AQ 4£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 4x U/I ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75184AP000AB0 CPU 1518-4 PN/DP£¬4 MB ³ÌÐò£¬20 MB Êý¾Ý£»1 ns£»¼¯³É 2x PN ½Ó¿Ú£¬2x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75173AP000AB0 CPU 1517-3 PN/DP£¬2 MB ³ÌÐò£¬8 MB Êý¾Ý£»2 ns£»¼¯³É 2x PN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP½Ó¿Ú
6ES75163AN010AB0 CPU 1516-3 PN/DP£¬1 MB ³ÌÐò£¬5 MB Êý¾Ý£»10 ns £»¼¯³É 2xPN ½Ó¿Ú£¬1x ÒÔÌ«Íø½Ó¿Ú£¬1x DP ½Ó¿Ú
6ES75152AM010AB0 CPU 1515-2 PN£¬500 KB ³ÌÐò£¬3 MB Êý¾Ý£»30 ns£»¼¯³É 2x PN ½Ó¿Ú,1x ÒÔÌ«Íø½Ó¿Ú
6ES75131AL010AB0 CPU 1513-1 PN£¬300 KB ³ÌÐò£¬1.5 MB Êý¾Ý£»40 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75111AK010AB0 CPU 1511-1 PN£¬150 KB ³ÌÐò£¬1 MB Êý¾Ý£»60 ns£»¼¯³É 2x PN ½Ó¿Ú
6ES75121CK000AB0 CPU 1512C-1 PN, 250 KB³ÌÐò£¬1 MBÊý¾Ý£»48 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 32 DI/32 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75111CK000AB0 CPU 1511C-1 PN, 175 KB³ÌÐò£¬1 MBÊý¾Ý£»60 ns£»¼¯³É2x PN½Ó¿Ú£»¼¯³É 16 DI/16 DO, 5 AI/2 AO, 6 HSC@100kHz
6ES75121DK010AB0 CPU 1512SP-1 PN£¬200KB ³ÌÐò£¬1 MB Êý¾Ý£»48 ns£»¼¯³É 1x PN ½Ó¿Ú (¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES75101DJ010AB0 CPU 1510SP-1 PN£¬100KB ³ÌÐò£¬750 KB Êý¾Ý£»72 ns£»¼¯³É 1x PN ½Ó¿Ú(¿ÉÓÃET 200SP×ÜÏßÊÊÅäÆ÷ÔÙÍØÕ¹2¸öPN ½Ó¿Ú)
6ES76772AA310EB0 CPU 1515SP PC,2 GB RAM,8 GB CFAST£» Ԥװ32λWINDOWS EMBEDDED STANDARD 7 E£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FB0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷
6ES76772AA410FK0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ128µãÊÚȨ)
6ES76772AA410FL0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ512µãÊÚȨ)
6ES76772AA410FM0 CPU 1515SP PC,4 GB RAM,16 GB CFAST£» Ԥװ64λWINDOWS EMBEDDED STANDARD 7 P£¬Ô¤×°CPU 1505S V1.7Èí¼þ¿ØÖÆÆ÷ºÍWINCC ADVANCED RUNTIME(´øÓÐ2048µãÊÚȨ)
6ES76727AC000YA0 CPU 1507S,VERSION 1.8(1¸ö¸¡µãÊÚȨ), ½öÄÜÔÚSIMATIC IPCÉÏʹÓÃ
6ES78062CD000YA0 S7-1500Èí¼þ¿ØÖÆÆ÷ÓÃODK£¬Ê¹ÓÃC/C++À©Õ¹S7-1500Èí¼þ¿ØÖÆÆ÷µÄ¹¦ÄÜ
6ES71936AR000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×RJ45
6ES71936AF000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×FC¿ìÁ¬Ê½
6ES71936AP000AA0 ×ÜÏßÊÊÅäÆ÷BA 2×SCRJ¹âÏË
6ES75455DA000AB0 S7-1510/1512 SP CPU DPͨÐÅÄ£¿é (RS-485 PROFIBUS-DP)
6ES79548LC020AA0 S7-1200/1500 4M ´æ´¢¿¨
6ES79548LE020AA0 S7-1200/1500 12M ´æ´¢¿¨
6ES79548LF020AA0 S7-1200/1500 24M ´æ´¢¿¨
6ES79548LL020AA0 S7-1200/1500 256M ´æ´¢¿¨
6ES79548LP010AA0 S7-1200/1500 2G ´æ´¢¿¨
6ES79548LT020AA0 S7-1200/1500 32G ´æ´¢¿¨
6ES71555AA000AB0 ET 200MP IM 155-5 PN ST ±ê×¼ÐͽӿÚÄ£¿é
6ES71555AA000AC0 ET 200MP IM 155-5 PN HF ¸ßÐÔÄÜÐͽӿÚÄ£¿é
6ES71555BA000AB0 ET 200MP IM 155-5 DP ST ±ê×¼ÐͽӿÚÄ£¿é
6ES75070RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ AC/DC 120/230 V
6ES75050RA000AB0 PS£º60 W£¬¶î¶¨ÊäÈëµçѹ DC 24/48/60 V
6ES75050KA000AB0 PS£º25 W£¬¶î¶¨ÊäÈëµçѹ DC 24 V
6EP1332-4BA00 PM 1507£º72W£¬ 24 V/3 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6EP1333-4BA00 PM 1507£º192W£¬ 24 V/8 A£¬¶î¶¨ÊäÈëµçѹ AC 120/230 V
6ES75325HF000AB0 AQ 8£ºÄ£ÄâÊä³öÄ£¿é£¬¸ßËÙ AQ 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325HD000AB0 AQ 4£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 4x U/I ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75325NB000AB0 AQ 2£ºÄ£ÄâÊä³öÄ£¿é£¬AQ 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75317KF000AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬AI 8x U/I/RTD/TC ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317NF100AB0 AI 8£ºÄ£ÄâÊäÈëÄ£¿é£¬¸ßËÙ£¬AI 8x U/I HS, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75317QD000AB0 AI 4£ºÄ£ÄâÊä³öÄ£¿é£¬AI 4x U/I/RTD/TC ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75347QE000AB0 AI4/AQ2£ºÄ£ÄâÁ¿ÊäÈë/Êä³öÄ£¿é AI/AO 4x U/I/RTD/TC 2x U/I ST, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BL000AB0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BL100AA0 DQ 32£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 32 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75221BH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A ST, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BH100AA0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¾§Ìå¹Ü DQ 16 x 24 VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75225FH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 16x 230 VAC/ 1A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HH000AB0 DQ 16£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 16x 230 VAC/ 2A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75221BF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¸ßÐÔÄÜ DQ 8x 24VDC/ 2A HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225FF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¿É¿Ø¹è DQ 8 x 230 VAC/ 2A ST (TRIAC), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75225HF000AB0 DQ 8£ºÊý×ÖÊä³öÄ£¿é£¬¼ÌµçÆ÷ DQ 8x 230VAC/ 5A ST (RELAY), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL000AB0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 32x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BL100AA0 DI 32£ºÊý×ÖÊäÈëÄ£¿é£¬DI 32x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH000AB0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬¸ßÐÔÄÜ DI 16x 24VDC HF, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211BH100AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 24VDC BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75211BH500AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬Ô´ÐÍ£¬DI 16x 24VDC SRC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75211FH000AA0 DI 16£ºÊý×ÖÊäÈëÄ£¿é£¬DI 16x 230V AC BA, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75231BL000AA0 DI16/DQ16£ºÊý×ÖÁ¿ÊäÈë/Êä³öÄ£¿é£¬16x 24VDC/16x 24VDC/ 0.5A BA, 25mmÄ£¿é£¬º¬Ç°Á¬½ÓÆ÷
6ES75501AA000AB0 TM Count 2 x 24 V£º2ͨµÀ¸ßËÙ¼ÆÊýÆ÷ÓëλÖòɼ¯(ÔöÁ¿ÐͱàÂëÆ÷£¬24VÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75511AB000AB0 TM PosInput 2£¬2ͨµÀ¼ÆÊýÓëλÖòɼ¯(ÔöÁ¿ÐÍ/¾ø¶ÔÖµ±àÂëÆ÷SSI£¬RS422ºÍ5V TTLÐźÅ), 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75521AA000AB0 TM Timer DIDQ 16x24V ´øÊ±¼ä´Á¡¢¸ßËÙ¼ÆÊý¡¢PWMµÈ¹¦ÄÜ, 35mmÄ£¿é£¬²»º¬Ç°Á¬½ÓÆ÷
6ES75401AB000AA0 PtP RS422/485 ͨѶģ¿é
6ES75411AB000AB0 PtP RS422/485£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75401AD000AA0 PtP RS232ͨѶģ¿é
6ES75411AD000AB0 PtP RS232£¬¸ßÐÔÄÜͨѶģ¿é£¨Ö§³ÖModbus RTU£©
6ES75901BC000AA0 S7-1500 °²×°µ¼¹ì£º2000 mm
6ES75901AJ300AA0 S7-1500 °²×°µ¼¹ì£º830 mm
6ES75901AF300AA0 S7-1500 °²×°µ¼¹ì£º530 mm
6ES75901AE800AA0 S7-1500 °²×°µ¼¹ì£º482 mm
6ES75901AC400AA0 S7-1500 °²×°µ¼¹ì£º245 mm
6ES75901AB600AA0 S7-1500 °²×°µ¼¹ì£º160 mm
6ES75922AX000AA0 ±êÇ©,35mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AX000AA0 ±êÇ©,25mmÄ£°åÊÊÓã¬100Ƭ
6ES75921AM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬Âݶ¤ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XB0 35mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75921BM000XA0 25mmÄ£°åǰÁ¬½ÓÆ÷£¬¿ìÁ¬ÐÍ£¬40Õ룬º¬4¸ùÌøÏß
6ES75905AA000AA0 "ÓÃÓÚÁ¬½ÓPE£¨µØ£©µ½S7-1500°²×°µ¼¹ìµÄ½ÓµØÔª¼þ£¬
¶ÔÓÚ2000mmµÄ°²×°µ¼¹ìÊDZØÐëµÄ ÿ¸ö°ü×°20Ƭ"
6ES75911AA000AA0 S7-1511/13CPUÏÔÊ¾Ãæ°å
6ES75911BA000AA0 S7-1515/16/17/18CPUÏÔÊ¾Ãæ°å
6ES75908AA000AA0 S7-1500 PS/PM¹©µçÄ£°åÁ¬½ÓÍ·£¬ÄÚº¬10Ƭ
6ES75280AA707AA0 ½Ó¿ÚÄ£¿é(6ES7 155-5AA00-0AB0)ǰ¸Ç°å5Ƭ/°ü
6ES75280AA007AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬35mmÄ£°åÊÊÓÃ
6ES75280AA000AA0 I/OÄ£¿éǰ¸Ç°å5Ƭ/°ü£¬25mmÄ£°åÊÊÓÃ
6ES75900AA000AA0 UÐÍÁ¬½ÓÆ÷,£¬5Ƭ/°ü
6ES75923AA000AA0 ÌøÏߣ¬20Ƭ/°ü
6ES75905CA000AA0 ÆÁ±ÎÌ×¼þ£ºº¬ÆÁ±Î¶Ë×Ó£¬¿ò¼ÜÒÔ¼°24VDC½ÓÏß¶Ë
6ES75905BA000AA0 Ä£ÄâÁ¿/¼¼ÊõÄ£°åרÓÃÆÁ±Î¶Ë×Ó
6ES76772AA300AA0 CPU 1515SP PC,2 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
6ES76772AA400AA0 CPU 1515SP PC,4 GB RAM,²»´øCFAST¿¨£¬ÎÞԤװÈí¼þ£¬½ö×÷±¸¼þʹÓÃ
¼¼ÊõÊý¾Ý
SIMATIC S7-1500, ANALOG OUTPUT MODULE AQ 4 X U/I ST; 16 BITS OF RESOLUTION, ACCURACY 0.3 %; 4 CHANNELS IN GROUPS OF 4; DIAGNOSIS, SUBSTITUTE VALUE INCL. INFEED ELEMENT, SHIELD CLAMP AND SHIELD TERMINAL |
| Ò»°ãÐÅÏ¢ |
| ²úÆ·ÀàÐͱêÖ¾ |
AQ 4xU/I ST |
| Ó²¼þ¹¦ÄÜ״̬ |
FS01 |
| ¹Ì¼þ°æ±¾ |
V2.0.0 |
| ¡ñ ¿É¸üй̼þ |
ÊÇ |
| ²úÆ·¹¦ÄÜ |
| ¡ñ I&M Êý¾Ý |
ÊÇ; I&M0 ÖÁ I&M3 |
| ¡ñ ¿É±äÊä³ö·¶Î§ |
·ñ |
| ¸½´ø³ÌÐò°üµÄ |
| ¡ñ STEP 7 TIA ¶Ë¿Ú£¬¿É×é̬ / ÒѼ¯³É£¬×Ô°æ±¾ |
V12 / V12 |
| ¡ñ STEP 7 ¿É×é̬/ ÒѼ¯³É£¬×Ô°æ±¾ |
V5.5 SP3 / - |
| ¡ñ PROFIBUS °æ±¾ GSD °æ / GSD ÐÞ¶©°æÒÔÉÏ |
V1.0 / V5.1 |
| ¡ñ PROFINET °æ±¾ GSD °æ / GSD ÐÞ¶©°æÒÔÉÏ |
v2.3 / - |
| ÔËÐÐģʽ |
| ¡ñ ¹ý²ÉÑù |
·ñ |
| ¡ñ MSO |
ÊÇ |
| RUN ģʽÏ嵀 CiR ÅäÖà |
| ¿ÉÔÚ RUN ģʽϸü¸Ä²ÎÊý·ÖÅä |
ÊÇ |
| ¿ÉÔÚ RUN ģʽÏÂУ׼ |
ÊÇ |
| µçÔ´µçѹ |
| ¶î¶¨Öµ (DC) |
24 V |
| ÔÊÐí·¶Î§£¬ÏÂÏÞ (DC) |
20.4 V |
| ÔÊÐí·¶Î§£¬ÉÏÏÞ (DC) |
28.8 V |
| ·´¼«ÐÔ±£»¤ |
ÊÇ |
| ÊäÈëµçÁ÷ |
| ºÄÓõçÁ÷£¬×î´óÖµ |
190 mA; 24 V DC ¹©µçʱ |
| ¹¦ÂÊ |
| À´×Ô±³°å×ÜÏߵŦÂÊÊä³ö |
0.6 W |
| ¹¦ÂÊËðʧ |
| ¹¦ÂÊËðʧ£¬µäÐÍÖµ |
4 W |
| Ä£ÄâÊä³ö |
| Ä£ÄâÊä³ö¶ËÊýÁ¿ |
4 |
| µçѹÊä³ö£¬¶Ì·±£»¤ |
ÊÇ |
| µçѹÊä³ö£¬¶Ì·µçÁ÷£¬×î´óÖµ |
24 mA |
| µçÁ÷Êä³ö£¬¿ÕÔØµçѹ£¬×î´óÖµ |
22 V |
| Ñ»·Ê±¼ä£¨ËùÓÐͨµÀ£© ×îСֵ |
3.2 ms; Ó뼤»îµÄͨµÀÊýÁ¿ÎÞ¹Ø |
| Êä³ö·¶Î§£¬µçѹ |
| ¡ñ 0 ÖÁ 10 V |
ÊÇ |
| ¡ñ 1 V ÖÁ 5 V |
ÊÇ |
| ¡ñ -10 V ÖÁ +10 V |
ÊÇ |
| Êä³ö·¶Î§£¬µçÁ÷ |
| ¡ñ 0 ÖÁ 20 mA |
ÊÇ |
| ¡ñ -20 mA ÖÁ +20 mA |
ÊÇ |
| ¡ñ 4 mA ÖÁ 20 mA |
ÊÇ |
| Ö´ÐÐÆ÷Á¬½Ó |
| ¡ñ ¶ÔÓÚÁ½ÏßÖÆ½Ó¿ÚµçѹÊä³ö |
ÊÇ |
| ¡ñ ¶ÔÓÚËÄÏßÖÆ½Ó¿ÚµçѹÊä³ö |
ÊÇ |
| ¡ñ ¶ÔÓÚÁ½ÏßÖÆ½Ó¿ÚµçÁ÷Êä³ö |
ÊÇ |
| ¸ºÔصç×裨ÔڶÊä³ö·¶Î§ÄÚ£© |
| ¡ñ µçѹÊä³ö¶ËµÄ×îСֵ |
1 kΩ; 1 ... 5 V ʱ 0.5 kOhm |
| ¡ñ µçѹÊä³ö¶ËµÄµçÈݸºÔØ£¬×î´óÖµ |
1 µF |
| ¡ñ µçÁ÷Êä³ö¶ËµÄ×î´óÖµ |
750 Ω |
| ¡ñ µçÁ÷Êä³ö¶ËµÄµç¸Ð¸ºÔØ£¬×î´óÖµ |
10 mH |
| µ¼Ïß³¤¶È |
| ¡ñ ÆÁ±Î£¬×î´óÖµ |
800 m; µçÁ÷ÖУ¬µçѹʱ 200 m |
| Êä³ö¶ËµÄÄ£ÄâÖµ¹¹³É |
| ¼¯³ÉºÍת»»Ê±¼ä/ÿͨµÀ·Ö±æÂÊ |
| ¡ñ ´øÓйýµ÷ÖÆµÄ·Ö±æÂÊ£¨°üÀ¨·ûºÅÔÚÄÚµÄλÊý£©£¬×î´óÖµ |
16 bit |
| ¡ñ ת»»Ê±¼ä£¨Ã¿¸öͨµÀ£© |
0.5 ms |
| ÆðÕñʱ¼ä |
| ¡ñ ¶ÔÓÚµç×è¸ºÔØ |
1.5 ms |
| ¡ñ ¶ÔÓÚµçÈݸºÔØ |
2.5 ms |
| ¡ñ ¶ÔÓÚµç¸Ð¸ºÔØ |
2.5 ms |
| Îó²î/¾«¶È |
| Êä³ö²¨ÎÆ£¨ÓëÊä³ö·¶Î§Óйأ¬´ø¿í 0 ÖÁ 50 kHz£©£¬(+/-) |
0.02 % |
| ÏßÐÔ´íÎó£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.15 % |
| ζȴíÎó£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.002 %/K |
| Êä³ö¶ËÖ®¼äµÄ´®ÈÅ£¬×î´óÖµ |
-100 dB |
| 25 °C ʱÆðÕñ״̬ϵÄÖØ¸´¾«¶È£¨ÓëÊä³ö·¶Î§Óйأ©£¬(+/-) |
0.05 % |
| Õû¸öζȷ¶Î§ÄڵIJÙ×÷´íÎóÏÞÖÆ |
| ¡ñ µçѹ£¬ÓëÊä³ö·¶Î§Óйأ¬(+/-) |
0.3 % |
| ¡ñ µçÁ÷£¬ÓëÊä³ö·¶Î§Óйأ¬(+/-) |
0.3 % |
| »ù±¾´íÎóÏÞÖÆ£¨25 °C ʱµÄ²Ù×÷´íÎóÏÞÖÆ£© |
0.2 % |
0.2 % |
| µÈʱģʽ |
| ½ÚÅÄͬ²½ÔËÐУ¨Ó¦ÓóÌÐòÖÁ¶Ë¿Úͬ²½£© |
·ñ |
| ±¨¾¯/Õï¶Ï/״̬ÐÅÏ¢ |
| Õï¶Ï¹¦ÄÜ |
ÊÇ |
| ¿É½ÓÈëÌæ´úÖµ |
ÊÇ |
| ±¨¾¯ |
| ¡ñ Õï¶Ï±¨¾¯ |
ÊÇ |
| Õï¶ÏÐÅÏ¢ |
| ¡ñ µçÔ´µçѹ¼à¿Ø |
ÊÇ |
| ¡ñ ¶ÏÏß |
ÊÇ; ½öÏÞµçÁ÷Êä³öÀàÐÍ |
| ¡ñ ¶Ì· |
ÊÇ; ½öÏÞµçѹÊä³öÀàÐÍ |
| ¡ñ Òç³ö/ÏÂÒç |
ÊÇ |
| Õï¶ÏÏÔʾ LED |
| ¡ñ RUN LED |
ÊÇ; ÂÌÉ« LED |
| ¡ñ ERROR LED |
ÊÇ; ºìÉ« LED |
| ¡ñ µçÔ´µçѹ¼à¿Ø (PWR-LED) |
ÊÇ; ÂÌÉ« LED |
| ¡ñ ͨµÀ״̬ÏÔʾ |
ÊÇ; ÂÌÉ« LED |
| ¡ñ ÓÃÓÚͨµÀÕï¶Ï |
ÊÇ; ºìÉ« LED |
| ¡ñ ÓÃÓÚÄ£¿éÕï¶Ï |
ÊÇ; ºìÉ« LED |
| µçλ¸ôÀë |
| ͨµÀµÄµçÊÆ·ÖÀë |
| ¡ñ ÔÚͨµÀÖ®¼ä |
·ñ |
| ¡ñ ÔÚͨµÀÖ®¼ä£¬·Ö×éµãÊý |
4 |
| ¡ñ ÔÚͨµÀºÍ±³°å×ÜÏßÖ®¼ä |
ÊÇ |
| ¡ñ ÔÚͨµÀºÍ¸ºÔصçѹ L+ Ö®¼ä |
ÊÇ |
| ÔÊÐíµÄµçλ²î |
| S ºÍ MANA (UCM) Ö®¼ä |
DC 8 V |
| ¾øÔµ |
| ¾øÔµ²âÊÔ£¬Ê¹Óà |
707 V DC£¨²âÊÔÀàÐÍ£© |
| ·Ö²¼Ê½ÔËÐÐ |
| °´ÓÅÏȼ¶Æô¶¯ |
·ñ |
| ³ß´ç |
| ¿í¶È |
35 mm |
| ¸ß¶È |
147 mm |
| Éî¶È |
129 mm |
| ÖØÁ¿ |
| ÖØÁ¿£¬Ô¼ |
310 g |
