Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú HYBRID STEPPER MOTOR-NEMA23HS
²úÆ·Ãû³Æ£º HYBRID STEPPER MOTOR-NEMA23HS
ÐÍ ºÅ£º NEMA23HS
Motor length£º
model motor length
23HS0XXX 41mm
23HS4XXX 45mm
23HS1XXX 51mm
23HS5XXX 56mm
23HS6XXX 64mm
23HS7XXX 76mm
23HS8XXX 100mm
23HS9XXX 112mm
Electrical Specifications:
£¨Electrical Specifications£©:
Series
Model
Step
Angle
Motor
Length
(mm)
Rated
Current
(A)
Phase
Resistance
(Ω)
Phase
Inductance
(mH)
Holding
Torque
(N.cm Min)
Detent
Torque
(N.cm Max)
Rotor
Inertia
 (g.cm²)
Lead
Wire
(No.)
Motor
Weight
(g)
23HS0610
1.8
41
1.0
5.2
5.5
40
2.5
150
6
470
23HS04062
1.8
41
0.62
12
24
55
2.5
150
4
470
23HS0420
1.8
41
2.0
1.2
2.5
55
2.5
150
4
470
23HS44062
1.8
45
0.62
12
26
80
2.8
190
4
520
23HS4425
1.8
45
2.5
1.0
2.2
80
2.8
190
4
520
23HS14062
1.8
51
0.62
13
28
110
2.8
190
4
520
23HS1425
1.8
51
2.5
1.2
3.2
110
2.8
190
4
520
23HS1608
1.8
51
0.8
6.8
9.2
62
3.0
230
6
590
23HS5615
1.8
56
1.5
3.2
5.5
90
3.5
280
6
590
23HS5425
1.8
56
2.5
1.3
4.2
110
3.5
280
4
680
23HS5430
1.8
56
3.0
0.8
2.4
110
3.5
280
4
680
23HS5442
1.8
56
4.2
0.4
1.2
110
3.5
280
4
680
23HS6410
1.8
64
1.0
7.5
20
150
5.0
380
4
850
23HS6425
1.8
64
2.5
1.5
4.5
150
5.0
380
4
850
23HS6430
1.8
64
3.0
0.8
2.3
150
5.0
380
4
850
23HS6442
1.8
64
4.2
0.55
1.2
150
5.0
380
4
850
23HS7615
1.8
76
1.5
4.5
7.8
140
6.0
440
6
1050
23HS7425
1.8
76
2.5
1.8
6.5
180
6.0
440
4
1050
23HS7430
1.8
76
3.0
1.0
3.5
180
6.0
440
4
1050
23HS8742
1.8
76
4.2
0.6
1.8
180
6.0
440
4
1050
23HS8430
1.8
78
3.0
1.4
5.5
250
10
680
4
1250
23HS8442
1.8
100
4.2
0.8
3.0
250
10
680
4
1250
23HS9430
1.8
112
3.0
1.6
6.8
280
12
800
4
1400
23HS9442
1.8
112
4.2
0.9
3.8
280
12
800
4
1400
*Note: We can manufacture products according to customer’s requirement
¹«Ë¾Ãû³Æ£º ³£ÖÝÈÙÊÀµçÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 0519 85138166 / ÍõÐÄâù
ÊÖ»ú£º
µØ Ö·£º ½­ËÕÊ¡³£ÖÝÊÐÆÝÊûÑßÇøÕþ´ó·1ºÅÁ¦´ï¹¤ÒµÔ°
ÓÊ ±à£º 213025
Ö÷ Ò³£º http://www.longs-motor.com.cn
  • ÓÀ´Åʽ²½½øµç»ú---PM15
  • ÓÀ´Åʽ²½½øµç»ú---PM25
  • ÓÀ´Åʽ²½½øµç»ú---PM20
  • ÓÀ´Åʽ²½½øµç»ú---PM35
  • ÓÀ´Åʽ²½½øµç»ú---PM42
  • Ö±Á÷ÎÞË¢µç»ú---86BLF
  • Ö±Á÷ÎÞË¢µç»úÇý¶¯Æ÷---DCBL-0115A
  • ²½½ø³ÝÂÖÏäµç»ú---42BYGH
  • ²½½ø³ÝÂÖÏäµç»ú---57BYGH
