²úÆ·Ãû³Æ£º
42BYGH
ÐÍ ºÅ£º
HYBRID STEPPER MOTOR-NEMA17HS
Electrical Specifications
Step
Angleº
Motor
Length
mm
Rated
voltage
v
Rated
Current
A
Phase
Resistance
Ω
Phase
Indutance
Mh
Holding
Torque(MIN)
N.m
Detent
Toruue(MAX)
N.cm
Rotor
Torque
g.cm2
Lead
Wire
Motor
Weight
KG
1.8
34
12
0.4
30
38
0.32
1.6
35
4
0.22
1.8
34
10.2
0.3
34
25.5
0.22
2.0
34
6
0.22
1.8
34
3.2
1.33
2.45
4.0
0.3
1.2
35
4
0.22
1.8
40
12
0.4
30
28.2
0.38
1.5
54
6
0.28
1.8
40
5.0
0.4
12.5
21
0.22
2.2
54
4
0.28
1.8
40
3.6
1.2
3.0
2.8
0.4
2.2
54
6
0.28
1.8
40
2.55
1.7
1.5
2.8
0.4
2.2
54
4
0.28
1.8
40
2.55
1.7
1.5
2.8
0.4
2.2
54
4
0.28
1.8
48
12
0.4
30
28
0.48
2.8
68
6
0.36
1.8
48
6
0.8
7.5
6.3
0.32
2
68
6
0.36
1.8
48
4.16
1.3
3.2
5.5
0.52
2.6
68
4
0.36
1.8
48
3.06
1.7
1.8
3.2
0.52
2.6
68
4
0.36
1.8
48
2.76
2.3
1.2
1.6
0.46
2.6
68
4
0.36
1.8
48
4.2
1.5
2.8
1.8
0.55
2.8
68
4
0.36
1.8
48
3.1
2.5
1.25
1.8
0.48
2.8
68
4
0.36
