OPTIMESS激光测量仪在木材行业的应用
The laser sensor for all areas of the wood industry
  • sturdy construction
  • regulated laser diode
  • interference immunity with regard to extraneous light
  • high measuring frequency
  with a cost effectiveness, which has been adapted to the wood industry as best as possible.
The main areas of application are:
  • on-line thickness measuring
  • board measurement
  • profile measuring
  For all areas, where wider measuring ranges are necessary (e.g. for veneer peeling machines) the OPTImess Standard series is available with measuring areas of up to 1000 mm.
Thickness Measuring
  Thickness Measuring The main area of operation for laser sensors in the wood industry is thickness measuring. Thickness measuring in the form of an one-track system is possible with one as well as with two sensors.  Measuring with one sensor is carried out on a reference cylinder as a basis. In this connection, the fact that the cylinder抯 ovality as well as any lifting of the product from the cylinder will be registered as a change of thickness and can lead to measuring errors needs to be taken into consideration.    Therefore, the standard use of two laser sensors per measuring track is recommended, whereby one sensor each is positioned above and below the product. This arrangement allows for a vertical movement of the product within the measuring range, which will have no influence on the measuring result. Depending on the sensors?arrangement and number, there is thus a possibility of different system configurations
·       stationary thickness measuring of 1 to x tracks
·       thickness measuring with adjustable measuring tracks
·       traversing thickness measuring
  For stationary thickness measuring there are specialised data processing units or system solutions with PC available. For traversing measuring different traversing frames in the shape of c-frames or o-frames with different widths are used. The traversing process facilitates the continuous scanning of longitudinal and cross profiles, and, additionally, width measuring in case of static product edges. Traversing errors due to production tolerances and the rail抯 deflexion caused by its own weight are compensated for by a corresponding traversing-error correction in the software.
Profile Measuring
  Depending on the board抯 length, several sensors are scanning the profile of the board, which is passing crosswise below the sensor. During the subsequent data processing, the width of the edges to be cut off and the sawing width are detected from the resulting data.
Tree-Trunk Measurement at Veneer Peeling Plants
  The rotating tree-trunk, which has been clamped into the peeling machine, is measured with several stationary sensors or a traversing system. The registered measured values are processed with a special software. According to the measured values, the tree-trunk receptors are adjusted in such a way, that optimal veneer peeling is achieved.
Controlling of Wood Grinders
  To guarantee the wood grinder抯 correct setting, e.g. when polishing doors, a fast measuring with laser sensors is used. The wood grinder is controlled on the basis of the detected door width. The OPTImess sensors in operation for this purpose are working on raw wood as well as on colour finished surfaces.
Width Measuring
  For continuous width measuring the OPTIline system is available. This system operates according to the shadow measuring method and carries out on-line width measuring on the basis of edge detection of the product.
公司名称: 瑞士ELAG电子有限公司北京代表处
联 系 人: Sandy Zhang
电  话: 010-51285271
传  真: 010-51285273
地  址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮  编: 100016
该厂商相关解决方案:
无接触激光测量—在汽车工业中的应用
OPTIMESS在钢铁工业中的应用
瑞士OPTIMESS公路路面车辙测量系统
瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
更多方案...
立即发送询问信息在线联系该解决方案厂商::
