Æ·ÅÆ£ºFIBOCOM ÐͺÅ:L710-CN ÐÅÏ¢´«ËÍÄÚÈÝ:¶¼¿ÉÒÔ Ö§³ÖÍøÂç:2G/3G/4G Ƶ¶Î:850/900/1800/1900 ÌìÏßÁ¬½Ó·½Ê½:¶¼ÓÐ ¶ÌÐÅϢģʽ:¶¼¿ÉÒÔ ÒôƵ½Ó¿ÚÐÍʽ:¶¼ÓРͨѶ½Ó¿ÚÐÍʽ:¶¼ÓÐ µç»°±¡¹¦ÄÜ:ÓÐ ÍâÐγߴç:51x30x3.4mm. Product Feature • LTE FDD: Band 1/3/5/8 • LTE TDD: Band 34/38/39/40/41 • WCDMA: Band 1/8 • TD-SCDMA: Band 34/39 • GSM/GPRS/EDGE: 900M/1800MHz • MiniPCIe 51x30x3.4mm • Operating temperature£º -40¡æ~+85¡æ • Storage Temperature: -45¡æ~+90¡æ • Operating Voltage: 3.3V~4.4V • AT Command Set: 3GPP TS 27.007 and 27.005, proprietary FIBOCOM AT commands • TX Power GSM900: 32.5 dBm±1dB DCS1800: 29.5dBm±1dB WCDMA : 23.5dBm±1dB TD-SCDMA: 23.5dBm±1dB LTE FDD: 23.0dBm±1dB LTE TDD: 23.0dBm±1dB
