Product Features
00001. Intel® H110 Express Chipset
00002. Supports Intel LGA 1151 Socket Core™ i3, i5, i7 & Pentium Processors
00003. 2 * Dual Channel DDR4 2133MHz up to 32GB
00004. 2* GbE LAN (Intel i211AT & i219LM)
00005. Support Intel vPro, Active Management Technology (iAMT 11.0)
00006. Integrated Realtek ALC662VD Audio CODEC 6-CH
00007. Support 1*PCIe x16 slot
00008. Support 10”COM
00009. Support 12”USB3.0&2.0
00010. Support 4 * SATAIII (6.0Gb/s), Support RAID 0,1,5,10
00011. HDMI/DP/DVI-D Video Outputs
00012. Built-in Watchdog Timer Technology
00013. Mini-ITX Form Factor (180mm * 180mm)
Form Factor
Dimensions
- Mini-ITX (180 * 180mm)
Processor System
CPU
- Intel LGA 1151 Socket Core i7 / i5 / i3 Pentium Processor
Core Number
- (by CPU)
Max Speed
- (by CPU)
L2 Cache
- (by CPU)
Chipset
- Intel H110 Express chipset
BIOS
- AMI 128Mb Flash ROM
Expansion Slot
PCI
- 0
Mini-PCIe
- 2 (1* Half size & 1*Full size co-lay with mSATA)
mSATA
- 1 ( Full size , co-lay with mPCIe)
PCIe
- 1 x16
CFast Card Socket
- 0
CF Card Socket
- 0
Memory
Technology
- DDR4 2133MHz Dual CH
Max.
- 32GB
Socket
- 2 * SO-DIMM
Graphics
Controller
- (by CPU)
VRAM
- Shared Memory
VGA
- 0
LVDS
- 1 * Onboard 24-bits dual channel connector
HDMI
- 1 ( Hdmi2.0 , Max. Resolution: 4096*2160@60Hz)
DVI-D
- 1 ( Max. Resolution: 1920*1080 )
DisplayPort
- 1 ( DP1.2, Max. Resolution: 4096*2304@60Hz )
MultiDisplay
- Yes (Triple Display)
Ethernet
Ethernet
- 10/100/1000 Mbps
Controller
- GbE LAN: INI219LM + i211AT
Connector
- 2* RJ 45
Audio
CODEC
- HD Audio : Realtek ALC662VD
Channel
- 6 Channel
SATA
Max Data Transfer Rate
- 4 * SATAIII (6.0Gb/s)
RAID
- Yes(RAID 0,1,5,10)
Rear I/O
VGA
- 0
DVI-D
- 1
HDMI
- 1
DisplayPort
- 1
Ethernet
- 2
USB
- 6 * USB 3.0
Audio
- 3 ( MIC , Line-out, Line-in )
Serial
- 2 (COM1 support RS232/422/485 )
eSATA
- 0
PS2
- 0
Internal Connector
USB
- 2 * USB 2.0
PS/2
- 1
LVDS / inverter
- 1
VGA
- 0
Serial
- 8 ( COM 3 support RS232/422/485 )
SATA
- 4 * SATAIII ( 6.0Gb/s )
mPCIe
- 2 (1*Half size , 1*Full size co-lay with mSATA)
Parallel
- 0
mSATA
- 1 ( Full size co-lay with mPCIe )
CIR
- 0
GPIO 8-bit
- 4in / 4out
Chassis intrusion
- 1
Audio Header
- 1
TPM
- 1 (Option)
Watchdog Timer
Output
- From Super I/O to drag RESETCON#
Interval
- 256 segments, 0,1,2…255sec/min
Power Requirements
Input PWR
- 24 pin/4 pin ATX PWR Connector
Power On
AT/ATX Supported
- AT : Directly PWR on as Power input ready
- ATX: Press Button to PWR on after Power input ready
Certifications
Certifications
- CE, FCC, RoHS, REACH
Environment
Temperature
- Operating: 0°C – 60°C
- Storage: -20°C – 85°C
