²úÆ·¸ÅÊö
½ÜºÍǶÈëʽÖ÷°åDT-H81DL·ûºÏIntel®±ê×¼³¬±¡Mini-ITX¼Ü¹¹£¬²ÉÓÃIntel®H81оƬ£¬Ö§³ÖÓ¢ÌØ¶û®Haswellƽ̨´¦ÀíÆ÷£¬Ö§³ÖVGA¡¢HDMI ¡¢LVDSÏÔʾÊä³ö£»Ìṩ2¸öMini-PCIeÀ©Õ¹²å²Û£¬·Ö±ðÖ§³ÖmSATAÐźŠ/ WiFi/BTÄ£¿é£¬ÊÊÓÃÓÚÊý×Ö±êÅÆ¡¢½ÌÓýÓõç×Ó°×°å¡¢³¬±¡Ò»Ìå»úµÈÉ豸¡£
²úÆ·ÌØµã
¡ö °åÔØIntel®Haswell ƽ̨´¦ÀíÆ÷
¡ö ²ÉÓÃ2x U-DIMM DDR3 Äڴ棬×î´óÀ©Õ¹16GB
¡ö Ìṩ1x VGA+1x HDMI1x LVDSÏÔʾ½Ó¿ÚÊä³ö
¡ö Ö§³Ö3x SATA£¬1¸öMini-PCIeÀ©Õ¹mSATAÐźÅ
¡ö Ö§³Ö2x USB 3.0£¬4x USB 2.0£¬1x RS232
¡ö Ö§³Ö2x RJ45,Ö§³ÖMini-PCIeÀ©Õ¹WiFi/BTÄ£¿é
²úÆ·¹æ¸ñ
²úÆ·Ãû³Æ
Giada DT-H81DL
´¦ÀíÆ÷
CPU
Intel® H81+LGA1150
BIOS
AMI Source Code
оƬ×é
H81
ÄÚ´æ
¹æ¸ñ
DDR3L-1333MHz
²å²Û
2x U-DIMM
×î´óÄÚ´æ
16GB
ͼÐÎÏÔʾ
ÏÔʾ½Ó¿Ú
1x HDMI£¨Max.1920 x 1080@60Hz£©
1x DVI£¨Max.1920 x 1080@60Hz£©
1x VGA£¨Max.1920 x 1080@60Hz£©
Íø¿¨
¿ØÖÆÆ÷
2× Realtek RTL8111H Gigabit Ethernet
ÍøÂç½Ó¿Ú
2×RJ45
ÍⲿI/O½Ó¿Ú
USB
ÒôƵ½Ó¿Ú
1x MIC-IN,1x LINE-IN,1x LINE-OUT
´®ÐнӿÚ
1x RS232
ÄÚ²¿I/O½Ó¿Ú
USB²åÕë
4x USB 2.0
PCIe
1x PCIe x 16
´®¿Ú²åÕë
5x RS232
Mini PCIe
1x È«¸ßMini PCIeÀ©Õ¹mSATA
1x È«¸ßMini PCIeÀ©Õ¹WiFi/BT
´æ´¢
SATA
3x SATA
mSATA
1x mSATA
ÎÞÈËÖµÊØ¼¼Êõ
JAHC
¿´ÃŹ·¼ÆÊ±Æ÷/×Ô¶¯¿ª¹Ø»ú/RTC
²Ù×÷ϵͳ
Windows
Windows 7/8.1/10(64-bit)
Linux
Ö§³Ö
µçÔ´ÒªÇó
¹©µçÀàÐÍ
ATX 24+4pin
PCB
³ß´ç
170mm x 170mm
Íⲿ»·¾³
¹¤×÷ζÈ
0-60¡æ(32~140°F)
Ïà¶Ôʪ¶È
95%@60¡æ(·ÇÄý½á)
Íⲿ»·¾³
°²È«±ê×¼
CE/FCC Class B,CCC
¸ü¶à²úÆ·ÏêϸÐÅÏ¢£¬Çëµã»÷ǰÍù½ÜºÍ¹ÙÍø£ºhttp://www.giadatech.com.cn/index/product/detail/aid/839.html
