免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → R&S CMW500 无线通信综合测试仪
产品名称: R&S CMW500 无线通信综合测试仪
型 号: CMW500
价 格: 0.00
品 牌:
 R&S CMW500 无线通信综合测试仪 测试标准    支持GSM、GPRS、EDGE、EDGE Evolution、Mobile WiMAX?、LTE FDD/TDD、TD-SCDMA、WCDMA/HSDPA、HSPA+、CDMA2000、1xEV-DO、GPS、Bluetooth、WLAN a/b/g/n、DVB-T、T-DMB、CMMB、FM stereo、Media FLO? 主要特性与技术指标1)基本模块:通用RF 功率计和带有List 模式的CW 发生器,可以完成无线设备的快速校准2)矢量信号分析仪(VSA)用来进行发射机验证3)矢量信号发生器(VSG)用来进行扩展的接收机测试:ARB 模式可以缩短配置时间或在线模式可以处理高数据容量的复杂信号4)通过直接连接R&S?NRP-Zxx 功率探头可启动参考RF 功率测量5)使用集成RF接口可方便地连接到具有复杂RF架构的无线设备6)当前先进的图形化用户界面(GUI)7)通过LAN/GPIB 接口进行SCPI 远程控制8)支持LXI Class C  B100A      CMW H100A Baseband Measurement UnitB110A      CMW H110A ARB+Realtime Baseband Generator ModuleB200A      CMW H200A Signaling Unit Universal(SUU)B230A      CMW H230A 1xEV-DO Signalling Extension Module for H200AB270A      CMW H270A WiMAX Signaling Extension Module for H200AB300A      CMW H300A Signaling Unit Wideband (SUW)B450A      Data application unitB510A      CMW H510A, four digital IQ interfaces (inputs/outputs/monitor)B520A      Digital I/Q 5 to 8 H520AB570A      CMW H570A RF converter module (TRX)B570B      CMW H570B RF converter module (TRX)B590A      CMW H590A RF Frontend moduleB612A      CMW H612A IEEE Bus Interface Module (single connector)B612B      CMW H612B IEEE Bus Interface Module (dual connector)B620A      CMW H620A Digital Video Interface (DVI) Module (only required for units with display/keB660A      CMW H660A Option CarrierB661A      CMW H661A Ethernet Switch BoardB690A      CMW H690A OCXO ModuleB690B      CMW H690B OCXO Module (highly stable)C3     3 years of calibration coverage based on the R&S recommended calibration interval - includes test data. The first calibration is included with product delivery with 2 additional depot calibration(s).C5     Five years of calibration coverage based on the R&S recommended calibration interval - includes test data. The first calibration is included with product delivery with 4 additional depot calibration(s).DCV-2       Documentation of calibration valuesKA700      Permanent CMW license: Application Enabler, extension Convergence Sublayer IPv4, WiMAX(IEEE802.16e)KB036      Permanent CMW license : Extended Frequency Range 3.3 GHz to 6 GHzKC420       Permanent CMW License: WCDMA R7 Test Cases 3GPP 34.123 Ciphering GCF WI-101KC421       Permanent CMW License: WCDMA R7 Test Cases 3GPP 34.123 CPC Tests GCF WI-070KC422       Permanent CMW license: WCDMA R7 test cases 3GPP 34.123 64QAM testsKC423       Permanent CMW license: WCDMA R7 test cases 3GPP 34.123 L2 enhancements testsKF502       Permanent CMW License: LTE FDD MLAPI Basic ProceduresKF503       LTE FDD MLAPI EPS Bearer VerificationKF504       Intra-LTE Handover and MobilityKG200      Permanent CMW licence: Generator, GSM/GPRS/EDGE, DownlinkKG400      Permanent CMW licence: Generator, WCDMA, DownlinkKG401      Permanent CMW license: Generator, WCDMA HSPA extension of CMW-KG400, DownlinkKM010     Permanent CMW license: FTT spectrum analyzerKM011     Permanent CMW license: TX measurement "IQ Versus Slot", UplinkKM012     Permanent CMW license: TX measurement Multi Evaluation List ModeKM200     Permanent CMW license: TX Measurement, GSM/GPRS/EDGE, UplinkKM400     Permanent CMW license: TX Measurement, WCDMA, uplinkKM401     Permanent CMW license: TX measurement, WCDMA HSPA, extension of CMW-KM400, UplinkKM403     Permanent CMW license: TX measurement, WCDMA HSPA+ extension of CMW-KM401, UplinkKM500     Permanent CMW license: TX measurement LTE FDD, UplinkKM610     Permanent CMW license: TX measurement, BluetoothKM650     Permanent CMW license: TX Measurement WLAN (IEEE 802.11a/b/g)KM700     Permanent CMW license: TX Measurements, Mobile WiMAX (IEEE 802.16e)KM701     Permanent CMW license: TX measurement, extension for R&D applications, WiMAX(IEEE802.16e), Wave 1KM750     Permanent CMW license: TX Measurement, TD-SCDMA, uplinkKM800     Permanent CMW license: TX Measurement, CMDA2000? 1xRTT, Reverse LinkKM880     Permanent CMW license: TX Measurement, 1xEV-DO, Reverse LinkKP080       Perm
公司名称: 深圳市中测仪修光电技术有限公司
电 话: 177 27475584 / 张经理
手机: 17727475584
地 址: 深圳市宝安区新安街道82区新安六路1003号华丰金融港A座9楼901
邮 编: 518101
主 页: www.zcyxiu.com
  • santec TSL-550 波长可调谐激光器1260-1680nm
  • keysight N1092E DCA-M 采样示波器
  • Keysight N1000A DCA-X 宽带宽示波器
  • 86106B 安捷伦 Agilent 86106B校准光通道
  • CBT32 R&S 罗德与施瓦茨 CBT/CBT32蓝牙测试仪
  • DSA8300 Tektronix DSA8300示波器
  • E5071B 安捷伦 Agilent E5071B 射频网络分析仪 9kHz-8.5GHz
  • Anritsu MT8852B 蓝牙综合测试仪
  • E8404A 安捷伦 Agilent E8404A 主机 C 型 VXI 主机,13 插槽
  • keysight N1078A 光/电时钟恢复主机
