Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú »ªÎªME906E»ªÎª4GÄ£¿é
²úÆ·Ãû³Æ£º »ªÎªME906E»ªÎª4GÄ£¿é
ÐÍ ºÅ£º ME906E
ÁªÍ¨2G+ÁªÍ¨3G+ÁªÍ¨4G FDD-LTE
µçÐÅ4G FDD-LTE
ÒÆ¶¯EDGE ÍøÂç
 Ö§³ÖÁªÍ¨LTE WCDMA GPRS£¨¼´ÁªÍ¨4G.3G.2G£©Í¬Ê±Ö§³ÖµçÐÅLTE Only(µçÐÅ4G)£¬LTE NGFF½Ó¿ÚÎÞÏßͨÐÅÄ£¿é
HUAWEI ME906E Series LTE M.2 Module
 General Features
LTE (FDD) B1/B2/B3/B5/B7/B8/B20
?Quad-band DC-HSPA+/HSPA+/HSPA/UMTS 2100/1900/900/850 MHz
?Quad-band EDGE/ GPRS/GSM 1900/1800/900/850 MHz
?GNSS GPS L1: 1575.42 MHz Glonass L1: 1602 MHz
?Receive persity DC-HSPA+/HSPA+/HSPA/UMTS 2100/1900/900/850 MHz MIMO HSPA+/DC-HSPA+ DL 2*2 MIMO LTE: DL 2*2 MIMO
? Max. transmitter power WCDMA/HSPA+:+24dBm (Power Class 3) GSM/GPRS 1900MHz/1800MHz: +30dBm (Power Class 1) GSM/GPRS 900M/850MHz: +33dBm (Power Class 4) EDGE 1900MHz/1800MHz: +26dBm (Power Class E2) EDGE 900M/850MHz: +27dBm (Power Class E2) LTE:Accorded with 3GPP TS 36.101 R8 Class 3(23dBm)?Control via AT commands 3GPP TS 27.007 and TS 27.005 Huawei extended AT command? SIM card supply voltage 1.8V/3.0 V UICC (SIM/UICC/UIM), ISIM supported? Supply voltage range 3.135V~4.4V (3.3 V recommended)?Temperature range Normal operation: -10°C to +55°C Extended operation: -20°C to +70°C Storage: -40°C to +85°C? Humidity: 5% - 95%? Dimensions: 42 mm x 30 mm x 2.3 mm? Weight: <6gOS: Windows 7 / Windows 8 / Android 4.0CEFCCGCFRoHS Compliant/ Halogen freeOperator TA: Vodafone, Telefonica, Telstra, TMOGeneral FeaturesInterfacesApprovals & CertificationsData FeaturesSMS FeaturesAdditional Features?GPRS/EDGE: Multi-slot Class 12?WCDMA PS: UL (384 kbps)/ DL (384 kbps)?DC-HSPA+ :UL (5.76 Mbps)/DL (42 Mbps)?LTE FDD: UL (50 Mbps)/ DL (100 Mbps) @Bandwidth 20M (CAT3)?Supporting MO and MT?Supporting formats of PDU?Point-to-point and cell broadcast?Antenna interfaces x 2?NGFF Socket 2 USB 2.0 interface high speed Power supply UICC interface?GNSS: GPS Standalone, A-GPS, GPS XTRA, Glonass?SIM Hotswap?IPV6?BodySAR?Ultrabook feature support(ACT,QC, WiFi Offload , DPTF)?Tunable AntennaNote:Please refer to the latest version of Hardware Guide about the
¹«Ë¾Ãû³Æ£º ÉîÛÚÊв©»¸¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83039550 / Àîºã
ÊÖ»ú£º 13392864818
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÒæÌïÄÏÂ·ÒæÌﻨ԰
ÓÊ ±à£º 518000
Ö÷ Ò³£º http://www.broad-tech.com
  • ÖÐÐË£¨ZTE£©MF833U1 4Gdongle
  • ¹ãºÍͨ4GÄ£¿éL716-CN
  • ÖÐÐË3GÄ£¿éMF206A
  • ÖÐÐËÄÚÖÃ3GÄ£¿é MF206(WCDMA)
  • ¹ãºÍͨG510ÎÞÏßGSMͨÐÅÄ£¿é
  • ¹ãºÍͨSQ808 SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨģ¿éSU806-CN SOCÖÇÄÜÄ£×é
  • ¹ãºÍͨMA510-GLÈýÄ£ÎïÁªÄ£¿é
  • ¹ãºÍͨFM150 5GͨÐÅÄ£¿é
  • N700¹ãºÍͨģ¿éLPWAÄ£¿é
