²úÆ·ÃèÊö
OMEGA пÃÐÍÍòÓÃÊý×ÖÒDZíDP20ϵÁиßÐÔÄÜ¡¢ÒײÙ×÷£¬¿ÉÓ¦ÓÃÓÚ¶àÖÖ¹¤ÒµÓÃ;¡£¸Ã¿îÒDZí¿É½ÓÊܸ÷ÀàÊäÈëÐźţ¬°üÀ¨Èȵçż¡¢²¬µç×è¡¢ÈÈÃôµç×è¡¢¹ý³ÌÊäÈë(mA & Vdc)¡¢×迹, ºÍÕæÓÐЧֵµçѹºÍµçÁ÷Ðźš£Í¨¹ýÉèÖã¬DP20ϵÁпÉÒÔ±ä³ÉAC/DC µçѹÒDZí (up to 600V) »òÕß AC/DC µçÁ÷ÒDZí (up to 5A)Ϊ¹¤Òµ¼°Ïà¹Ø¿ØÖÆÁìÓòÌṩÁé»î¶àÑùµÄÓ¦Ó᣹ú¼Ê±ê×¼µÄµçÔ´ÊäÈëʹµÃDP20ϵÁпÉÒÔÔÚÈκιú¼Ò·ÅÐÄʹÓÃ.
Êä³öÖÖÀà°üÀ¨¼ÌµçÆ÷¡¢Ä£ÄâÐźš¢ModbusͨѶÐźÅΪ¿Í»§ÌṩÁËרҵµÄ¿ØÖƼ°Í¨Ñ¶·½°¸¡£ÆäËûÐÔÄÜÀýÈçÁ½ÖÖ±ÈÀýµ÷½Ú¡¢ÃÜÂë±£»¤ÒÔ¼°¿ÉÑ¡ÔñСÊýµãÊý¶¼Ê¹µÃÕâ¿îÒDZí³öÀà°ÎÝÍ¡£
¼¼Êõ²ÎÊý
ÏÔʾÊý×Ö: 4
¶ÁÊý·¶Î§: 9999 / -1999
СÊýµãÊý: ¿ÉÑ¡Ôñ
ÏÔʾÆÁÑÕÉ«: ºìÉ«
Êý×ָ߶È: 14 mm (0.55")
ÊäÈëÐźŷ¶Î§:ÍòÓÃÊäÈ룬ÏêÇé¼û²Ù×÷ÊÖ²á
AC Voltages and AC Currents: 600 Vac, 200 Vac, 20 Vac, 2 Vac, 200 mVac, 60 mVac, 5 Aac, 20 mAac (True RMS measure) (accepts phase-neutral and phase-phase measure)
DC Voltages and DC Currents: ±600 Vdc, ±200 Vdc, ±20 Vdc, ±2 Vdc, ±200 mVdc, ±60 mVdc, ±5 Adc, ±20 mAdc
Èȵçż: K, J, E, N, L, R, S, B, T and C (×Ô¶¯Àä¶Ë²¹³¥)
²¬µç×è¼°ÈÈÃôµç×è:
Resistive ‘Pt’ Probes: Pt100 with 2 and 3 wires, Pt500, Pt1000
Resistive ‘Ni’ Probes: Ni100, Ni200, Ni1000
Resistive NTC Probes: ÏêÇé¼û²Ù×÷ÊÖ²á
Resistive PTC Probes: Families KTY-121, KTY-210 and KTY-220
¹ý³ÌÊäÈë: 4/20 mA, 0/10 Vdc (+15 Vdc excitation voltage configurable at terminal 5)
×迹: Ranges 0/5 K and 0/50 K
µçλÆ÷: With nominal values from 500 R up to 20 K
ÈÈת»¯²¹³¥¶Î: 150 ppm/ºC
²ÉÑùËÙÂÊ: 3 readings/ second
Ë¢ÐÂƵÂÊ: 3 readings/ second
·´Ó¦Ê±¼ä: <300 mSec. (0 % to 99 % of signal)
µçÔ´: 18 to 265 Vac/dc (isolated 1500 Veff @ 60 seconds)
Êä³ö¼°¿ØÖÆÑ¡Ïî:
Ò»¸ö»òÁ½¸ö¼ÌµçÆ÷Êä³ö£¬»òÒ»¸ö¸ôÀëµÄÄ£ÄâÊä³ö4/20ºÁ°²
Ò»¸ö Modbus RTU isolated serial Êä³ö
Íâ¿Ç±ê×¼: NEMA 4 (IP65)
ÏûºÄ (Õý³£Ä£Ê½): <1.0 W (meter only) <2.5 W (meter with options)
ÏûºÄ (Ê¡µçģʽ): <0.3 W (meter only) <1.5 W (meter with options)
ÁªÏß: Plug-in screw terminals
ÖØÁ¿: <150 g (5.3 oz)
¹¤×÷ζÈ: 0 to 50ÉãÊÏC (32 to 122»ªÊÏF)
¡ñ ÕæÓÐЧֵ¹¦ÂÊÒÇ
¡ñ ×Ô¶¯Ê¡µçģʽ¼°ÃÜÂë±£»¤
¡ñ 5ÖÖÁÁ¶Èµ÷½Ú£¬¿Éµ÷½Ú¶ÁÊý±ä»¯
¡ñ ¶ÀÁ¢µÄË«Êä³ö±¨¾¯, ¿ÉÉèÖÃ×î´ó/×îСֵ
¡ñ ¶ÔÓÚͬһÖÖÐźż°¿ØÖÆ¿ÉÌṩÁ½ÖÖ±ÈÀýµ÷½Ú
¡ñ ¿ìËٲ˵¥¼ü¿ÉÑ¡Ôñ±¨¾¯ÉèÖúÍ×î´ó×îСÄÚ´æÖµ
¡ñ 5ºÅ¶Ë¿Ú¿É½ÓÍⲿ¿ØÖÆÊä³ö (µÚ¶þÖÖ±ÈÀýµ÷½Ú, ¶ÁÊý¾«¶Èµ÷½Ú, ±£Áô¶ÁÊý»ò¼¤»î×î´ó×îСÄÚ´æÖµ)
¡ñ Êä³ö¿ØÖÆÑ¡Ôñ: 1»ò2¸ö¼ÌµçÆ÷Êä³ö, 1¸ö4 to 20 mA¸ôÀëÄ£ÄâÊä³ö, 1 Modbus RTU ¸ôÀëͨѶÊä³ö
¡ñ Ïà¹ØÓ¦ÓÃ
¡ñ ¹¤³§Éú²ú¼°×é×°Ïß
¡ñ ×Ô¶¯»¯³µ¼äµç×Ó¿ØÖƹñ
¡ñ´óѧ¼°Ñо¿»ú¹¹ÊµÑéÊÒ
