Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Î÷ÃÅ×ÓMM440±äƵÆ÷
²úÆ·Ãû³Æ£º Î÷ÃÅ×ÓMM440±äƵÆ÷
ÐÍ ºÅ£º 6SE6440-2UD31-5DB1
Æ· ÅÆ£º 1
±¾¹«Ë¾¾­ÓªÎ÷ÃÅ×Ó£¬S7-200,S7-200CN,S7-300 S7-400PLC,±äƵÆ÷£¬ÈË»ú½çÃæ£¬PCU50,ÖÊÁ¿±£Ö¤£¬¼Û¸ñÓÅÊÆ£¬»¶Ó­×ÉѯǢ̸¡£
»¶Ó­ÄúÀ´µç×Éѯ¸ßÆ·ÖÊÎ÷ÃÅ×ÓÇý¶¯ºÍ×Ô¶¯»¯²úÆ·¼Û¸ñ
ÉϺ£ÌÚÎ÷Î÷ÃÅ×Ó¹¤¿Ø¼°×Ô¶¯»¯²úÆ··ÖÏúÉÌ
ÁªÏµÈË£º½ð·ïÎõ£¨ÏúÊÛ¾­Àí£©
ÊÖ»ú£º18621337130
´«Õ棺021-57653572 QQ£º97446518
ÓÊÏ䣺97446518@qq.com
ÍøÖ·£ºhttp://www.tensey.com
24СʱÏúÊÛ¼¼Êõ·þÎñÈÈÏߣº 186 2133 7130
Î÷ÃÅ×ÓMM440±äƵÆ÷¶©»õºÅ£º
6SE6440-2UD13-7AA1
1 ST A EAR99 N 1 1.3 DA51-E 323 9819 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.37 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.37 KW 173 x 73 x 149 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD15-5AA1
 1 ST A EAR99 N 1 1.3 DA51-E 323 9819 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.55 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.55 KW 173 x 73 x 149 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD17-5AA1
1 ST A EAR99 N 1 1.3 DA51-E 323 9819 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.75 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬0.75 KW 173 x 73 x 149 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD21-1AA1
 1 ST A EAR99 N 1 1.3 DA51-E 323 9819 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬1.1 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬1.1 KW 173 x 73 x 149 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD21-5AA1
1 ST A EAR99 N 1 1.3 DA51-E 323 9819 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬1.5 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬1.5 KW 173 x 73 x 149 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD22-2BA1
1 ST A EAR99 N 1 3.3 DA51-E 323 9820 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬2.2 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬2.2 KW 202 x 149 x 172 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD23-0BA1
1 ST A EAR99 N 1 3.3 DA51-E 323 9820 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬3 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬3 KW 202 x 149 x 172 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD24-0BA1
1 ST A EAR99 N 1 3.3 DA51-E 323 9820 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬4 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬4 KW 202 x 149 x 172 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD25-5CA1
1 ST A N N 1 5.5 DA51-E 323 9821 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬5.5 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬7.5 KW 245 x 185 x 195 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD27-5CA1
1 ST A EAR99 N 1 5.5 DA51-E 323 9821 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬7.5 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬11 KW 245 x 185 x 195 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD31-1CA1
 1 ST A EAR99 N 1 5.5 DA51-E 323 9821 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬11 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬15 KW 245 x 185 x 195 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD31-5DA1
1 ST A EAR99H N 1 16 DA51-E 323 9822 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬15 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬18.5 KW 520 x 275 x 245 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD31-5DB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 500-600 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  15 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  18.5 KW 520 X 275 X 245 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD31-8DA1
1 ST A EAR99H N 1 16 DA51-E 323 9822 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬18.5 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬22 KW 520 x 275 x 245 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD31-8DB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  18.5 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  22 KW 520 X 275 X 245 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD32-2DA1
1 ST A EAR99H N 1 16 DA51-E 323 9822 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬22 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬30 KW 520 x 275 x 245 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD32-2DB1
 1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  22 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  30 KW 520 X 275 X 245 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD33-0EA1
1 ST A EAR99H N 1 20 DA51-J 323 9823 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬30 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬37 KW 650 x 275 x 245 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD33-0EB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  30 KW OVERLOAD  150% 60 S, 200% 3 S SQUARED TORQUE POWER  37 KW 650 X 275 X 245 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD33-7EA1
 1 ST A EAR99H N 1 20 DA51-J 323 9823 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬37 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬45 KW 650 x 275 x 245 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD33-7EB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  37 KW OVERLOAD  150% 60 S, 200% 3 S SQUARED TORQUE POWER  45 KW 650 X 275 X 245 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD34-5FA1
1 ST A EAR99H N 1 56 DA51-J 323 9824 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬45 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬55 KW 850 x 350 x 320 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
 6SE6440-2UD34-5FB1
 1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  45 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  55 KW 850 X 350 X 320 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD35-5FA1
 1 ST A EAR99H N 1 56 DA51-J 323 9824 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬55 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬75 KW 850 x 350 x 320 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD35-5FB1
 1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  55 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  75 KW 850 X 350 X 320 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD37-5FA1
1 ST A EAR99H N 1 56 DA51-J 323 9824 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬75 KW ¹ýÔØ 150%£¬ÓÃÓÚ 60S£¬200% 3 S£¬Æ½·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬90 KW 850 x 350 x 320 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È -10 - +50 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD37-5FB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  75 KW OVERLOAD 150% 60 S, 200% 3 S SQUARED TORQUE POWER  90 KW 850 X 350 X 320 (H X W X D) PROTECTION IP20 AMBIENT TEMP. -10 TO +50 DEG. C WITHOUT AOP/BOP °´ÒªÇó
 6SE6440-2UD38-8FA1
 1 ST D EAR99H N 1 110 DA51-K 324 9825 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬90 KW ¹ýÔØ 136%£¬ÓÃÓÚ 57S£¬160% 3 S ƽ·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬110 KW 1400 x 326 x 356 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È 0 - +40 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD38-8FB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  90 KW OVERLOAD 136% 57 S, 160% 3 S SQUARED TORQUE POWER  110 KW 1400 X 326 X 356 (H X W X D) PROTECTION IP20 AMBIENT TEMP. 0 TO +40 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD41-1FA1
1 ST D EAR99H N 1 116 DA51-K 324 9825 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬110 KW ¹ýÔØ 136%£¬ÓÃÓÚ 57S£¬160% 3 S ƽ·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬132 KW 1400 x 326 x 356 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È 0 - +40 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD41-1FB1
 1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  110 KW OVERLOAD 136% 57 S, 160% 3 S SQUARED TORQUE POWER  132 KW 1400 X 326 X 356 (H X W X D) PROTECTION IP20 AMBIENT TEMP. 0 TO +40 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD41-3GA1
1 ST D EAR99H N 1 170 DA51-K 324 9826 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬132 KW ¹ýÔØ 136%£¬ÓÃÓÚ 57S£¬160% 3 S ƽ·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬160 KW 1533 x 326 x 545 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È 0 - +40 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD41-3GB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  132 KW OVERLOAD 136% 57 S, 160% 3 S SQUARED TORQUE POWER  160 KW 1533 X 326 X 545 (H X W X D) PROTECTION IP20 AMBIENT TEMP. 0 TO +40 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD41-6GA1
1 ST D EAR99H N 1 174 DA51-K 324 9826 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬160 KW ¹ýÔØ 136%£¬ÓÃÓÚ 57S£¬160% 3 S ƽ·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬200 KW 1533 x 326 x 545 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È 0 - +40 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD41-6GB1
1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  160 KW OVERLOAD 136% 57 S, 160% 3 S SQUARED TORQUE POWER  200 KW 1533 X 326 X 545 (H X W X D) PROTECTION IP20 AMBIENT TEMP. 0 TO +40 DEG. C WITHOUT AOP/BOP °´ÒªÇó
6SE6440-2UD42-0GA1
 1 ST D EAR99H N 1 176 DA51-K 324 9826 Falsch 0 0   MICROMASTER 440£¬²»´øÂ˲¨Æ÷£¬3AC 380-480V +10/-10% 47-63Hz£¬ºãת¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬200 KW ¹ýÔØ 136%£¬ÓÃÓÚ 57S£¬160% 3 S ƽ·½×ª¾Ø£¬¶î¶¨Êä³ö¹¦ÂÊ£¬250 KW 1533 x 326 x 545 (H x W x D)£¬·À»¤µÈ¼¶ IP20£¬»·¾³ÎÂ¶È 0 - +40 ¡æ£¬²»´ø AOP/BOP °´ÒªÇó
6SE6440-2UD42-0GB1
 1 ST D N N 1 °´ÒªÇó  ID  Falsch 0 0   MICROMASTER 440 WITHOUT FILTER 3AC 380-480 V +10/-10% 47-63 HZ CONSTANT TORQUE POWER  200 KW OVERLOAD 136% 57 S, 160% 3 S SQUARED TORQUE POWER  250 KW 1533 X 326 X 545 (H X W X D) PROTECTION IP20 AMBIENT TEMP. 0 TO +40 DEG. C WITHOUT AOP/BOP °´ÒªÇó
¹«Ë¾Ãû³Æ£º ÉϺ£º²ÔÁ×Ô¶¯»¯ÏµÍ³ÓÐÏÞ¹«Ë¾
µç »°£º 021 60531208 / ½ð·ïÎõ
ÊÖ»ú£º 18621337130
µØ Ö·£º ÉϺ£ÊÐËɽ­ÇøË¼ÏÍ·2399Ū137ºÅ
ÓÊ ±à£º 201600
Ö÷ Ò³£º http://han-yue.com
  • Î÷ÃÅ×ÓPLCÖйú×Ü´úÀí
  • Î÷ÃÅ×ÓCP5613¹âÏËÍø¿¨
  • Î÷ÃÅ×ÓCP5613Íø¿¨
  • Î÷ÃÅ×ÓCP5512Íø¿¨
  • Î÷ÃÅ×ÓCP5611Íø¿¨
  • Î÷ÃÅ×ÓUSB½Ó¿Ú±à³ÌµçÀÂ
  • Î÷ÃÅ×ÓCPU312C
  • Î÷ÃÅ×ÓCPU313C
  • Î÷ÃÅ×ÓCPU314
  • Î÷ÃÅ×ÓCPU313C-2DP
