²úÆ·¸ÅÊö
½ÜºÍ¹¤¿ØÕû»úAE67ÊÇ»ùÓÚIntel® Kabylakeƽ̨´¦ÀíÆ÷£¬²ÉÓÃ˫ͨµÀDDR3LÄÚ´æÉè¼Æ£¬ÌṩmSATA½Ó¿ÚºÍ2.5´çSATA½Ó¿Ú£¬1¸öÈ«¸ßMini PCIe²å²ÛÀ©Õ¹WiFi/BT/3G/4GÄ£×飬֧³ÖDP+HDMI+VGAÏÔʾ½Ó¿ÚÊä³ö£¬ Ö§³Ö4x USB 3.0,4x USB 2.0,4x RS232,4x RS485£¬ÎÞ·çÉȽðÊôÉ¢ÈÈÉè¼Æ£¬¹ã·ºÓ¦ÓÃÓÚÖÇÄܵçÍø£¬ÄÜÔ´¹ÜÀíºÍ¹¤ÒµÉú²ú¿ØÖƵȳ¡ºÏ¡£
²úÆ·ÌØµã
¡ö ²ÉÓÃIntel® Kabylakeƽ̨´¦ÀíÆ÷
¡ö ²ÉÓÃ˫ͨµÀDDR3LÄÚ´æÉè¼Æ£¬×î´ó¿ÉÀ©Õ¹ÖÁ32GB
¡ö Ìṩ1x DP+1x HDMI+1x VGAÏÔʾ½Ó¿ÚÊä³ö
¡ö Ö§³ÖmSATA£¬SATA¶àÖÖ´æ´¢·½Ê½
¡ö Ö§³Ö4x USB 3.0£¬4x USB 2.0£¬4x RS232£¬2xRE485
¡ö Ö§³Ö1x RJ45£¬1x È«¸ßMini-PCIeÀ©Õ¹WiFi/BT/3G/4G£¬1x SIM¿¨²Û
²úÆ·¹æ¸ñ
ÐͺÅ
Giada AE67
´¦ÀíÆ÷
CPU
Intel® Core i5-7200U/Pentium 4415U
Ö÷Ƶ
2.5 GHz / 2.3 GHz
BIOS
AMI Source Code
оƬ×é
SOC
ÄÚ´æ
¹æ¸ñ
DDR3L-1600MHz
²å²Û
2x SO-DIMM
×î´óÄÚ´æ
32GB
ͼÐÎÏÔʾ
GPU
Intel® HD Graphics 620
ͼÐÎÒýÇæ
Direct3D 2015, OpenGL 5.0, OpenCL 2.1
DP
1x DP (Max.4096x2304@60Hz)
HDMI
1x HDMI (Max.4096x2304@24Hz)
VGA/DVI
1x VGA (Max.2048x1536@50Hz)
Íø¿¨
¿ØÖÆÆ÷
1x IntelI219 Gigabit Ethernet
ÍøÂç½Ó¿Ú
1x RJ45
I/O½Ó¿Ú
USB
4x USB 3.0, 4 x USB 2.0
´®Ðж˿Ú
4x RS232,£¨RS485 can be set in BIOS£©,2x RS485£¨·ï»Ë¶Ë×Ó£©
ÒôƵ½Ó¿Ú
1x 2-in-1 Headset(AUDIO-OUT&SPDIF)
Mini-PCIe
1x È«¸ßMini-PCleÀ©Õ¹Wifi/BT/3G/4G
SIM
1x SIM ¿¨²Û
M.2
1x M.2£¨2230£©À©Õ¹WiFi
´æ´¢
SATA
1x 2.5” SATA
mSATA
1x È«¸ßmSATA
ÎÞÈËÖµÊØ¼¼Êõ
JAHC
¿´ÃŹ·¼ÆÊ±Æ÷/×Ô¶¯¿ª¹Ø»ú/RTC/Ô¶³Ì¿ØÖÆ
²Ù×÷ϵͳ
Windows
Windows 7/8.1/10
Linux
Ö§³Ö
µçÔ´ÒªÇó
¹©µçÀàÐÍ
DC-IN
µçÔ´ÊÊÅäÆ÷
19V/2.42A
ÎïÀíÌØÐÔ
Íâ¿Ç²ÄÁÏ
½ðÊô
°²×°·½Ê½
Ö§³Ö×ÀÃæ°²·Å£¨±ê×¼·½Ê½£©£¬Ö§³ÖVESA¹Ò¼Ü£¨JZ300£©
³ß´ç
259.87 mm x 173.4mm x 38.5mm
ÑÕÉ«
ºÚÉ«
Íⲿ»·¾³
¹¤×÷ζÈ
-20°C-60°C £¨-4°F -140°F£©at 0.7m/s Air Flow
Ïà¶Ôʪ¶È
90%@40°C£¨·ÇÄý½á£©
Íⲿ»·¾³
°²È«±ê×¼
CE/FCC Class B, CCC
¸ü¶à²úÆ·ÏêϸÐÅÏ¢£¬Çëµã»÷ǰÍù½ÜºÍ¹ÙÍø£ºhttp://www.giadatech.com.cn/index/product/detail/aid/836.html
