国际标准目录(阀门)汇编 · ISO 5208:1993 Industrial valves -- Pressure testing of valves · 工业用阀门 阀门的压力试验 · ISO 5209:1977 General purpose industrial valves -- Marking · 工业用阀门 标记 · ISO 5210:1991 Industrial valves -- Multi-turn valve actuator attachments · 工业用阀门 多回转阀门驱动装置的连接 · ISO 5211:2001 Industrial valves -- Part-turn actuator attachments · 工业用阀门 部分回转阀门驱动装置的连接 · ISO 5752:1982 Metal valves for use in flanged pipe systems -- Face-to-face and centre-to-face dimensions · 法兰管路系统中金属阀门的结构长度 · ISO 5996:1984 Cast iron gate valves · 铸铁闸阀 · ISO 6002:1992 Bolted bonnet steel gate valves · 阀盖用螺栓连接的钢制闸阀 · ISO 6552:1980 Automatic steam traps -- Definition of technical terms · 自动蒸汽疏水阀 术语 · ISO 6553:1980 Automatic steam traps -- Marking · 自动蒸汽疏水阀 标记 · ISO 6554:1980 Flanged automatic steam traps -- Face-to-face dimensions · 法兰连接自动蒸汽疏水阀结构长度 · ISO 6704:1982 Automatic steam traps -- Classification · 自动蒸汽疏水阀 分类 · ISO 6948:1981 Automatic steam traps -- Production and performance characteristic tests · 自动蒸汽疏水阀 产品试验和工作特性试验 · ISO 7121:1986 Flanged steel ball valves · 法兰连接钢制球阀 · ISO 7259:1988 Predominantly key-operated cast iron gate valves for underground use · 主要靠扳手操作的地下用铸铁闸阀 · ISO 7841:1988 Automatic steam traps -- Determination of steam loss -- Test methods · 自动蒸汽疏水阀 漏气量测定 试验方法 · ISO 7842:1988 Automatic steam traps -- Determination of discharge capacity -- Test methods · 自动蒸汽疏水阀 排水量测定 试验方法 · ISO 10434:2004 Bolted bonnet steel gate valves for petroleum and natural gas industries · 石油天然气工业用螺栓连接阀盖钢制闸阀 · ISO 10497:2004 Testing of valves -- Fire type-testing requirements · 阀门试验 阀门耐火试验要求 · ISO 10631:1994 Metallic butterfly valves for general purposes · 普通用途的金属蝶阀 · ISO 12149:1999 Bolted bonnet steel globe valves for general-purpose applications · 通用螺栓连接阀盖钢制球阀 · ISO 15761:2002 Steel gate, globe and check valves for sizes DN 100 and smaller, for the petroleum and natural gas industries · 石油、天然气工业用钢制闸阀、球阀和止回阀(DN≤100) · ISO 17292:2004 Metal ball valves for petroleum, petrochemical and allied industries · 石油和石化工业用金属球阀 · ISO 4126-1:2004 Safety devices for protection against excessive pressure - Part 1: Safety valves · 用于超压保护安全装置 第一部分:安全阀 · ISO 4126-2:2003 Safety devices for protection against excessive pressure - Part 2: Bursting disc safety devices · 用于超压保护安全装置 第二部分:安全隔板保险装置 · ISO 4126-4:2004 Safety devices for protection against excessive pressure - Part 4: Pilot-operated safety valves · 用于超压保护安全装置 第四部分:先导式安全阀 · ISO 4126-5:2004 Safety devices for protection against excessive pressure - Part 5: Controlled safety pressure relief systems · 用于超压保护安全装置 第五部分:控制安全压力排放系统 · ISO 4126-6:2003 Safety devices for protection against excessive pressure - Part 6: Application, www.wt136.comselection and installation of bursting disc safety devices · 用于超压保护安全装置 第六部分:爆破片安全装置的选择、应用和安装 · ISO 4126-7:2004 Safety devices for protection against excessive pressure - Part 7: Common data · 用于超压保护安全装置 第七部分:通用要求 · ISO 6718:1991 Bursting discs and bursting disc devices · 安全隔板和安全隔板装置 · ISO 6718:1991/Cor 1:1993 (available in French only)(93年只有法语板) 制修订国际标准目录(阀门) · ISO/DIS 4126-3 用于超压保护安全装置 第三部分:化工安全装置用安全阀和爆破膜 ·ISO/DIS 7121 一般工业用金属球阀 · ISO/DIS 15848-1 工业阀门—测量、试验和资质证明(近期发行)第一部分 阀门的型式试验用系统分类和质量认可程序 · ISO/DIS 15848-1 工业阀门—测量、试验和资质证明(近期发行)第二部分 产品的验收试验 注:CD—工作组草案;DIS—国际标准草案;FDIS—国际标准最终草案。
