Agilent 8960 Series 10 无线通信测试仪能为移动设备制造商带来直接的竞争优势。 为大规模的自动生产制造测试所开发的 8960 Series 10 测试仪,为客户提供了 速度, 精度, 重复能力,多制式能力, 易于编程, 以及制式灵活的体系结构。 对移动设备制造商来说,这意味着更低的测试成本和更高的产出,并且也有助于满足客户对电话的当前和未来要求。
当前对8960 Series 10 的增强把仪器的应用领域扩展到无线终端的设计和开发之中。除了扩展的参数测试外,您还可利用强大的协议记录特性,用新的“实验室应用软件” 对您的无线设计进行验证和纠错。
可把 8960 Series 10 配置为用于 W-CDMA, cdma2000, IS-95, GSM, GPRS, TIA/EIA-136 和 AMPS移动电话测试。
Agilent E5515C 常用选件
E1961A AMPS/136 mobile test application. (Requires E5515C.)
E1962B cdma2000/IS-95/AMPS mobile test application. (Requires E5515C
and E5515C-003.)
E1962B-401 cdma2000 Rel A new control channels. (Requires E5515C
and E5515C-003.)
E1962B-402 Advanced AMPS. (Requires E5515C and E5515C-003.)
E1962B-403 cdma2000 authentication. (Requires E5515C and E5515C-003.)
E1962B-405 cdma2000 digital bus (fading).
E1962B-406 cdma2000 multi-unit syncronization.
E1962B-407 cdma2000 protocol logging.
E1963A W-CDMA mobile test application. (Requires E5515C and E5515C-003.)
E1963A-401 W-CDMA video phone test. (Requires E5515C and E5515C-003.)
E1963A-403 HSDPA test modes. (Requires E5515C and E5515C-003.)
E1963A-413 HSUPA test modes. (Requires E5515C, E5515C-003, and
E1963A-403.)
E1966A 1xEV-DO terminal test application. (Requires E5515C and E5515C-003.)
E1966A-102 1xEV-DO Release A. (Requires E5515C and E5515C-003.)
E1966A-405 1xEV-DO digital bus (fading).
E1966A-406 1xEV-DO multi-unit syncronization.
E1966A-407 1xEV-DO protocol logging.
E1968A E1968A GSM/GPRS mobile test application. GSM, GPRS, and EGPRS wireless
technology functionality is available. Must specify an option for a specific
format or combination of formats.
E1968A-101 GSM functionality. (Requires E5515C and E5515C-002.)
E1968A-102 GPRS functionality. (Requires E5515C and E5515C-002.)
E1968A-103 EGPRS functionality. (Requires E5515C and E5515C-002.)
E1968A-201 GSM/GPRS functionality. (Requires E5515C and
E5515C-002.)
E1968A-202 GSM/GPRS/EGPRS functionality. (Requires E5515C and
E5515C-002.)
E1968A-410 EGPRS phase and amplitude versus time. (Requires E5515C
and E5515C-002.)
E1987A Fast switching test application. Fast switches across all TA formats. (Requires
at least two TAs, E5515C, and E5515 options for the wireless formats to
be switched.)
E1991B 8960 test application suite. Includes TAs for GSM, GPRS, EGPRS, AMPS,
136 (TDMA), cdma2000, IS-95, 1xEV-DO, W-CDMA, and fast switching.
Contains E1968A, E1968A-202, E1961A, E1962B, E1963A, E1966A, and E1987A
TAs. (Requires E5515C, E5515C-202, and E5515C-003. E1991B is for installation
on a single 8960 test set. TA feature options such as E1962B-401, 402, 403, 405,
406, 407; E1963A-401, 403; E1966A-102, 405, 406, 407; E1968A-410; E1999A;
and E1999A-201 are ordered separately; they are not included in the E1991B
TA suite.)
E1993A 8960 UMTS test application suite. Includes TAs for GSM, GPRS, EGPRS,
AMPS, W-CDMA, and fast switching. Contains E1968A-202, E1963A, and
E1987A TAs. (Requires E5515C, E5515C-002, and E5515C-003. E1993A is for
installation on a single 8960 test set. TA feature options such as E1963A-401,
403; E1968A-410; E1999A; and E1999A-201 are ordered separately; they are not
included in the E1993A TA suite.)
E1996A 8960 cdma2000/1xEV-DO test application suite. Includes TAs for cdma2000,
IS-95, 1xEV-DO, AMPS, and fast switching. Contains E1962B, E1966A, and
E1987A TAs. (Requires E5515C and E5515C-003. E1996A is for installation
405, 406, 407; E1966A-102, 405, 406, 407; E1999A; and E1999A-201 are
ordered separately; they are not included in the E1996A TA suite.)
E1999A E5515 application features.
E1999A-201 Fast device tune measurement. Enables fast device tune
measurement in E1962B, E1963A, E1966A, E1968A, and E1987A
TAs. (Requires E1962B, E1963A, E1966A, or E1968A TA.)
E6701E GSM/GPRS lab application. (Requires E5515C and E5515C-002. Order
E5515C-004 to enable fading.)
E6702B cdma2000 lab application. (Requires E5515C and E5515C-003.)
E6703D W-CDMA lab application. (Requires E5515C and E5515C-003. Order E5515C-004
to enable fading.) Includes E5515-10007 UMTS (W-CDMA) USIM card.
E6704A EGPRS lab application. (Requires E6701E and E5515C with E5515C-002.)
E6706A 1xEV-DO lab application with Release A. (Requires E5515C and E5515C-003.
Order E5515C-004 to enable fading.)
E6785D Fast switching lab application for GSM/GPRS/EGPRS and W-CDMA. (Requires
E6701E, E6703D, E5515C, E5515C-002, and E5515C-003. For EGPRS capability,
add E6704A. Order E5515C-004 to enable fading.)
E6716A cdma2000/1xEV-DO lab application suite. Includes LAs for cdma2000 and
1xEV-DO with Release A. Contains E6702B and E6706A LAs. (Requires
E5515C and E5515C-003. Order E5515C-004 to enable fading. E6716A is for
installation on a single test set.)
E6717B 8960 lab application UMTS suite. Includes LAs for GSM, GPRS, EGPRS, and
W-CDMA. Contains E6701E, E6703D, E6704A, and E6785D fast switching LA.
(Requires E5515C, E5515C-002, and E5515C-003. Order E5515C-004 to enable
fading. E6717B is for installation on a single 8960 test set.)
E6719D Lab application suite. Includes LAs for GSM, GPRS, EGPRS, cdma2000,
W-CDMA, 1xEV-DO with Release A, and fast switching. Contains E6701E,
E6702B, E6703D, E6704A, and E6706A LAs plus E6785D fast switching LA.
fading. E6719D is for installation on a single 8960 test set.)
E6720A Annual upgrade contracts for 8960 lab applications. Must specify an option for
each format. For contract renewals, order the contract extension to avoid
overlap of existing and renewal terms.
E6720A-001 For E6701 GSM/GPRS and E6704A EGPRS LAs
E6720A-002 For E6703 W-CDMA LA
E6720A-006 For E6706 1xEV-DO LA
E6720A-017 For E6701 GSM/GPRS, E6704A EGPRS, E6703 W-CDMA LAs
E6720A-201 Contract extension for E6701 GSM/GPRS and E6704A EGPRS LAs
E6720A-202 Contract extension for E6703 W-CDMA LA
E6720A-206 Contract extension for E6706 1xEV-DO LA
E6720A-217 Contract extension for E6701 GSM/GPRS, E6704A EGPRS,
E6703 W-CDMA LAs
