²úÆ·Ãû³Æ£º AS-C74
ÐÍ ºÅ£º AS-C74
Æ· ÅÆ£º 735
Specification
Form Factor
Industrial ATX Motherboard
Processor
Intel® Core™ i7 / i5 / i3, Pentium & Xeon Desktop processor
Package Type: FCLGA1155
Memory
4 x DDR3 1066/1333 DIMM up to 32 GB
Chipset
Intel® Q67 Express Chipset
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset with internal timer for 1min/s ~ 255min/s
Power Management
ACPI 1.0 compliant, supports power saving mode
Serial ATA Interface
Intel® Q67 chipset built-in 4 x Serial ATA II interface up to 300MB/s
2 x SATA3 interface up to 600MB/s. Total 6 x SATA interface
Support RAID 0, 1, 5, 10 and Intel® Rapid Storage Technology
VGA Interface
Integrated Intel® HD graphic technology
DVI Interface Onboard 26-pin DVI interface
Audio Interface
Intel® integrated Q67 with Realtek ALC888 HD Audio
LAN Interface
2 x Intel® 82574L Gigabit Ethernet Controller
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extended Interface
PCI-Express X16 & X4 slot, 5 x PCI slots, Mini-PCIe & Mini-PCI
Internal I/O Port
2 x RS232, 1 x RS232/422/485, 1 x GPIO, 1 x CDIN, 1 x SMBus,
1 x LPT, 1 x Audio, 1 x IrDA, 8 x USB2.0
External I/O Port
1 x PS/2 keyboard/mouse, 2 x RJ45, 1 x VGA, 4 x USB2.0,
1 x Audio, 3 x RS232, 1 x SPDIF
External Audio
Line-in, MIC-in, Front, Rear, Center/Subwoofer and optical SPDIF
Power Requirement
Standard 24-pin ATX power supply and P4 8-pin 12V.
( compatible with 20-pin ATX power supply )
Board Dimension
307 mm x 244 mm (L x W)
Temperature
Operating within 0 ~ 60¡ãC
Storage within -20 ~ 85¡ãC
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
