²úÆ·¸ÅÊö
½ÜºÍ¹¤¿ØÕû»úAS20ÊÇ»ùÓÚIntel® Bay trailƽ̨´¦ÀíÆ÷£¬Ö§³Ö1x SO-DIMM DDR3LÄڴ棬ÌṩmSATA½Ó¿ÚºÍ2.5´çSATA½Ó¿Ú£¬1¸öÈ«¸ßMini PCIe²å²ÛÀ©Õ¹WiFi/BT/3G/4GÄ£×飬֧³ÖVGA»òDVI½Ó¿ÚÏÔʾ£¬ Ö§³Ö6¸ö¸ßËÙ´®¿ÚÊý¾Ý´«Êä¡£ÎÞ·çÉȽðÊôÉ¢ÈÈÉè¼Æ£¬¹ã·ºÓ¦ÓÃÓÚÖÇÄܵçÍø£¬ÄÜÔ´¹ÜÀíºÍ¹¤ÒµÉú²ú¿ØÖƵȳ¡ºÏ¡£
²úÆ·ÌØµã£º
¡ö ²ÉÓÃIntel® Bay Trailƽ̨´¦ÀíÆ÷
¡ö²ÉÓÃ1x SO-DIMM DDR3LÄڴ棬×î´ó¿ÉÀ©Õ¹ÖÁ8GB
¡ö Ö§³Ö1x VGA»ò1x DVIÏÔʾ½Ó¿ÚÊä³ö
¡ö Ö§³ÖmSATA£¬SATA¶àÖÖ´æ´¢·½Ê½
¡ö Ö§³Ö1x USB 3.0£¬5x USB 2.0 £¬6x COM
¡ö Ö§³Ö1x RJ45£¬1x È«¸ßMini-PCIeÀ©Õ¹WiFi/BT/3G/4G£¬1x SIM¿¨²Û
²úÆ·¹æ¸ñ
ÐͺÅ
Giada AS20
´¦ÀíÆ÷
CPU
Intel® Atom E3815
Ö÷Ƶ
1.46 GHz
BIOS
AMI Source Code
оƬ×é
Intel SOC Chipset
ÄÚ´æ
¹æ¸ñ
DDR3L-1067MHz
²å²Û
1x SO-DIMM
×î´óÄÚ´æ
8GB
ͼÐÎÏÔʾ
GPU
Intel® HD Graphics
ͼÐÎÒýÇæ
DirectX 11.1, OpenGL 3.0, OCL 1.1, OpenGL ES 2.0
VGA/DVI
1x VGA/DVI(Max.2560x1600@60Hz)
Íø¿¨
¿ØÖÆÆ÷
2x I210IT Gigabit Ethernet
ÍøÂç½Ó¿Ú
2 x RJ45
I/O½Ó¿Ú
USB
1x USB 3.0, 5 x USB 2.0
´®Ðж˿Ú
6x RS232/ RS422/RS485
GPIO
4Bit x DI(ESD protection for 15KV),4Bit x DO(Compatible 5V/TTL)
Mini-PCIe
1x È«¸ßMini-PCleÀ©Õ¹Wifi/BT/3G/4G
SIM
1x SIM Slot
LED Indicators
3x PWR/RUN/HDD LED,6x 2 COM LED,4x 2LAN LEN
´æ´¢
SATA
1x 2.5” SATA
mSATA
1x È«¸ßmSATA
ÎÞÈËÖµÊØ¼¼Êõ
JAHC
¿´ÃŹ·¼ÆÊ±Æ÷/×Ô¶¯¿ª¹Ø»ú/RTC
²Ù×÷ϵͳ
Windows
Windows 7/8.1/10
Linux
Ö§³Ö
µçÔ´ÒªÇó
¹©µçÀàÐÍ
Phoenix Contact 2-pin connector with lock
µçÔ´ÊÊÅäÆ÷
12V-24V
ÎïÀíÌØÐÔ
Íâ¿Ç²ÄÁÏ
½ðÊô
³ß´ç
170 mm x 70mm x 127mm
ÑÕÉ«
ºÚÉ«
Íⲿ»·¾³
¹¤×÷ζÈ
-40°C -70°C £¨-40°F -158°F£©at 0.7m/s Air Flow
Ïà¶Ôʪ¶È
90%@70°C£¨·ÇÄý½á£©
Íⲿ»·¾³
°²È«±ê×¼
CE/FCC Class B, CCC
¸ü¶à²úÆ·ÏêϸÐÅÏ¢£¬Çëµã»÷ǰÍù½ÜºÍ¹ÙÍø£ºhttp://www.giadatech.com.cn/index/product/detail/aid/262.html
