²úÆ·Ãû³Æ£º LV-669
ÐÍ ºÅ£º LV-669
Form Factor
Mini-ITX Motherboard (170 x 170 mm)
CPU
Onboard VIA C7 1.5 GHz processor.
Memory
1 x 184-pin DDR up to 1 GB and optional onboard 256 MB SDRAM
Chipset
VIA CN700 & VT8237R+
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset  internal timer for 1min ~ 255 min
Power Management
ACPI 1.0 compliant, supports power saving mode
PCI Enhanced IDE
2 x DMA133 IDE channel up to 4 ATAPI devices.
(1 x 40-pin and 1 x 44-pin)
VGA Interface
 VIA CN700 integrated Unichrome Pro 3D/2D Graphics controller.
Serial ATA Interface
2 x Serial ATA Interface  with 150 MB/s transfer rate.
Audio Interface
Realtek ALC655  5.1 channel Audio
LAN Interface
 2 x Realtek RTL8110S-32 Gigabit Ethernet .
Solid State Disk
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II on the rear .
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
1 x PCI slot , 1 x Min-PCI socket
External I/O Port
2 x RJ45 LAN port, 1x DB15 VGA port, 1 x  PS/2 Keyboard / Mouse ports,  2 x COM, 1 x IEEE 1394 ports, 4 x USB 2.0 ports, Audio ,  DC input connector
   Internal I/O Port
    1 x RS232 & 1 x RS232/422/485, 1 x slim FDD, 1 x IrDA ,
    2 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x LPT
Power Requirement
8 V ~ 24 V full range DC input , onboard 4-pin 12V connector
    Board Dimension     170mm x 170 mm (L x W)
Operation Temperature
 0 ~ 60oC (32 ~ 140oF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
