²úÆ·Ãû³Æ£º LE-350
ÐÍ ºÅ£º LE-350
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: 3.5" Flanless Embeded miniboard
  • CPU: onboard embedded AMD Geode GX1 300 MHz CPU
  • Memory: Onboard 1 x 144-pin SO-DIMM socket supports up to PC133 256 MB.
  • Chipset : AMD Geode CS5530
  • Real Time Clock : Chipset Integrated RTC with onboard battery
  • Watchdog Timer : Generates NMI or system  reset  watchdog timer
  • Power Managerment : ACPI 1.0 compliant, supports power saving mode with ATX PSU
  • PCI Enhanced IDE: One ATA33 IDE channel supports up to 2 ATAPI devices.Onboard 1 x 44-pin IDE connectors
  • VGA Interface: AMD Geode CS5530 built-in VGA controller with 2D engine and 4 MB of video memory shared with system.
  • LCD Interface: 18-bit TTL/LVDS LCD Interface.1 x internnal 40-pin TTL connector.1 x internal 20-pin LVDS connector.
  • LAN Interface: 2 x Realtek RTL8100B PCI Ethernet Controller.
  • Audio Interface: Realtek ALC201A AC97 Codec.
  • Internal I/O Ports: 1x IrDA port, 1x Parallel and 2 x USB ports.1 x RS-232/422/485 jumper selectable  , 1x FDD ,1 x  8-bit GPIO,1 x  4-pin DC connector
  • External I/O Ports: 2 x RJ45 LAN ports, 1x DB15 VGA port and 1x PS/2 port, 1x RS232 port, 1x DC Jack
  • External Audio Port: Line -out/Front , Line-in/Rear and MIC-in /Center
  • Solid States Disk : Compact Flash Card Type I
  • Extended Interface: 1 x  PC/104 interface
  • Power Requirement : DC 12V input
  • Board Dimmension : 146 mm x 101 mm (L xW)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
