项目简介:
智能型电网故障信息处理系统以先进的技术为电网的安全、经济运行提供的一个有效的预告方案, 具有开放性设计、功能拓展性好、配置灵活等特点,提供了从数据采集、故障诊断直至事故处理的电力系统的完整解决方案。
Intelligent Power Fault Analyzing System will provide an effective solution for power’s secure and stable operation with advanced technology. With features of open design, flexible configuration, and high functional extensibility, it will present you an integrated power solution from data collection, fault analyzing to system restoration.
NPC-5000通讯服务器作为故障信息系统子站与主站数据交互的桥梁,支持一个多种传输协议(IEC103、104、101等)、多任务并行工作,它为系统提供了稳定、可靠、先进的传送途径,同时支持为不同客户端按信息类型定制传输不同内容,以满足不同用户要求;对IEC61850平台进行了良好兼容。
As the data-exchange bridge between fault information system of sub-station and master station, Nematron NPC-5000 Embedded IPC can assure a kind of multi-transfer protocol (IEC103, 104, 101), and various tasks to work at the same time. Providing a stable, reliable, advanced transfer way, it can transfer specific contents by different information categories for various customer demands. A better compatibility for IEC61850 platform has also been present by Nematron NPC-5000.
应用领域:电力
所用我司产品:NPC-5000
系统解决方案:
