超强节电特性 High energy saving
相比传统伺服电机节能率可到30%~80%,可比同类伺服电机多节能5%~30%
Compared with traditional infecetion molding machines,energy-saving can reach 30%~80%,
Compared with other servomotors,Dacheng can save 5%~30% energy
极佳成型稳定性 Better molding stability
闭环精密控制,相比传统注塑机成型重复精度大大提高
Compared with conventioal injecton molding machines,repeatability is greatly improved due to servo motor close-loop control
高响应特性 Quick response
刚性高响应快,启动时间仅需0.02s~0.05s
High rigidity,fast response,the response time only 0.02~0.05 second
安静、低噪音 Quiet & low noise
整机运行低噪音,低速运行更宁静
The machine runs with low noise,and will be much quieter in a low speed
可靠的保压性能 Reliable holding pressure
相比其他伺服电机保压时间更长、更稳定,最高可达30min
Compares servo motors to guarantee presses the time to be longer,to be stabler, which can reach 30min
低温升 Oil temperature rise slowly
伺服电机比例输出液压油,避免多余热量产生,温升低,液压油甚至无需冷却,实现大幅节水、节能
Servo motor proportionally deliver hydraulic oil base on our needs,it's can prevent unnecessary heat being generated,even in some cases does not require cooling system.
会员简介
会员代号: liwenjun
联 系 人: 李文俊
电  话: 0755-27933800
传  真: 0755-29668283
地  址: 深圳市宝安79区好运来商务大厦A9010
邮  编: 518101
立即发送询问信息在线联系该技术文摘厂商:
