§¶ËµÄ×ܺͣ© |
| ¸÷¸ö²½Öè |
·ñ |
| ״̬/¿ØÖÆ |
| ¡ñ ±äÁ¿×´Ì¬/¿ØÖÆ |
ÊÇ |
| ¡ñ ±äÁ¿ |
ÊäÈë/Êä³ö¶Ë¡¢±ê¼Ç¡¢DB¡¢ÍâΧÉ豸ÊäÈë/Êä³ö¶Ë¡¢¼ÆÊ±Æ÷¡¢¼ÆÊýÆ÷ |
| ¡ñ ±äÁ¿ÊýÁ¿£¬×î´óÖµ |
| — ÆäÖеıäÁ¿×´Ì¬£¬×î´óÖµ |
200; ÿ¸öÈÎÎñ |
| — ÆäÖеıäÁ¿¿ØÖÆ£¬×î´óÖµ |
200; ÿ¸öÈÎÎñ |
| Ç¿ÖÆ |
| ¡ñ Ç¿ÖÆ£¬±äÁ¿ |
ÍâΧÊäÈë/Êä³ö |
200 |
| Õï¶Ï»º³åÆ÷ |
| ¡ñ ´æÔÚ |
ÊÇ |
| ¡ñ ÌõÄ¿ÊýÁ¿£¬×î´óÖµ |
1 000 |
| — ÆäÖеÄÍ£µç±£ÏÕ |
500 |
| Trace |
| ¡ñ ¿É×é̬ Trace µÄÊýÁ¿ |
4; ÿ¸ö Trace ×î¶à 512 KB Êý¾Ý |
| ±¨¾¯/Õï¶Ï/״̬ÐÅÏ¢ |
| ±¨¾¯ |
| ¡ñ Õï¶Ï±¨¾¯ |
ÊÇ |
| ¡ñ ¹ý³Ì±¨¾¯ |
ÊÇ |
| Õï¶ÏÐÅÏ¢ |
| ¡ñ µçÔ´µçѹ¼à¿Ø |
ÊÇ |
| ¡ñ ¶ÏÏß |
ÊÇ; ¹ØÓÚÄ£ÄâÊäÈë/Êä³ö²Î¼ûÊÖ²áÖеÄÃèÊö |
| ¡ñ ¶Ì· |
ÊÇ; ¹ØÓÚÄ£ÄâÊä³ö²Î¼ûÊÖ²áÖеÄÃèÊö |
| ¡ñ ÔöÁ¿Ê½±àÂëÆ÷ÖÐ A/B ת»»´íÎó |
ÊÇ |
| Õï¶ÏÏÔʾ LED |
| ¡ñ RUN/STOP LED |
ÊÇ |
| ¡ñ ERROR LED |
ÊÇ |
| ¡ñ MAINT LED |
ÊÇ |
| ¡ñ µçÔ´µçѹ¼à¿Ø (PWR-LED) |
ÊÇ |
| ¡ñ ͨµÀ״̬ÏÔʾ |
ÊÇ |
| ¡ñ ÓÃÓÚͨµÀÕï¶Ï |
ÊÇ; Ä£ÄâÁ¿ÊäÈë/Êä³ö |
| ¡ñ LINK TX/RX Á¬½ÓÏÔʾ |
ÊÇ |
| Ö§³ÖµÄ¹¤ÒÕ¶ÔÏó |
| Ô˶¯¿ØÖÆ |
ÊÇ |
| ¡ñ תËÙÖá |
| — תËÙÖáÊýÁ¿£¬×î´óÖµ |
6; ǰÌáÌõ¼þ£ºÎ´´´½¨ÆäËüµÄÔ˶¯¼¼Êõ¶ÔÏó£»Ìáʾ£ºÖáµÄÊýÁ¿»á¶Ô PLC ³ÌÐòµÄÑ»·Ê±¼äÕÕ³ÉÓ°Ï죻TIA Ñ¡Ôñ¹¤¾ß»áÌṩѡÐͰïÖú |
| ¡ñ ¶¨Î»Öá |
| — ¶¨Î»ÖáÊýÁ¿£¬×î´óÖµ |
| ¡ñ ͬ²½ÖᣨÏà¶Ô³ÝÂÖÏäͬ²½£© |
| — ÖáµÄ×î´óÊýÁ¿ |
3; ǰÌáÌõ¼þ£ºÎ´´´½¨ÆäËüµÄÔ˶¯¼¼Êõ¶ÔÏó£»Ìáʾ£ºÖáµÄÊýÁ¿»á¶Ô PLC ³ÌÐòµÄÑ»·Ê±¼äÕÕ³ÉÓ°Ï죻TIA Ñ¡Ôñ¹¤¾ß»áÌṩѡÐͰïÖú |
| ¡ñ Íⲿ±àÂëÆ÷ |
| — Íⲿ±àÂëÆ÷ÊýÁ¿£¬×î´óÖµ |
| µ÷½ÚÆ÷ |
| ¡ñ PID_Compact |
ÊÇ; ¼¯³ÉÓÅ»¯µÄͨÓà PID ¿ØÖÆÆ÷ |
| ¡ñ PID_3Step |
ÊÇ; ÊÊÓÃÓÚ·§ÃŵÉÓÅ»¯µÄ PID ¿ØÖÆÆ÷ |
| ¡ñ PID ÎÂ¶È |
ÊÇ; ζȼ¯³ÉÓÅ»¯µÄ PID ¿ØÖÆÆ÷ |
| ¼ÆÊýºÍ²âÁ¿ |
| ¡ñ ¸ßËÙ¼ÆÊýÆ÷ |
ÊÇ |
| ¼¯³É¹¦ÄÜ |
| ¼ÆÊýÆ÷ÊýÁ¿ |
6; ÆäÖÐ×î´ó 4x A/B/N |
| ¼ÆÊýƵÂÊ£¨¼ÆÊýÆ÷£©£¬×î´óÖµ |
400 kHz; Ëı¶·ÖÎöʱ |
| ¼ÆÊý¹¦ÄÜ |
| ¡ñ Ñ»·¼ÆÊý |
ÊÇ |
| ¡ñ ¿É¶Ô¼ÆÊýÆ÷ÌØÐÔ½øÐвÎÊýÉèÖà |
ÊÇ |
| ¡ñ Êý×ÖÊäÈë¶ËÉϵÄÓ²¼þ Tor |
ÊÇ |
| ¡ñ Èí¼þ Tor |
ÊÇ |
| ¡ñ ʼþ¿ØÖÆÍ£Ö¹ |
ÊÇ |
| ¡ñ ͨ¹ýÊý×ÖÊäÈë¶Ëͬ²½ |
ÊÇ |
| ¡ñ ¼ÆÊý·¶Î§£¬¿ÉÉèÖòÎÊý |
ÊÇ |
| ±È½ÏÒÇ |
| — ±È½ÏÒÇÊýÁ¿ |
2; ÿ¸ö¼ÆÊýÐŵÀ£»ÏêϸÐÅÏ¢²Î¼ûÊÖ²á |
| — ·½ÏòÐÔ |
ÊÇ |
| — ¿É´ÓÓû§³ÌÐòÖиü¸Ä |
ÊÇ |
| λÖÃÊÕ¼¯ |
| ¡ñ ÔöÁ¿ÊÕ¼¯ |
ÊÇ |
| ¡ñ ÊÊÓÃÓÚ S7-1500 Ô˶¯¿ØÖÆ |
ÊÇ |
| ²âÁ¿¹¦ÄÜ |
| ¡ñ ²âÁ¿Ê±¼ä£¬¿ÉÉèÖòÎÊý |
ÊÇ |
| ¡ñ ¶¯Ì¬²âÁ¿Ê±¼äµ÷Õû |
ÊÇ |
| ¡ñ ãÐÖµÊýÁ¿£¬¿ÉÉèÖòÎÊý |
2 |
| ²âÁ¿·¶Î§ |
| — ƵÂʲâÁ¿£¬×îСֵ |
0.04 Hz |
| — ƵÂʲâÁ¿£¬×î´óÖµ |
400 kHz; Ëı¶·ÖÎöʱ |
| — ÖÜÆÚ³ÖÐøÊ±¼ä²âÁ¿£¬×îСֵ |
2.5 µs |
| — ÖÜÆÚ³ÖÐøÊ±¼ä²âÁ¿£¬×î´óÖµ |
25 s |
| ¾«¶È |
| — ƵÂʲâÁ¿ |
100 ppm£»Óë²âÁ¿ÖÜÆÚºÍÐźŷÖÎöÓÐ¹Ø |
| — ÖÜÆÚ³ÖÐøÊ±¼ä²âÁ¿ |
| — ²âËÙ |
| µçλ¸ôÀë |
| Êý×ÖÊäÈëµçλ¸ôÀë |
| ¡ñ ÔÚͨµÀÖ®¼ä |
·ñ |
| ¡ñ ÔÚͨµÀÖ®¼ä£¬·Ö×éµãÊý |
16 |
| Êý×ÖÊä³öµçλ¸ôÀë |
| ¡ñ ÔÚͨµÀÖ®¼ä |
·ñ |
16 |
| ͨµÀµÄµçÊÆ·ÖÀë |
| ¡ñ ÔÚͨµÀºÍ±³°å×ÜÏßÖ®¼ä |
ÊÇ |
| ¡ñ ÔÚͨµÀºÍ¸ºÔصçѹ L+ Ö®¼ä |
·ñ |
| ¾øÔµ |
| ¾øÔµ²âÊÔ£¬Ê¹Óà |
707 V DC£¨²âÊÔÀàÐÍ£© |
| »·¾³ÒªÇó |
| ÔËÐÐÖеĻ·¾³ÎÂ¶È |
| ¡ñ ˮƽ°²×°£¬×îСֵ |
0 °C |
| ¡ñ ˮƽ°²×°£¬×î´óÖµ |
60 °C; ×¢ÒâÊÖ²áÖйØÓÚ°åÔØÍâΧÉ豸µÄ½µ¶î˵Ã÷£»ÏÔʾ£º50 °C£¬ÔËÐÐζÈΪµäÐÍÖµ 50 °C ʱ£¬ÏÔʾÆÁ¹Ø±Õ |
| ¡ñ ´¹Ö±°²×°£¬×îСֵ |
0 °C |
| ¡ñ ´¹Ö±°²×°£¬×î´óÖµ |
40 °C; ×¢ÒâÊÖ²áÖйØÓÚ°åÔØÍâΧÉ豸µÄ½µ¶î˵Ã÷£»ÏÔʾ£º40 °C£¬ÔËÐÐζÈΪµäÐÍÖµ 40 °C ʱ£¬ÏÔʾÆÁ¹Ø±Õ |
| ×é̬ |
| ±à³Ì |
| ±à³ÌÓïÑÔ |
| — KOP |
ÊÇ |
| — FUP |
ÊÇ |
| — AWL |
ÊÇ |
| — SCL |
ÊÇ |
| — GRAPH |
ÊÇ |
| ¼¼Êõ±£»¤ |
| ¡ñ Óû§³ÌÐò±£»¤ |
ÊÇ |
| ¡ñ ¸´ÖƱ£»¤ |
ÊÇ |
| ¡ñ Ä£¿é±£»¤ |
ÊÇ |
| ·ÃÎʱ£»¤ |
| ¡ñ ÏÔʾÆÁÃÜÂë |
ÊÇ |
| ¡ñ ·À»¤¼¶±ð£ºÐ´±£»¤ |
ÊÇ |
| ¡ñ ·À»¤¼¶±ð£º ¶Áд±£»¤ |
ÊÇ |
| ¡ñ ·À»¤¼¶±ð£º È«²¿±£»¤ |
ÊÇ |
| Ñ»·Ê±¼ä¼à²â |
| ¡ñ ÏÂÏÞ |
¿Éµ÷ÕûµÄ×î¶ÌÑ»·Ê±¼ä |
| ¡ñ ÉÏÏÞ |
¿Éµ÷ÕûµÄ×ѻ·Ê±¼ä |
| ³ß´ç |
| ¿í¶È |
85 mm |
| ¸ß¶È |
147 mm |
| Éî¶È |
129 mm |
| ÖØÁ¿ |
| ÖØÁ¿£¬Ô¼ |
1 050 g |
