免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 81525A 安捷伦 Agilent 81525A 大功率 InGaAs 光学探头
产品名称: 81525A 安捷伦 Agilent 81525A 大功率 InGaAs 光学探头
型 号: 81525A
价 格:
品 牌:
销售81525A,出租81525A,维修81525A,回收81525A,技术方案
81525A价格,81525A中文操作手册,81525A参数指标。
  81525A 安捷伦 Agilent 81525A 大功率 InGaAs 光学探头安捷伦 Agilent81525A光功率计探头安捷伦 Agilent81525A光功率计探头光万用表81525A是一种高功率InGaAs光学头。规格:5MM。 27-70 dBm.800到1650 nm。它是用在:HP8163A,HP8164A,HP8153A安捷伦 Agilent 81525A 大功率 InGaAs 光学探头,5 毫米详细资料:81525A|安捷伦 Agilent 81525A|HP 81525ASpecifications at a glance for the 81525A:Wavelength Range: 800 to 1650 nmDetector Type (Sensor Element): InGaAsDetector Size (diameter): 5 mmPower Range: -70 to +23 dBm (800 - 1650 nm)Wavelength Accuracy (Uncertainty): +/- 3.0% (900 to 1600 nm)Additional Information主要特性与技术指标The 安捷伦 Agilent optical power heads are specially designed for low PDL, low spectral ripple and high return loss and are used for optical component test. The heads come with a magnetic D-shape adapter and provide a safe stand.Applicable Fiber Type: Standard Single-mode And Multimode max. 100 um core size, NA < 0.3Linearity: -50 to +10 dBmConnector Type Options:81000FA: FC/PC connector adapter81000KA: SC/PC connector adapter81000PA: E-2000 connector adapter81000VA: ST/PC connector adapter81003LA : LC/PC connector adapterThe 81525A is a high power InGaAs optical head. Specs: 5mm. +27 to -70 dBm.800 to 1650 nm. It is used with: HP8163A, HP8164A, HP8153A. 8163a,8164a,81618a,81619a,81624b,81623a,81623b,81625a,81521b,81533b,81525a,8156a,81576a,81570a,81578a, n7744a,,86100A,86100C,86105A,86103A,83493A,83492A,83494A,81610A,81632B,81636BN5980A,86130A,86120B,86120C,86107A,86105C,86116CKEITHLEY ,2400,2420,6517b,2602a, 2612TEK DSA8200 80E04 80C08-CR4,80C02Anritsu 9710BYOKOGAWA 2201,2200-42186100C 安捷伦 Agilent 86100C 宽带示波器主机Tektronix DSA820086105C 安捷伦 Agilent 86105C 9 GHz光采样模块安捷伦 Agilent N9020A 信号分析仪R&S CMW500 无线通信综合测试仪keithley2400型通用性源表Keysight 是德3458A 数字多用表8156A 安捷伦 Agilent 8156A 光学衰减器81576A 安捷伦 Agilent 81576A 可变光衰减器模块81570A 安捷伦Agilent 81570A 可变光衰减器模块86100A 安捷伦 Agilent 86100A宽带示波器86105A 安捷伦 Agilent 86105A 模块86105D 安捷伦Agilent 86105D 模块Agilent 81578A-0628164A 安捷伦 Agilent 8164A 光波测量系统Keysight 是德N7744A 多端口光功率计Agilent 83494A-UK6yokogawa AQ6370D 光谱分析仪81642B安捷伦 Agilent 81642B 可调激光源Agilent 66319D 电源keithley6517B 型静电计/高阻表安捷伦 Agilent E5071C ENA 网络分析仪keithley2420型高压源表Anritsu MS9710BYOKOGAWA AQ2201 帧控制器Tektronix DPO5000 示波器Q8384Advantest  Q8384 光谱分析仪Agilent 8753ES S-参数矢量网络分析仪Anritsu MT8852B 蓝牙综合测试仪YOKOGAWA AQ2201 帧控制器Agilent 4339B 高电阻表3920IFR 3920 测试仪安捷伦 Agilent N5230C 系列微波网络分析仪N5230CFLUKE福禄克 5500A 多功能校准器8163A 安捷伦 Agilent 8163A 光波万用表系统81618A 安捷伦 Agilent 81618A接口模块81619A 安捷伦 Agilent 81619A 接口模块81624B 安捷伦 Agilent 81624B 通用光功率探头81623A 安捷伦 Agilent 81623A 探头81623b 安捷伦agilent 81623b光功率探头模块81625A 安捷伦 Agilent 81625A 探头大功率 81521B  安捷伦 Agilent HP 81521B 光功率探头 81533B安捷伦 Agilent 81533B光探头接口模块81525A 安捷伦 Agilent 81525A 大功率 InGaAs 光学探头86103A安捷伦 Agilent 86103A 光电模块83493A 光时钟恢复模块83492A 多模时钟恢复插入式模块81610A安捷伦 Agilent 81610A回损测试模块81632B安捷伦 Agilent 81632B光功率传感器81636B 安捷伦 Agilent 81636B 光功率传感器Keysight 是德N5980A 用于光电器件生产线的3125 Gbs生产用串行比特误码率测试仪BERT86130A安捷伦 Agilent 86130A 误码分析仪86120B安捷伦 Agilent 86120B波长计 86120C 安捷伦 Agilent 86120C 多波长计Agilent 86107AKeysight 是德86116C 40 至 65 GHz 光插入式模块和 80 GHz 电插入式模块Anritsu MS2602Akeithley 2612A 双通道系统数字源表80E04 tektronix 80E04 电接口取样模块Tektronix 80C08DTEKTRONIX 80C02-CR光电采样模块Keysight 是德N7752A 2 通道光衰减器和功率计SDA813Zi 力科Lecroy SDA813Zi 示波器MN9664A ANRITSU MN9664A光通道选择器MP1570A Anritsu MP1570A 多功能分析仪mp1632A 安立mp1632A 数字式分析仪N4906A  安捷伦 Agilent N4906A 比特误码率测试仪P80318 泰克P80318手持式探头Q8326 ADVANTEST Q8326 光波长计Q8341 ADVANTEST Q8341光谱分析仪81533A 安捷伦 Agilent HP 81533A 光功率模块81566A 安捷伦 Agilent 81566A 模块化衰减器81594B 安捷伦 Agilent 81594B 模块81613A 安捷伦 Agilent 81613A 回波损耗模块81634A 安捷伦 Agilent 81634A 光功率传感器模块81654A 安捷伦 Agilent 81654A 双法布里-珀罗激光源81689A 安捷伦 Agilent 81689A 压缩的可调激光81989A 安捷伦 Agilent 81989A 紧凑型可调激光源83482A 安捷伦 Agilent 83482A 模块83483A 安捷伦 Agilent 83483A 20 GHz 双通道电模块83485A 安捷伦 Agilent 83485A 模块8504B 安捷伦 Agilent 8504B Reflectometer8508A  安捷伦 Agilent 8508A 矢量电压表86060C 安捷伦 Agilent 86060C  光开关86105B 安捷伦 Agilent 86105B 模块86112A 安捷伦 Agilent 86112A 20 GHz双通道电模块86140B 安捷伦 Agilent 86140B 频谱分析器86145B 安捷伦 Agilent 86145B光谱分析仪8703A 安捷伦 Agilent 8703A 光波元器件分析仪E4805B 安捷伦 Agilent E4805B 中央时钟模块E4808A 安捷伦 Agilent E4808A 时钟模块E4832A 惠普/安捷伦E4832A 675兆赫数据发生器/分析仪模块E4835AZ 安捷伦 Agilent HP E4835AZ 插卡模块E4861A 安捷伦 Agilent E4861A 模块 2.7 Gb/s 和 1.65 Gb/s ParBERT E4861B 安捷伦 Agilent E4861B 3.35 Gb/s ParBERT 模块E8404A 安捷伦 Agilent E8404A 主机 C 型 VXI 主机,13 插槽"E8491B 安捷伦 Agilent E8491B IEEE-1394 PC Link to VXI,   C尺寸 (FireWire)"EST-125 JDSU EST-125和 EDT-135 E1 数据通信测试仪LM1000SFPS4 IXIA LM1000SFPS4 模块1000Mbps Ethernet Load ModuleMN9601A 安立Anritsu MN9601A光选择开关MN9662A 安立Anritsu MN9662A  光通道选抉器R3767CH 爱德万 ADVANTEST R3767CH网络分析仪TQ8325 ADVANTEST TQ8325 光波长计WA-7100 EXFO  WA-7100、WA-7600多波长计86116B 安捷伦 Agilent 86116B 模块 65 GHz光模块 / 80 GHz电模块E5071B 安捷伦 Agilent E5071B 射频网络分析仪 9kHz-8.5GHz81002FF 安捷伦 Agilent 81002FF 积分球Q82214 爱德万 Advantest  Q82214 功率传感器Q8221 爱德万 Advantest  Q8221 万用表MU163220A Anritsu 安立  MU163220A分析仪LM100T8 IXIA LM100T8以太网测试模块CSA8000 Tektronix CSA8000示波器CBT32 R&S 罗德与施瓦茨 CBT/CBT32蓝牙测试仪86106B 安捷伦 Agilent 86106B校准光通道E1339A 安捷伦 Agilent E1339A 通道数字输出/继电器驱动器E1459A 安捷伦 Agilent E1459A 64 通道隔离数字输入/中断E1412A 安捷伦 Agilent E1412A 6.5位万用表VXI模块E1466A 安捷伦 Agilent E1466A 继电器矩阵开关VXI模块E1563A 安捷伦 Agilent E1563A继电器矩阵开关VXI模块VXI-MXI-2 美国国家仪器 NI VXI-MXI-2 RAM仪器控制81495A 安捷伦 Agilent 81495A 参考接收机3245A 安捷伦 Agilent 3245A通用信号发生器400T IXIA 400T 测试仪6050A 安捷伦 Agilent 6050A 电源 6811B 安捷伦 Agilent 6811B C 功率源6812B 安捷伦 Agilent 6812B 交流电源6813B 安捷伦 Agilent 6813B 交流电源80A02 泰克Tektronix 80A02 EOS/ESD 保护模块80A05 泰克 Tektronix 80A05 电接口时钟恢复模块80C01-CR 泰克 Tektronix 80C01-CR 光测量模块80C07 泰克 Tektronix 80C07为多速率光测量模块 80C12 泰克 Tektronix 80C12 光接口模块81010BS 安捷伦 Agilent /HP 81010BS 分配器8153A 安捷伦 Agilent 8153A 光波万用表主机81551mn 安捷伦 Agilent 81551mn可调激光源81554SM 安捷伦 Agilent 81554SM 激光源模块 81626A 安捷伦 Agilent 81626A功率探头模块81628A 安捷伦 Agilent 81628A功率探头81635A  安捷伦 Agilent 81635A 双光功率传感器8169A 安捷伦 Agilent HP 8169A 光波偏振控制器81626B 安捷伦Agilent 81626B 大功率光探头86118A 安捷伦Agilent 86118A 探头 双 70+ GHz 电模块远程探头6813A 惠普HP安捷伦 Agilent 6813A 变频电源 81531A 安捷伦Agilent/HP/81531A/功率传感器模块81567A 安捷伦Agilent 81567A光学衰减器模块81571A 安捷伦Agilent 81571A 可变光衰减器模块81651A 安捷伦agilent 81651A光模块81625B 安捷伦agilent 81625B 大功率光探头N6732B  安捷伦agilent N6732B 基礎型直流電源模組81940A 安捷伦agilent 81940A 具有连续扫描模式的紧凑型可调激光源85082A 安捷伦agilent 85082A 50-Ohm Input 模块M9147A 安捷伦agilent M9147A PXI 射频多路复用器81640A 安捷伦agilent  81640A 可调激光源86100D 安捷伦agilent 86100D Infiniium DCA-X 宽带宽示波器主机CW2501P AMETEK-ELGAR CW2501P-114交流电源PLZ1004W Kikusui Electronics Corporation(菊水) PLZ1004W 电子负载2945A MARCONI马可尼2945A无线综合测试仪FSP30 罗德与施瓦茨R&S?FSP30 频谱分析仪 9KHz到30GHzAQ6370 Yokogawa 横河 Ando AQ6370光谱分析仪3260BWayne Kerr 3260B 测试分析仪MW8208AAnritsu 安立 MW8208A 功频谱分析仪N5532A安捷伦 Agilent N5532A 模块6914MARCONI马可尼 6914 Power SensorN9923A安捷伦 Agilent N9923A 网络分析仪 2604B吉时利 keithley 2604B 万用表 248-SHV吉时利 keithley 248-SHV 电源 SMR60罗德与施瓦茨R&S SSMR60 數位示波器SMR50罗德与施瓦茨R&S SMR50 數位示波器 ATS-1AUDIO PRECISION ATS-1801PCalifornia Instruments 801P 电源IHA-1900ASUMMITEK IHA-1900A 分析仪CRT-400Albert CRT-400 分析表 DL9140Yokogawa 横河 DL9140 示波器 SR5500思博伦 Spirent SR5500 仿真测试仪ESIB40 R&S ESIB40 EMI测试接收机 TAP3500泰克Tektronix TAP3500 探头TT1000ABarfield TT1000A  涡轮温度测绘仪TDS3044B泰克Tektronix TDS3044B 数字荧光示波器SMR40罗德与施瓦茨R&S SMR40 信号发生器 SW5250AElgar SW5250A 电源366XAnritsu 安立 366X 校准套件3100LAEMI 3100LA 放大器 N5998A安捷伦 Agilent N5998A 分析仪.N4375B安捷伦 Agilent N4375B 26.5 GHz 单模光波元器件分析仪N7714A安捷伦 Agilent N7714A 4 端口可调激光系统信号源Keysight 是德N1501A 介电探头套件Keysight 是德85072A 10 GHz 分裂圆柱体谐振腔体Keysight 是德B2201A 14 通道低泄漏开关主机Keysight 是德B2200A fA 级低泄漏开关主机Keysight 是德E5250A 低漏电开关主机Keysight 是德B1500A 半导体器件参数分析仪Keysight 是德B1505A 功率器件分析仪/曲线追踪仪Keysight 是德E5270B 精密型 IV 分析仪Keysight 是德E5260A 8 插槽高速测量主机Keysight 是德E5263A 2 通道Keysight 是德E5262A 2 通道 高速电源监测单Keysight 是德B2912A 精密型电源Keysight 是德B2911A 精密型电源Keysight 是德B2902A 精密型电源Keysight 是德B2901A 精密型电源Keysight 是德N7748A 高性能光功率计Keysight 是德N7731A 双通道  4 光开关Keysight 是德N7734A  13 光开关Keysight 是德N7711A 单端可调激光系统信号源Keysight 是德N7745A 多端口光功率计Keysight 是德N7751A 单通道光衰减器和功率计Keysight 是德N7761A 单通道可变光衰减器Keysight 是德N7762A 2 通道可变光衰减器Keysight 是德N7764A 4 通道可变光衰减器Keysight 是德N7766A 2 通道多模光衰减器Keysight 是德N7768A 4 通道多模光衰减器Keysight 是德N7747A 高性能光功率计Keysight 是德81134A 双通道3 35 GHz脉冲码型发生器Keysight 是德81602A 超大功率可调谐激光源Keysight 是德81606A 可调谐激光源Keysight 是德81607A 可调谐激光源Keysight 是德81609A 步进可调谐激光源Keysight 是德81960A 快速扫描紧凑型可调谐激光源 1505nm 至 1630nmKeysight 是德81980A 具有连续扫描模式的紧凑型可调激光源 1465 nm 至 1575 nmKeysight 是德N7788B 光元器件分析仪Keysight 是德N7781B 偏振分析仪Keysight 是德N7782B 台式 PER 分析仪Keysight 是德N7783B 热循环设备Keysight 是德N7784B 高速偏振控制器RS TS8991 OTA性能测试系统RS TS8996 RSE 测试系统RSFSU8 频谱分析仪 20Hz到8HzRSFSU26 频谱分析仪 20Hz到26.5HzRSFSU43 频谱分析仪 20Hz到43GHzRSFSU46 频谱分析仪 20Hz到46GHzRSFSU50 频谱分
Keithley 2500 数字源表
Keithley 2502 数字源表
KEITHLEY 6221 电流源表
Tektronix 80e04 双通道时域反射计
Keysight 11708A 衰减器垫
Keithley 2001A 数字多用表
Keithley 2400-C 数字源表
Agilent 34570A 数字万用表
Keysight 3458A 数字多用表
Keysight 34903A GP开关块
Agilent 44476A 微波复用器块
Anritsu 69347B 信号源
Agilent 70004A 光谱分析仪
Keithley 7001半导体开关系统
Tektronix 80C02 光采样块
Agilent 81000FI 光纤连接器
Agilent 81002FF 积分球
Agilent 81521B 光功率计探头
Agilent 81524A 光功率探头
Agilent 8152 大功率光学探头
Agilent 81533A 接口块
Agilent 81533B 接口块
Agilent 81536A 光功率计传感插件
HP 8153A 光功率计
HP 8153B 光波万用表
HP 81551MM 点光源块
Agilent 81560A 可变光衰减器
Agilent 81567A 可变光衰减器块
Agilent 8156A 光衰减器
Keysight 81570A 可变光衰减器块
Agilent 81578A可变光衰减器块
Agilent 8157A 光衰减仪
HP 8158B 可编程光衰减器
Keysight 81595B 光开关
Agilent 81610A回损测试块
Keysight 81618A 接口块
Agilent 81619A 光功率块
Keysight 81623B 锗光功率探头
Agilent 81624A 光学探头
Agilent 8162 光功率探头
Agilent 81625B 大功率光探头
Keysight 81626B 大功率光探头
Keysight 81630B 大功率光传感器
Agilent 81633A 分布式反馈(DFB)激光器
Keysight 81634B 低偏振相关光功率传感器
Agilent 8163 双光功率传感器
Keysight 81636B 光功率传感器
Agilent 81637B 快速功率计
Agilent 8163A光功率计主机
keysight 8163B 光波万用表
Agilent 81640A 可调激光源
Agilent 8164A 光波测量系统主机
Agilent 8164B 光波测量系统
Agilent 81650A 单法布里-珀罗激光源
Agilent 81651A 光源块
Agilent 81654A 法布里-珀罗激光源
Agilent 81662A 分布式反馈(DFB)激光器
Agilent 8168E 可调谐激光源
Newport 818-IG高性能光电二极管传感器
Keysight 82357B GPIB 卡
Agilent 83440D光波转换器
Agilent 83480A 数字通信分析仪
Agilent 83483A 双通道电块
Agilent 83486A 光电块
Agilent 83487A 光电块
Agilent 83492A 多时钟块
Agilent 83493A 单时钟恢复块
Agilent 83494A 单时钟恢复块
Agilent 8349 时钟恢复块
Agilent 83496A 光电时钟恢复块
Agilent 83497A 光电时钟恢复块
HP 83540A 插件信号源
HP 8595E 频谱分析仪
Agilent 86100A DCA宽带宽示波器
Agilent 86100D DCA-J宽带示波器主机
Agilent 86102A 光电块
Agilent 86103A 光电块
Agilent 86103B 光电块
Agilent 8610 光电块
Agilent 86105B 光电块
keysight 86105B 光电采样块
Keysight 86105C 光电采样块
keysight 86105C 光电采样块
Keysight 86105D 光电块
Agilent 86106B 光电块
Agilent 86107A 精密时基参考块
keysight 86115D 并行光收发信机测试块
keysight 86116C 40/65/80GHz 光电块
Agilent 86120B 多波长计
Agilent 86120C 多波长计
Agilent 86140B 光谱分析仪
Agilent 86142A 光谱分析仪
Agilent 86142B 高性能光谱分析仪
Agilent 86146b 光谱分析仪
Newport 918-IG 高性能光电二极管传感器
Newport 918-ir 高性能光电二极管传感器
Ando AQ2140光功率计
YOKOGAWA AQ2200-421 单槽型光开关
YOKOGAWA AQ2201 帧控制器主机
Ando AQ2730光功率计块
Ando AQ2742 光功率传感器
Ando AQ2743 光功率传感器
Andu AQ-4137 光源
Andu AQ-4142 光源
Ando AQ4211LD组件
Ando AQ4215 光功率计
ANDO AQ6317B 光谱分析仪
yokogawa AQ6370 光谱分析仪
Yokogawa AQ6370D 光谱分析仪
Tektronix DPP125B 误码仪
Tektronix DSA8200 采样示波器
Tektronix DSA8300 数字采样示波器
Keysight E3631A 三路输出电源
Agilent E5061A ENA-L 射频网络分析仪
Photom EP-712 光功率计
R&S FSP3 频谱分析仪
Ericsson FSU-975 光纤熔接机
R&S FSV7 信号分析仪
IFR GPS-101定位系统拟器
Jdsu HA9 光衰减器
Exfo IQS-3150 可变衰减器
Keysight J7231B 抖动通信性能分析仪
CVI Melles Griot 05-LHP-211-1
Anritsu MN9610B光衰减器
Anritsu MS9710B 光谱分析仪
Anritsu ms9710c 光谱分析仪
Anritsu MS9740A 台式光谱分析仪
keysight N1092A DCA-M采样示波器(一个光通道)
keysight N1092B DCA-M采样示波器
keysight N1092C DCA-M采样示波器
keysight N1092D DCA-M采样示波器
keysight N1092E DCA-M采样示波器
keysight N1077A 光/电时钟恢复模块
keysight N1076B 电时钟恢复模块
keysight N1078A 光/电时钟恢复模块
keysight Keysight N1055A 远程探头
keysight N1030A 光通信插入式模块
keysight N1040A 电通信插入式模块
keysight N4391A 光调制分析仪
keysight N4877A 接收机和发射机
Agilent N4901B BERT比特误码率测试仪
Keysight N5181A 射频拟信号发生器
Agilent N5980A 误码率测试仪
keysight N7734A 1x13 光开关
Agilent N7740A 多端口光功率计
Keysight N7744A 多端口光功率计
keysight N774 多端口光功率计
Keysight N7748A 高性能光功率计
keysight N7761A 单通道可变光衰减器
keysight N7762A 2通道可变光衰减器
keysight N7764A 4通道可变光衰减器
keysight N7766A 2通道多光衰减器
keysight N7768A 4通道多光衰减器
keysight N8973A 噪声系数分析仪
R&S NRPZ51 射频功率计
R&S NRPZ55 射频功率计
R&S NRP-Z55 射频功率计
JDSU OLP-55 光功率计
NI PCI GPIB小卡
Picometrix PT-12B 光电转换芯片
NI PXI-1031 板卡
USHIO UXM-Q256BY点光源
EXFO WA-1650 光波长计
光示波器/眼图仪—Agilent 86100A, Agilent 86100B, Agilent 86100C, Agilent 86100D,Agilent 8610, Agilent 86105B, Agilent 86116C, Agilent 86105D, Agilent 86103A, Agilent 86106B, Agilent 86103B, Agilent 83493A, Agilent 83496A, Agilent 86118A, Agilent 54754A,Tektronix DSA 8300,Tektronix DSA 8200,Tektronix 80C08,Tektronix 80C15,Tektronix 80C07, Tektronix 82A04,Tektronix 80E04,Anritsu MP2100B
光谱分析:Agilent 86142B, Agilent 86146B,Agilent 86140B,Anritsu MS9740A,Anritsu MS 9710C,Anritsu MS9710B,Yokogawa 6317B,Yokogawa:6370D
波长计:Agilent 86122A,Agilent 86120B,Agilent 86120C,EXFO WA1600,EXFO WA1650,EXFO WA1100
光衰减器:Agilent 8156A,Agilent 8157A,Agilent 81570A,Agilent 81571A,Agilent 81576A,Agilent 81577A,Agilent 81567A,JDSU HA-9
光万用表:Agilent 8164A,Agilent 8164B,Agilent 8163A,Agilent 8163B,Agilent 8153A,Agilent 8166B,Agilent N7744A,Agilent N774,Agilent N7748A,Agilent 81632B,Agilent 81633A,Agilent 81634A,Agilent 81634B,Agilent 8163,Agilent 81636B,Agilent 86137B,Agilent 81623A,Agilent 81623B,Agilent 81624A,Agilent 81624B,Agilent 8162,Agilent 81625B,Agilent 81626B,Agilent 81628B,Agilent N7752A
误码仪:Agilent N5980A,Agilent N4901A,Agilent N4903A,Agilent N4906A
光开关:Agilent 81595B,Agilent 86062C,JDSU SB optical switch
可调光源:Agilent 81640A,Agilent 81642A,Agilent 81680A,Agilent 81682A,Agilent 81600B
网络分析仪:Agilent E5071C,Agilent 8722ES,Agilent 8720ES,Agilent E5061B,Agilent E5062A,R&S ZNB
射频信号源:Agilent E4438C,Agilent 8257D,Agilent N5181A,Agilent N5182A,Aglent N5182B,Agient N5183A,Agilent 8257D,Akeysight E8257D 精度指标 gilent 8267D
频谱分析仪:Agilent E4440A,Agilent N9010A,Agilent N9020A,Agilent N9030A
Wifi/蓝牙测试仪:Anritsu 8852B,LitePoint IQxel 80,,LitePoint IQXEL 160,,LitePoint 2011,,LitePoint IQ flex,Agilent N4010A
公司名称: 深圳市中测仪修光电技术有限公司
电 话: 177 27475584 / 张经理
手机: 17727475584
地 址: 深圳市宝安区新安街道82区新安六路1003号华丰金融港A座9楼901
邮 编: 518101
主 页: www.zcyxiu.com
  • santec TSL-550 波长可调谐激光器1260-1680nm
  • keysight N1092E DCA-M 采样示波器
  • Keysight N1000A DCA-X 宽带宽示波器
  • 86106B 安捷伦 Agilent 86106B校准光通道
  • CBT32 R&S 罗德与施瓦茨 CBT/CBT32蓝牙测试仪
  • DSA8300 Tektronix DSA8300示波器
  • E5071B 安捷伦 Agilent E5071B 射频网络分析仪 9kHz-8.5GHz
  • Anritsu MT8852B 蓝牙综合测试仪
  • E8404A 安捷伦 Agilent E8404A 主机 C 型 VXI 主机,13 插槽
  • keysight N1078A 光/电时钟恢复主机
