Kvaser USBcan工程师开发的第一选择
广州密创力电子科技有限公司
一.USB产品
1.
Kvaser USBcan Professional with MagiSync?
CAN/USB interface with two channels
Application support
ATI Apollo
ATI CANlab
ATI Vision
Ficosa CANica
Kvaser CanKing
National Instruments LabView
National Instruments DIAdem
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows 2000/XP/Server 2003, Windows 98/ME,
WinCE
Linux
The Kvaser USBcan Professional provides two CAN bus interfaces through a single USB connection. When combined with the Kvaser Linx the Kvaser USBcan Professional also supports bus types like LIN, J1587 and SWC.
The Kvaser USBcan Professional supports Kvaser's MagiSync technology to synchronize time stamps across multiple units without extra wires providing flexibility for multi-channel applications. With quick reaction times and high data throughput, the Kvaser USBcan Professional is perfect for rapid ECU re-flashing, advanced bus analyzers, and efficient development work.
Major features of Kvaser USBcan Professional
One device for desktop and laptop.
Quick and easy plug-and-play installation.
Automatic and accurate clock synchronization between several Kvaser USBcan Professional interfaces through Kvaser MagiSync. The technical solution is unique and patented by Kvaser.
Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifiers.
Support for different bus types through Kvaser Linx, e.g LIN, SWC, J1587
CAN Messages are time-stamped and synchronized with a precision of 2 microsecond.
Large on-board RAM buffer for CAN message.
Handles up to 40 000 messages per second.
Excellent error handling.
Supports silent mode for analyzing tools.
Galvanic isolation of the CAN bus driver stage to protect the hardware.
Labeled CAN channel for easy identification of the supported physical layer.
100% compatible with applications written for all Kvaser hardware with KVASER's CANlib.
Interfaces the CAN bus with a 9-pin D-SUB connector.
Designed for USB 2.0, backward compliant with USB 1.1.
A practically unlimited number of Kvaser USBcan Professional devices can be connected via standard USB hubs for simultaneous use on a single PC.
Automatically switches power supply between CAN (primary) and USB (secondary), to reduce power drain of laptop battery.
Driver support for major operating systems.
100% compatible with applications written for Leaf, LAPcan, PCIcan, andPCcan with KVASER's CANlib.
Two high-speed channels with ISO 11898-2 compliant CAN transceivers, 10 kbit/s up to 1 Mbit/s.
Plastic housing with dimension W*L*H about 50*90*25 mm (approx 2 x 3,5 x 1 inch)
Software and documentation
Kvaser CANLIB SDK , which includes everything you need todevelop software for the Kvaser CAN boards. Includes full documentation and many program samples, written in C, C++,Delphi, Visual Basic, and C#. All Kvaser CAN interface boards share a common software API. Programs written for one board type will run without modifications on the other board types!
J2534 Application Programming Interface
RP1210A Application Programming Interface
On-line documentation in Windows HTML-Help and Adobe Acrobat format.
Software and drivers can be downloaded for free atwww.kvaser.com.
Download the User's Guide in PDF fromat.
Download the product sheet in PDF format.
Read about Kvaser MagiSync.
Download Kvaser USBcan Product Comparison Table
Product versions
Kvaser USBcan Professional HS/HS (Item No. 00357-6)
Two high-speed channels with ISO 11898-compliant transceivers (TJA1050)
Product kits
Kvaser USBcan Professional Kit for J1587 (Item No. 00377-4)
The kit includes the Kvaser USBcan Professional HS/HS (Item No. 00357-6) and the Kvaser Linx J1587 (Item. No. 00389-7).
Kvaser USBcan Professional Kit for LIN (Schedule for Q1, 2007)
The kit includes the Kvaser USBcan Professional HS/HS (Item No. 00357-6) and the Kvaser Linx LIN (Schedule for Q1, 2007).
Kvaser USBcan Professional Kit for K-line (Schedule for Q1, 2007)
The kit includes the Kvaser USBcan Professional HS/HS (Item No. 00357-6) and the Kvaser Linx K-line (Schedule for Q1, 2007).
Kvaser USBcan Professional Kit for SWC (Schedule for Q1, 2007)
The kit includes the Kvaser USBcan Professional HS/HS (Item No. 00357-6) and the Kvaser Linx SWC (Schedule for Q1, 2007).
Kvaser USBcan Professional Kit for LS (Schedule for Q1, 2007)
The kit includes the Kvaser USBcan Professional HS/HS (Item No. 00357-6) and the Kvaser Linx LS (Schedule for Q1, 2007).
<< 回到产品目录
2.
Kvaser Leaf Professional with MagiSync
USB/CAN interface with extreme performance
Application support
ATI Apollo
ATI CANlab
ATI Vision
Ficosa CANica
Kvaser CanKing
National Instruments LabVIEW
VAT 2000
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows XP/2000/Server 2003; Windows 98/ME;
Linux (in progress)
Kvaser Leaf Professional with MagiSync is a one channel USB interface for CAN and LIN. It offers the possibility to easily connect several interfaces to a PC. T he time-stamping is synchronized through Kvaser MagiSync. Providing flexibility and making it perfect for multi-channel applications. High-Speed, Low-Speed and Single-Wire CAN and LIN are supported through different product versions.
Major features
Automatic and accurate clock synchronization between several Kvaser Leaf Professional interfaces through Kvaser MagiSync. The technical solution is unique and patented by Kvaser.
Messages are time-stamped and synchronized with a precision of 1 microsecond.
Handles up to 20 000 messages per second.
Auto transmit buffers, to send messages on a defined interval.
Auto response buffers, to send messages on a defined event.
Low power consumption.
Excellent EMC performance.
Polyurethane cabling for extreme environments.
Equipped with a 110 cm (44 in.) long USB cable and a 30 cm (12 in.) long CAN cable.
Quick and easy Plug-and-Play installation.
A practically unlimited number of Kvaser Leafs can be connected via standard USB hubs for simultaneous use on a single PC.
Please note that not all applications listed under Application Support for Kvaser Leaf Professional, support the Kvaser Leaf Professional LIN product version.
Kvaser CANLIB SDK , which includes everything you need to develop software for the Kvaser CAN boards. Includes full documentation and many program samples, written in C, C++, Delphi, Visual Basic, and C#. All Kvaser CAN interface boards share a common software API. Programs written for one board type will run without modifications on the other board types!
Documentation, software and drivers can be downloaded for free fromwww.kvaser.com, or they can be purchased on CD if preferred. Updates of the software are regularly posted on the web.
Kvaser CanKing for Windows, a general-purpose interactive CAN bus monitor/analyzer with special support for CanKingdom and DeviceNet.
Product versions
Kvaser Leaf Professional HS (Item No. 00243-2)
One channel USB-to-bus interface for High-Speed CAN (ISO 11898-2).
Handles a bit rate from 5 kbits/s up to 1 Mbits/s.
Kvaser Leaf Professional LS (Item No.00261-6)
One channel USB-to-bus interface for Low-Speed CAN (ISO 11898-3).
Handles a bit rate from 5 kbits/s up to 125 kbits/s.
Kvaser Leaf Professional SWC (Item No.00264-7)
One channel USB-to-bus interface for Single-Wire CAN (SAE J2411, GMLAN).
Handles a bit rate from 5 kbits/s up to 50 kbits/s (100 in high-speed mode)
Kvaser Leaf Professional LIN (Item No. 00269-2)
One channel USB-to-bus interface for LIN.
<< 回到产品目录
3.
Kvaser USBcan II
CAN/USB interface with one or two channels
Application support
ATI Apollo
ATI CANlab
ATI Vision
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
WinCE
Linux
The Kvaser USBcan II provides a dual channel CAN bus interface with a standard USB interface. One CAN channel is for High-Speed CAN. The second optional CAN channel can be ordered for High-Speed, Low-Speed as well as Single-Wire CAN.
Major features of Kvaser USBcan II
CAN messages are time-stamped with 10 microseconds resolution.
Supports ”listen-only” mode for analyzing tools.
1 00% compatible with applications written for Leaf, LAPcan, PCIcan, and PCcan with KVASER's CANlib.
Very good error handling
One CAN connection for High-Speed CAN, 50 kbit/s up to 1 Mbit/s (transceiver Philips TJA1050), and one for either Low-Speed (transceiver Philips TJA1054), Single-Wire ( transceiver Philips AU5790) or High-Speed CAN ( transceiver Philips TJA1050 ).
One USB 1.1 connection (12 Mbit/s) that is USB 2.0 compliant
Power from CAN-bus or from the USB side.
Product versions
Kvaser USBcan II HS/HS (Item No. 00159-6)
Kvaser USBcan II HS (Item No. 00158-9)
One high-speed channel with ISO 11898-compliant transceiver (TJA1050)
Kvaser USBcan II HS/LS (Item No. 00174-9)
One high-speed channel with ISO 11898-compliant transceiver (TJA1050). One low-speed channel with TJA1054 transceiver.
Kvaser USBcan II HS/SWC (Item No. 00231-9)
One high-speed channel with ISO 11898-compliant transceiver (TJA1050). One single-wire channel with AU5790 transceiver.
4.
Kvaser Leaf SemiPro with MagiSync
USB/CAN interface with high performance
Application support
ATI Apollo
ATI CANlab
ATI Vision
Ficosa CANica
Kvaser CanKing
VAT 2000
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows XP/2000/2003;
Windows 98/ME;
Linux (in progress)
Kvaser Leaf SemiPro with MagiSync is a one channel USB interface for CAN. It offers the possibility to easily connect several interfaces to a PC. T he time-stamping is synchronized through Kvaser MagiSync. Providing flexibility and making it perfect for multi-channel applications. High-Speed, Low-Speed and Single-Wire CAN are supported through different product versions.
Major features
Automatic and accurate clock synchronization between several Kvaser Leaf SemiPro interfaces through Kvaser MagiSync. The technical solution is unique and patented by Kvaser.
Messages are time-stamped and synchronized with a precision of 25 microsecond.
Handles up to 15 000 messages per second.
Reliable error handling.
1 00% compatible with applications written for all Kvaser hardware with KVASER's CANlib.
Kvaser CanKing for Windows, a general-purpose interactive CAN bus monitor/analyzer with special support for CanKingdom and DeviceNet .
Product versions
Kvaser Leaf SemiPro HS (Item No. 00242-5)
Kvaser Leaf SemiPro LS (Item No.00260-9)
Kvaser Leaf SemiPro SWC (Item No.00263-0)
<< 回到产品目录
5.
Kvaser USBcan Rugged
CAN/USB interface with 1 or 2 CAN channels and a solid design
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
The Kvaser USBcan Rugged has a CAN bus interface with a standard USB interface. The Kvaser USBcan Rugged can be ordered with two High-Speed CAN channels (TJA1050 compliant), or one channel.
Major features of Kvaser USBcan Rugged
High-performance driver support for major operating systems.
100% compatible with applications written for Leaf, LAPcan, PCIcan, and PCcan with KVASER's CANlib.
One CAN connection ISO-11898 High speed, 50 kbit/s up to 1 Mbit/s (transceiver Philips TJA1050).
Optional, second CAN connection that can be either low-speed (transceiver Philips TJA1054) or high-speed (ISO-11898).
Extensive software support
IP54 classed
Rugged metal housing
Fault tolerant electrical CAN interface
Additional software and documentation
Documentation software and drivers can be downloaded for free atwww.kvaser.com or purchased separately on CD if preferred.
Product versions
Kvaser USBcan Rugged HS/HS (Item No. 00181-7)
Kvaser USBcan Rugged HS (Item No. 00180-0)
<< 回到产品目录
6.
Kvaser Leaf Light
USB/CAN interface with high performance for budget applications
Application support
ATI Apollo
ATI CANlab
ATI Vision
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Xtm
Software Platforms
Windows XP/2000/2003; Windows 98/ME;
Linux (in progress)
Kvaser Leaf Light is a one channel USB interface for CAN. It offers the possibility to easily connect several interfaces to a standard PC.
Major features
CAN messages are time-stamped with a precision of 100 microseconds.
Handles up to 8000 messages per second.
Supports data and remote frames.
Detects error frames.
Very good EMC performance.
Low power-consumption.
Product versions
Kvaser Leaf Light HS (Item No. 00241-8)
<< 回到产品目录
二.数据记录器
7.
Kvaser Memorator Professional
CAN/USB interface and data logger
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Linux (in USBcan Professional mode)
Kvaser Memorator Professional provides the functionality of a standalone CAN bus data logger and a USB CAN bus interface in a single device. When combined with the Kvaser Linx, the Kvaser Memorator Professional also supports bus types like LIN, J1587, and SWC.
As a data logger, the Kvaser Memorator Professional is the perfect tool to capture irregular faults in the field or perform remote diagnosis. A great advantage is that all configurations are made with a user-friendly configuration program and are stored on the flash disk. It makes it both easy and convenient to set configurations with the PC and download it to Kvaser Memorator Professional for use in the field. The Kvaser Memorator Professional has a USB connection and can be used as a powerful USB CAN bus interface (like our Kvaser USBcan Professional ).
Functions in Kvaser Memorator Professional
Triggers and Data Logger capabilities
Kvaser Memorator can log continuously, or logging can be triggered by creating advanced triggers based on messages, data signal values, error messages, external trigger's falling or rising edge, and I/O signals.
Pre- and post-triggers are available without buffer size restrictions, limited by disk space only.
Handles up to 20 000 msgs/s in standalone logger mode.
Transmit messages to the bus network.
External digital output that can drive a LED or a buzzer.
< 250 ms boot up time.
Supports Silent Mode – log bus traffic safely without interfering and ”listen-only” mode for bus analysis tools.
Filters
Kvaser Memorator Professional can filter out selectable messages and/or signals to be logged. The identifiers can be picked from a database, or all messages can be logged.
Support for pass as well as stop filters.
Create a counting pass filter to have a message logged at enumerated occurrence.
Memory cards and functions
Standard MMC or SD type flash memory cards can be used - up to 2GB.
Larger SDHC cards supported in the future – up to 32GB. See our support pages for more information.
Set up several devices in a daisy chain for larger logging capacity.
Transfer recorded data over the USB interface at 1.4 MB/s or an SD card reader at 15 MB/s.
Configuration software in the PC
Easy to use graphic configuration tool – Kvaser Memorator Professional Setup Tool.
Configuration of the CAN controller, i.e. bit rate and filters.
Configuration of the trigger conditions.
Configuration of filter for messages to be stored.
Configuration upload and download via USB.
Using the included Kvaser Dispatcher software, a complete measurement setup can be turned into a self-installing package that is sent to a remote location to carry out a specific logging task.
Major features of Kvaser Memorator
Functionality of a standalone CAN bus data logger and a USB CAN bus interface in a single device.
Support for different bus types through Kvaser Linx, e.g LIN, SWC, J1587.
Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B) identifiers.
CAN messages are time-stamped with 2 microseconds resolution.
Large on-board RAM buffer for CAN messages.
100% compatible with applications written for Kvaser Leaf, LAPcan, PCIcan, PCcan, USBcan, etc., with Kvaser's CANlib.
Two CAN connections ISO-11898-2 high-speed, 10 kbit/s up to 1 Mbit/s.
Galvanic isolation to protect the hardware.
130mA current consumption.
Operating temperature range from -40 to + 85 oC
Power from CAN bus or from the USB side.
Built-in real time (calendar) clock with battery backup.
Logger status is indicated with five externally visible LEDs.
Plastic housing with dimension W*L*H about 50*90*25 mm (circa 2 x 3,5 x 1 inch)
Kvaser CANLIB SDK , which includes everything you need to develop software for the Kvaser CAN boards. Includes full documentation and many program samples, written in C, C++, C#, Delphi, and Visual Basic. All Kvaser CAN interface boards share a common software API. Programs written for one board type will run without modifications on the other board types!
Documentation, software and drivers can be downloaded for free atwww.kvaser.com or purchased separately on CD if preferred.
Download the product sheet for Kvaser Memorator Professional.
Download the User's Guide in PDF format.
Download Kvaser Memorator Product Comparison Table.
Product versions
Kvaser Memorator Professional HS/HS (Item No. 00351-4)
Two high-speed channels with ISO 11898-2 compliant CAN transceivers. Support for different bus types through Kvaser Linx, for example LIN, SWC, J1587.
Product kits
Kvaser Memorator Professional Kit for J1587 (Item No. 00383-5)
The kit includes the Kvaser Memorator Professional HS/HS (Item No. 00351-4) and the Kvaser Linx J1587 (Item. No. 00389-7).
Kvaser Memorator Professional Kit for LIN (Scheduled for Q1, 2007)
The kit includes the Kvaser Memorator Professional HS/HS (Item No. 00351-4) and the Kvaser Linx LIN (Scheduled for Q1, 2007).
Kvaser Memorator Professional Kit for K-line (Scheduled for Q1, 2007)
The kit includes the Kvaser Memorator Professional HS/HS (Item No. 00351-4) and the Kvaser Linx K-line (Schedule for Q1, 2007).
Kvaser Memorator Professional Kit for SWC (Scheduled for Q1, 2007)
The kit includes the Kvaser Memorator Professional HS/HS (Item No. 00351-4) and the Kvaser Linx SWC (Scheduled for Q1, 2007).
Kvaser Memorator Professional Kit for LS (Scheduled for Q1, 2007)
The kit includes the Kvaser Memorator Professional HS/HS (Item No. 00351-4) and the Kvaser Linx LS (Scheduled for Q1, 2007).
<< 回到产品目录
8.
Kvaser Memorator
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Linux (in USBcanII mode)
Kvaser Memorator makes it possible for you to log data from a CAN bus to a standard SD or MMC disk. Kvaser Memorator provides a dual channel CAN bus interface with a standard USB interface and is delivered with a SD disk. Support for High-Speed, Low-Speed and Single-Wire CAN through different product versions.
Kvaser Memorator has a USB connection and can be used as a powerful CAN to USB interface (like our USBcan II adapter) as well as a standalone CAN dat a logger - two products in one! As a data logger, it is for example perfect as a flight recorder due its compact design. A great advantage is that all configurations are made with a user-friendly configuration program and are stored on the flash disk. It makes it both easy and convenient to set configurations with the PC and download it to Kvaser Memorator for use in the field.
Triggers
Kvaser Memorator can log continuously, or logging can be triggered by external triggers (rising or falling edge) and/or by messages and signals on the CAN bus (triggered by identifier, or data contents.) Pre- and post-triggers are available.
Filters
To enhance logging performance, Kvaser Memorator can filter out selectable messages to be logged. The identifiers can be picked from a database, or all messages can be logged.
Memory cards
Standard MMC or SD type flash memory cards can be used. Larger memory cards, up to 1 GB, can be used. See our support pages for more information.
Supports ”listen-only” mode for bus analysis tools.
100% compatible with applications written for Leaf, LAPcan, PCIcan, PCcan and USBcan with Kvaser's CANlib.
One SD/MMC connector that accepts SD or MMC flash disks, currently up to 1 GB.
One CAN connection ISO-11898 high-speed, 50kbit/s up to 1 Mbit/s (Philips TJA1050).
Optional, second CAN connection that can be either high-speed (TJA1050), low-speed (Philips TJA1054), or single-wire ( AU5790 )
One USB 1.1 connection (12 Mbit/s). This connection is compatible with USB 2.0.
Logger status is indicated with four externally visible LEDs.
Product versions
Kvaser Memorator HS/HS (Item No. 00175-6)
Kvaser Memorator HS/LS (Item No. 00170-1)
Kvaser Memorator HS/SWC (Item No. 00234-0)
<< 回到产品目录
三.linx
9.
Kvaser Linx
SWC/LS/J1587/LIN/K-Line
Attach the Kvaser Linx to your Kvaser CAN interface's and access J1587, LIN, K-Line, SWC or LS bus network. The Kvaser Linx are interchangeable and designed for maximum flexibility and maintainability.
Kvase r Linx LIN is designed for LIN 2.0 and LIN 1.x.
Kvaser Linx J1587 is designed for SAE J1587/1708.
Kvaser Linx K-line is designed for ISO 9141.
Kvaser Linx SWC is designed for SAE J2411, GMLAN.
Kvaser Linx LS is designed for ISO 11898-3 (fault tolerant CAN).
Kvaser Linx Analog I/O is designed for an input voltage from 0 to 24 Volt.
General features
Molded 9 pin DSUB female connector with thumbscrews
Molded 9pin DSUB male connector
Compact plastic housing
Designed for Kvaser's High-Speed CAN interfaces
Perfect for Kvaser Memorator Professional, Kvaser USBcan Professional.
Product Versions
Kvaser Linx J1587 (Schedule for Item no. 00389-7)
<< 回到产品目录
四.PCMCIA产品
10.
Kvaser LAPcan
CAN/PCMCIA (PCcard) interface with 2 channels
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows 2000/XP/Server 2003, Windows 95/98/ME,
Windows NT4,
Linux
The Kvaser LAPcan is a two channel CAN interface for the PC card (PCMCIA) bus with two Philips SJA1000 CAN controllers. The CAN transceivers are built into the interface cables.
Major features
The CAN drivers (DRVcans) are exchangeable; see below
Physical layer depends on the DRVcan type
Ultrasonically welded card frame
The on-board firmware will auto-detect the type of DRVcan
PC card (PCMCIA) type II, on-board C161 16-bit microcontroller
DRVcan – required cable, connector and CAN driver for LAPcan
For maximum flexibility and maintainability the CAN driver circuit is built into LAPcan interface cables. Please see separate documentation of our DRVcans .
The Kvaser DRVcans must be purchased separately and are not included with the LAPcan. Note that one or two DRVcans are required to use the LAPcan.
Software support
32-bit drivers for Windows 95/98/ME/NT 4.0/2000/XP, Windows CE and Linux.
On-line documentation (in Windows Help and Adobe Acrobat format)
Documentation, software and drivers can be downloaded for free fromwww.kvaser.com, or they can be purchased in CD if preferred. Updates to the software are regularly posted on the web.
Additional hardware
Are you interested in using the LAPcan on a stationary PC? We do recommend that you use these PCMCIA to ISA or PCI adapters.
Specifications
General
Size:
Power:
Current consumption:
Connectors:
Internals
Processor:
On-board
Memory:
CAN
Controllers
CAN Drivers:
PCCard (PCMCIA) Type II
85 x 53.5 x 5 mm (approx. 3.4 x 2.1 x 0.2 in.)
5 V DC.
110 mA (plus the current of the DRVcans)
2 x 15-pin PCMCIA I/O
connector (connects to the DRVcans)
Infineon SAB C161, 16 MHz
128 kByte RAM, 256 kByte flash
2 x SJA1000 (Philips)
dependent of type of DRVcan
Kvaser LAPcan (Item No. 00029-2)
Two CAN channels
Supports CAN 2.0A and 2.0B
Exchangeable CAN drivers
32-bit high performance driver support
Large on-board message buffer
<< 回到产品目录
11.
Kvaser LAPcan II
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows 95/98/ME,
Windows NT4,
WinCE,
Linux,
The Kvaser LAPcan II is a two-channel CAN interface for the PC card (PCMCIA) bus. It is equipped with dual Philips SJA1000 CAN controllers, and has a high performance microprocessor and memory architecture, as well as enhanced ESD robustness.
Major features
PC card (PCMCIA) type II, on-board C161 16-bit controller
Driver support for major Operating Systems
DRVcan – required cable, connector and CAN driver for LAPcan II
For maximum flexibility and maintainability the CAN driver circuit is built into LAPcan II interface cables. Please see separate documentation of our DRVcans .
The Kvaser DRVcans must be purchased separately and are not included with the LAPcan II. Note that one or two DRVcans are required to use the LAPcan II.
A dditional software and documentation
Additional hardware
If you want to use the LAPcan II on a stationary computer in a convenient way, we do recommend that you use these PCMCIA to ISA or PCI adapters.
SPECIFICATIONS
General
Size
Voltage feed
Power consumption
Connectors
Controllers
CAN drivers
LAPcan family comparison
PCCard (PCMCIA) Type II 85 x 53.5 x 5 mm
( approx. 3.4 x 2.1 x 0.2 in.)
5 V DC
110 mA
2 x 15-pin to DRVcan's
Depends on attached DRVcan
LAPcan model:
DRVcan compatibility
Enhanced real-time performance
Enhanced driver library
Superior EMC performance
Extended OS compliance
DRVcan hot-swap support
I
x
II
x
x
x
x
x
x
Kvaser LAPcan II (Item No. 00115-2)
High ESD performance
PC card type II
Two CAN channels
<< 回到产品目录
12.
Kvaser DRVcan
CAN physical layer driver and cable for Kvaser LAPcan family
A Kvaser DRVcan is a combined cable, connector and CAN bus driver for the LAPcan / LAPcan II PCMCIA CAN interface. The DRVcans are interchangeable and designed for maximum flexibility and maintainability.
DRVcan 251 and DRVcan 1050 are for normal, high-speed ISO 11898 CAN bus systems.
DRVcan Dnopto is also intended for normal, high-speed ISO 11898 CAN bus systems but is equipped with optocouplers.
DRVcan 1053 and DRVcan 1054 are for fault-tolerant CAN buses (sometimes called "low-speed CAN")
DRVcan Fi employs optical fiber and is used for special applications. Different physical layers are supported through different product versions.
DRVcan S is used with Single-Wire CAN (SAE J2411, GMLAN)
DRVlin is used with the LIN bus. Please note that not note that not all applications listed under Application Support for LAPcan/LAPcan II support the DRVlin.
Product Transceiver Speed range Power Pin Layout
D-SUB Connector Common areas of application
DRVcan 251 82C251 1 Mbit high speed 30mA S u pplied by Kvaser LAPcan 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H; Automotive, automation, avionics, space tech., marine electronics
DRVcan 1050 TJA1050 50 kbit to 1 Mbit high speed 30mA S u pplied by Kvaser LAPcan 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H ; Automotive, automation, avionics, space tech., marine electronics
DRVcan 1053 TJA1053 125 kbit low speed 30mA S u pplied by Kvaser LAPcan 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H ; Automotive (body electronic bus)
DRVcan 1054 TJA1054 125 kbit low speed 30mA Supplied by Kvaser LAPcan 2 = CAN_L;
3 = GND;
5 = shield;
DRVcan Dnopto 82C251.
HP7101 or
compatible optocouplers 1 Mbit high speed 30mA Supplied by Kvaser LAPcan 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H ;
9 = VB+; Automotive, automation, avionics, space tech., marine electronics
DRVcan Fi HS 82C251 1 Mbit high speed 30mA Supplied by Kvaser LAPcan and CAN bus 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H ;
9 = VB+; EMC measurements
DRVcan Fi LS TJA1054 125 kbit low speed 30mA Supplied by Kvaser LAPcan and CAN bus 2 = CAN_L;
3 = GND;
5 = shield;
7 = CAN_H;
DRVcan Fi SWC AUS5790D 100 kbit 30mA Supplied by Kvaser LAPcan and SWC bus 3 = GND;
5 = shield;
7 = CAN_H;
DRVcan S AUS5790D 100 kbit 30mA Supplied by Kvaser LAPcan and SWC bus 3 = GND;
5 = shield;
7 = CAN_H;
9 = VB+; Mainly automotive (body electronic bus)
DRVlin MC33399.
HCPL0600 or compatible optocouplers 1 to 20 kbit 30mA Supplied by Kvaser LAPcan and LIN bus 3 = GND;
4 = LIN;
5 = shield;
<< 回到产品目录
五.PC104+
13.
Kvaser PC104+
PC/104-Plus CAN interface board with 2 channels
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows 98/ME,
Windows NT4,
Linux,
Venturecom RTX 5.1
Compact and self-stacking, the Kvaser PC104+ board complies with the flexible PC/104-Plus specification. Allowing embedded system designers to substantially reduce development costs and time. The Kvaser PC104+ board represents a dual channel CAN interface, with a high performance microcontroller onboard.
Hardware
Compliant with the PC/104-Plus specification
Stack-through connector
On-board 16-bit microcontroller
Communicates with the PC through a fast DPRAM
CAN Controller from Renesas (M16C)
Supports CAN 2.0 A and 2.0 B (active)
High-speed ISO 11898 compliant driver circuits, supports bit rates up to 1 Mbit/s
Optoisolated driver circuits with fast optocouplers
CAN oscillator frequency: 16 MHz
Dimensions 91 x 96 mm (approx. 3.6 x 3.8 in.)
Interfaces the CAN bus with IDC Headers
Wide temperature range, -40°C - +85°C
Software and Documentation
Documentation, software and drivers can be downloaded for free fromwww.kvaser.com, or they can be purchased on CD if preferred. Updates of the software are regularly posted on the web. The following free software is available for the Kvaser PC/104can board.
Driver routines: 32-bit kernel driver support for Windows 98/ME/2000/XP and Windows NT 4.0.
Kvaser CANLIB SDK, which includes everything you need to develop software for the Kvaser CAN boards. Includes full documentation and many program samples, written in C, C++, Delphi, Visual Basic, and C#. All Kvaser CAN interface boards share a common software API. Programs written for one board type will run without modifications on the other board types!
Kvaser CanKing, a general-purpose interactive CAN bus monitor.
Product versions
Kvaser PC104+ HS/HS (Item No. 00336-1)
PC/104-Plus CAN interface board with dual channels and 1 0 Pin IDC Headers CAN connectors. Handles a bit rate from 5 kbits/s up to 1 Mbits/s.
Kvaser PC104+ HS/HS (Item No. 00352-1)
PC/104-Plus CAN interface board with dual channels and 9 Pin DSUB CAN connectors. Handles a bit rate from 5 kbits/s up to 1 Mbits/s.
<< 回到产品目录
六.PCI产品
14.
Kvaser PCIcanx II
CAN/PCI interface boards with 1 or 2 channels
Application support
ATI Vision
ATI Apollo
ATI CANlab
Ficosa CANica
Kvaser CanKing
VAT 2000
Warwick X-Analyser
Vector CANalyzer
Vector CANoe
Vector CANape
Warwick X-Analyser
Xtm
Software Platforms
Windows 98/ME,
Windows NT4,
Linux,
Venturecom RTX 5.1
Kvaser PCIcanx II is a high-performance CAN/PCI interface board and comprises two members:
PCIcanx II HS/HS and PCIcanx II HS. Kvaser PCIcanx II HS is delivered with a free of charge low profile bracket. The Kvaser PCIcanx II boards fits in both PCI-X and PCI bus systems.
Hardware Specifications
Compliant with PCI 2.3
The board fits in both 3.3V PCI-X and 3.3V and 5V PCI busses
Fully software compatible with the discontinued PCIcan II boards
Dimensions 120 x 95 mm (approx. 4.5 x 4 in.)
Quick and easy plug-and-play installation - no switches.
CAN Controller: Renesas M16C
Industry-standard 9-pin D-SUB connectors
The Kvaser PCIcanx II family boards can optionally be delivered with exchangeable CAN drivers, supporting e.g. single-wire CAN.
Documentation, software and drivers can be downloaded for free fromwww.kvaser.com. Updates of the software are regularly posted on the web. The following free software is available for the Kvaser PCIcanx II family:
Driver support for Windows XP/Win2k, Windows 98/ME, Windows NT 4.0 and Linux.
Product versions
Kvaser PCIcanx II HS/HS (Item No. 00343-9)
Two CAN channel interface for the PCI-X and PCI bus. Two 9-pin D-SUB connectors.
Kvaser PCIcanx II HS (Item No. 00344-6)
One CAN channel interface for the PCI-X and PCI bus. One 9-pin D-SUB connector. In addition, delivered with a free of charge low profile bracket.
<< 回到产品目录
15.
Kvaser PCIcanx
CAN/PCI interface boards with 1, 2 or 4 channels
Application support
Kvaser CanKing
Xtm
Software Platforms
Windows NT4.0,
Linux
The Kvaser PCIcanx product family is a family of CAN/PCI interface boards and comprises three members: Kvaser PCIcanx 4xHS, PCIcanx HS/HS and PCIcanx HS. The Kvaser PCIcanx boards fits in both PCI-X and PCI bus systems.
Hardware
Completely compatible with our PCIcan boards.
Dimensions 140 x 100 mm (approx. 5.5 x 4 in.)
I/O mapped
SJA1000 CAN Controllers from Philips, with 64-byte receive FIFO
Interfaces the CAN bus with DSUB CAN connectors
16 MHz CAN oscillator frequency
The following software is available for PCIcanx 4xHS, PCIcanx HS/HS and PCIcanx HS:
Driver support for Windows 95/98/ME/2000/XP, Windows NT 4.0, Linux.
Kvaser CanKing for Windows, a general-purpose interactive CAN bus monitor with special support for CanKingdom and DeviceNet?
All our CAN interfaces and cards share a common API. Programs written for one board type will run without modifications on the other board types.
Product versions
Kvaser PCIcanx 4xHS (Item No. 00330-9 )
Four CAN channel interface for the PCI bus with 4 x SJA1000 CAN controllers. One 25-pin D-SUB connector.
Kvaser PCIcanx HS/HS (Item No. 00331-6 )
Two CAN channel interface for the PCI bus with 2 x SJA1000 CAN controllers. Two 9-pin D-SUB connectors.
Kvaser PCIcanx HS (Item No. 00332-3 )
One CAN channel interface for the PCI bus with 1 x SJA1000 CAN controller . One 9-pin D-SUB connector.
Channels
CAN controllers Connectors
PCIcanx 4xHS 4 4 x SJA1000 1 x D-SUB 25
PCIcanx HS/HS 2 2 x SJA1000 2 x D-SUB 9
PCIcanx HS 1 1 x SJA1000 1 x D-SUB 9
<< 回到产品目录
16.
Kvaser PCIcan
Application support
Kvaser CanKing
Xtm
Software Platforms
Windows NT4.0,
Linux
The Kvaser PCIcan product family is a family of CAN/PCI interface boards and comprises three members: Kvaser PCIcan 4xHS, PCIcan HS/HS and PCIcan HS
Hardware
Compliant with PCI 2.2
I/O mapped
Quick and easy plug-and-play installation (even under Windows NT 4.0!)
CAN Controllers: SJA1000 from Philips, with 64-byte receive FIFO
PCIcan 4xHS only:
The CAN controllers can individually be connected to a common CAN bus on the card
The common CAN bus has a built-in optional termination
PCIcan HS/HS and HS only:
The PCIcan HS/HS and PCIcan HS can optionally be delivered with exchangeable CAN drivers, supporting e.g. single-wire CAN.
Software
The following software is available for PCIcan 4xHS, PCIcan HS/HS and PCIcan HS:
Driver support for Windows 95/98/ME/2000/XP and Windows NT 4.0 and Linux
Driver for Win CE under development
Kvaser CanKing for Windows, a general-purpose interactive CAN bus monitor/analyzer with special support for CanKingdom and DeviceNet?
Supported Environments
The environments currently supported are:
32-bit programs under Windows 95/98/ME
32-bit programs under Windows 2000/XP/NT 4.0
All Kvaser hardware products share a common software API. Programs written for one board type will run without modifications on the other board types!
Product versions
Kvaser PCIcan 4xHS (Item No. 00084-1)
Four CAN channel interface for the PCI bus with 4 x SJA1000 CAN controllers. Built-in loopback and terminator. One 25-pin D-SUB connector.
Kvaser PCIcan HS/HS (Item No. 00083-4)
Kvaser PCIcan HS (Item No. 00082-7)
Channels
PCIcan 4xHS 4 4 x SJA1000 1 x D-SUB 25
PCIcan HS/HS 2 2 x SJA1000 2 x D-SUB 9
PCIcan HS 1 1 x SJA1000 1 x D-SUB 9
<< 回到产品目录
七.ISA产品
17.
Kvaser PCcan
Application support
Kvaser CanKing
Software Platforms
Windows NT4,
Windows 3.x,
DOS,
The PCcan product family comprises three members: PCcan 4xHS, PCcan HS/HS, and PCcan HS
Hardware
The board is a quarter-size (length 135 mm) 8-bit ISA bus board and occupies 64 bytes of I/O space. The base address can be any of 200 H , 240 H , 300 H , and 340 H . The interrupt signal on the CAN controllers can be connected – under software control – to any one of IRQ 2/9, IRQ 3, and IRQ 5 on the ISA bus.
The original 16 MHz oscillator may be replaced with an oscillator of frequency range 1–24 MHz to obtain the required bit rate on the bus. The PCcan 4xHS board draws approximately 600 mA at 5V.
The industry-standard CAN controllers on the PCcan cards are directly accessible to the programmer. This makes the cards suitable for cross-platform development: you can develop your software on your PC and then move it, with a minimum of changes, to your embedded system.
The CAN controllers support CAN 2.0 A and 2.0 B (active.) The CAN bus drivers supports the standard, high-speed ISO11898 physical layer.
External Connector
The outputs from the CAN circuits are connected to female D-SUB connectors via optocouplers and bus drivers (Philips 82C251, conforming to ISO 11898).
The connectors provide the voltage feed for the bus section (optocouplers and driver circuits). Alternatively the PC is used as power source; however this gives no galvanic separation between the computer and the CAN bus.
On the PCcan 4xHS card, it is possible to connect all the 4 CAN in/outputs to a common CAN bus, which is also connected to the CAN-connector.
Software
The following software is available for the Kvaser PCcan family:
Driver routines: libraries for DOS; 16-bit DLL for Windows 3.1 ; 32-bit support for Windows 95/98/ME/2000/XP and NT 4.0
All our CAN interfaces share a common 32-bit API. You can use the same programs, without modifications, for all our CAN interfaces!
Product versions
Kvaser PCcan 4xHS (Item No. 00049-0)
Four CAN channel interface for the ISA bus with 2 x SJA1000 and 2 x 82527 CAN controllers. Built-in loopback and terminator. One 25-pin D-SUB connector.
Kvaser PCcan HS/HS (Item No. 00051-3)
Two CAN channel interface for the ISA bus with 2 x SJA1000 CAN controllers. Two 9-pin D-SUB connectors.
Kvaser PCcan HS (Item No. 00050-6)
One CAN channel interface for the ISA bus with 1 x SJA1000 CAN controller . One 9-pin D-SUB connector.
Channels CAN controllers Connectors
PCcan 4xHS 4 2 x SJA1000
2 x 82527 1 x D-SUB 25
PCcan HS/HS 2 2 x SJA1000 2 x D-SUB 9
PCcan HS 1 1 x SJA1000 1 x D-SUB 9
<< 回到产品目录
八.其他产品
18.
Kvaser OBD II Adapter Cable
A Kvaser OBD II Adapter Cable connects any Kvaser CAN bus interface with a 9 Pin DSUB connector
to a vehicle with an OBD II (J1962) connector.
General features
Molded OBD II (SAE J1962) male connector, for Type A (12 Volt) as well as Type B (24 Volt).
2500 mm (approx. 8 ft) long cable made of durable thermoplastic rubber
Designed for Kvaser's High-Speed, Low-Speed and Single-Wire CAN interfaces
Perfect for Kvaser Memorator, Kvaser Leaf Professional, etc.
More Product Information
Download detailed schematic
Product Versions
Kvaser OBD II Adapter Cable (Item no. 00302-6)
<< 回到产品目录
19.
Kvaser Protocol Stacks
Please contact us for more information about these products.
Kvaser Protocol Stack for CANopen
The KVASER CANopen stack is a user friendly API designed for high performance CANopen network.
Kvaser CANopen stack is very memory efficient. The stack is equipped with predefined compile parameters that offers the possibility to ignore support for unused CANopen optional functionality for the specific CANopen node to save even more memory if necessary to suit the wide range of needed complexity of an CANopen protocol implementations that you may have. Within the code, related blocks of functionality are grouped together in easily maintainable modules.
Kvaser CANopen stack supports
NMT Master (module control service, reset node service, error control service, node guarding service, life guard event, heart beat event, boot up services,)
NMT protocols (start, stop, reset, enter pre-operational, enter operational, reset communication),
Synchronization Object (SYNC),
Time Stamp Object (TIME),
Emergency Object (EMCY),
SDO Client/Server (expedited transfers and segmented transfers, configurable messages buffers and unlimited number of active SDOs),
PDO handler,
PDO inhibit time,
Dynamic PDO mapping,
SYNC master, and
A Local Object dictionary.
Communication between the CANopen Slave/Master and the application process takes place through easy-to-use and CPU-time efficient application communication functions described in the KVASER CANopen API documentation.
Kvaser CANopen code stack can run on all hardware supported by Kvaser CANLIB.
Kvaser Protocol Stack for NMEA2000
The NMEA 2000? stack is a set of ANSI C software modules that performs the core NMEA 2000? requirements. The stack interface is designed for compatibility with any operating system while providing fast-packet and transport protocol packetization, reassembly, and timing logic. The stack includes the network address claim logic, which may be configured off for "listen only" nodes. A configurable message identifier filter table optimizes the message reception process for your application. Operating system and target independent communication stack.
Includes Address Claim processing.
Performs Fast packet timing requirements, packetization and reassembly.
Performs Transport Protocol timing requirements, packetization and reassembly.
Configurable message buffer sizes.
Configurable message identifier filter table.
Multiple stack instantiation support (for multiple CAN channels in the same device).
RAM usage: 6 kilobytes
ROM usage: 16 kilobytes
Fully commented, royalty free, ANSI C source code
Example code for Mitsubishi/Renesas M16C (M306N) and CANLib SDK.
Further protocols are available for all CAN interface
RP1210A
J2543
<< 回到产品目录
20.
Kvaser OBD II Extension Cable
A Kvaser OBD II Extension Cable is an extension cable with a male to female OBD II connector. The cable is made of durable thermoplastic rubber. All pins are connected.
General features
Molded OBD II (SAE J1962) female connector, for Type A (12 Volt) as well as Type B (24 Volt).
Made of durable thermoplastic rubber
Gold plated pins on OBDII connectors for extra reliable contact.
Termination is built in with a 120 Ohm terminating resistor
Available in four different cable lengths
Product Versions
Kvaser OBD II Extension Cable (Item no. 00347-7)
2.5 meter (approx. 98,5 inch)
Kvaser OBD II Extension Cable (Item no. 00301-9)
5 meter (approx. 197 inch)
Kvaser OBD II Extension Cable (Item no. 00348-4)
10 meter (approx. 394 inch)
Kvaser OBD II Extension Cable (Item no. 00349-1)
15 meter (approx. 591 inch)
<< 回到产品目录
九.免费开发产品
21.
Kvaser CANlib
Application support
Kvaser LAPcan Family
Kvaser Leaf Family
Kvaser Memorator
Kvaser PCIcan Family
Kvaser PCcan Family
Kvaser USBcan Family
Software Platforms
Windows 95, 98, ME, 2000, XP, Server 2003, NT 4.0
The CANlib Software Development Kit – your transparent interface to the KVASER hardware platforms.
Features in CANlib SDK (Software Developers Kit)
Support for the following compilers:
Microsoft Visual C++ (also supports the C language )
Borland C++ Builder (and the old Borland C++ compiler as well) - also supports the C language
Borland Delphi (all versions)
Microsoft Visual Basic and VB.NET
Microsoft C#
Includes
Many example programs
Debug your own CAN tools using CANking (free of charge bus monitor)
Getting-started and reference documentation
Supports virtual (non-hardware) CAN channels which you can use for test or demo purposes. Install the virtual drivers today and try everything out.
Includes limited 16-bit (DOS, Windows 3.x) support for the PCcan family of boards.
CANopen Master API for all our hardware available
Software written using CANlib provides compability with present and future hardware from KVASER. An application using CANlib can be used on another platform without modifications.
More Information
CANLIB 3.8 Help (this help is included with CANLIB SDK)
Download CANLIB SDK (includes documentation, samples etc.)
An overview of the structure of CANLIB
<< 回到产品目录
22.
Kvaser CanKing
Software Platforms
Windows 95, 98, 2000, XP & NT 4.0
Kvaser CanKing is a free CAN bus monitor and general-purpose diagnostic tool. It is especially suited for interactive development work. You can easily send CAN messages and study their impact on the target module. All you need is a Kvaser CAN interface. Kvaser CanKing is free of charge.
Features:
The basic version enables you to display the messages on the CAN bus, and optionally format them in a several different ways. You can also send CAN messages just by filling out a dialog box and press OK. There are many message layout options. (Users of CanKingdom will find support for almost all King's Pages here.)
Other features include:
A history list for the messages you have sent
CAN bus statistics (number of messages, bus load etc)
A traffic generator for studying your system under heavy bus load
Time stamping of incoming and outgoing messages (time stamps can be displayed in both absolute and relative format)
Please note that CANKing is not a substitute for a full-blown CAN bus analyzer. It is intended for interactive development, not for heavy-duty logging of bus traffic.
CAN Interfaces
CANKing is supported by all CAN interfaces from Kvaser!
Download CANking now!
<< 回到产品目录
公司名称: 广州密创力电子科技有限公司
联 系 人: 陈志刚
电  话: 020-88195466
传  真: 020-87051345
地  址: 广州市五山华南理工大学国家科技园
邮  编: 510640
该厂商相关技术文摘:
电导技术
更多文摘...
立即发送询问信息在线联系该技术文摘厂商:
